Topic: arduino databse eeprom lib (Read 5970 times) previous topic - next topic
yair
im looking for a db lib
all dedicated solutions i found are broken on 1.0
roll my own?
http://www.arduino.cc/playground/Code/ExtendedDatabaseLibrary
http://www.arduino.cc/playground/Code/DatabaseLibrary
PaulS
So? Fix one of them.
You really don't have a lot of room for a database on an Arduino. 2K doesn't hold a lot of data.
yair
ok, attached zip of extendeDb lib compiles under 1.0.1
robtillaart
Thanks for sharing,
added a link on - http://arduino.cc/playground/Code/ExtendedDatabaseLibrary - to this thread so people see your updated lib
Rob Tillaart
yair
thanks robtillaar, to make compatible i replaced WProgram.h with
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
#else
  #include "WProgram.h"
actually i dont real like that lib, made me want to get closer to the metal.
anyways i did some benchmark using EEPROMEx lib, and was a bit shocked to find out the write speeds of EEPROM
Check how much time until EEPROM ready to be accessed
Time to write 1 byte  (ms)                        : 0
Recovery time after writing byte (ms)             : 4
Time to write Long (4 bytes) (ms)                 : 10
Recovery time after writing long (ms)             : 4
Time to read Long (4 bytes) (ms)                  : 0
Recovery time after reading long (ms)             : 0
Time to write 7 byte array  (ms)                  : 20
Time to update 7 byte array with 7 new values (ms): 18
Time to update 7 byte array with 3 new values (ms): 10
Time to read 7 byte array (ms)                    : 0
so i've been thinking about moving over to PROGMEM land (using this FLASH lib).
my db is about 510 bytes.
is flash memory a better path?
not just for speed. any cons?
PaulS
Besides being read-only? Nope. Can't think of any.
yair
yair
dont get it, eeprom is also technically "read only"
http://www.arduino.cc/playground/Learning/Memory
i've seen text that mentioned you can not use progmem to write variables.
but the learning page is a bit slim on details.
dxw00d
Where does it say that EEPROM is read-only? It says
EEPROM is memory space that programmers can use to store long-term information.
and
...EEPROM memory are non-volatile (the information persists after the power is turned off).
Neither of which imply read-only.
yair
Electrically Erasable Programmable Read-Only Memory
dxw00d
I know what it means. It's a bit of a misnomer really though.
robtillaart
wrt performance issues:
The database code does not take into account that EEPROM writes are often done in pages (chucks of bytes, powers of 2, 16/32/64 etc)
If you need to updat 7 vars in 1 page you can do that in 7 writes but also in 1.
Seems that you did it per byte.
Rob Tillaart
yair
thanks for the tip,
so:
Quote from: http://arduiniana.org/libraries/flash
PROGMEM (Flash) data region can only be populated at program burn time. You can't change the values in the flash after the program has started running.
i think its worth mentioning in the learning.Memory section.
robtillaart
Rob Tillaart
