Loading...
Pages: 1 ... 4 5 [6]   Go Down
Author Topic: Scrolling text on LED matrices using SPI and arduino Mega2560  (Read 3195 times)
Raleigh, NC.
Offline Offline
Full Member
Addicted to Arduino
View Profile
you're right....but you use the serial monitor quite a bit......and arrays is dusty to me.....trying to get more skills on that
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Yes, serial monitor is nice for sending debug statements to see what is going on, comment them out as things work and they are no longer needed.
Once you understand arrays and pointers into arrays and copying data from the array and putting it somewhere else, things will start gelling.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Raleigh, NC.
Offline Offline
Full Member
Addicted to Arduino
View Profile
I have a single 8 x 8 scrolling very nice now......And just a heads up...
with the 8 pins on each side of the matrix I thought pins 1-8 were swapped and pins 9-16 were swapped right...
No.....because I just wired up this single 8 x 8 how I have it in my enclosure.....did the same thing...letters are backwards.....
so I swapped the Column pins ONLY.....Like C0 - C7       C1 - C6           C2 - C5         C3 - C4
and now its scrolling like a champ.....(just the one matrix I have with my Duemilanove here:)
pic attached
I'm going to try and consolidate more code and get my enclosure working fully...after I swap some column wires too.....
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Yes, need to "map out" the display being used.
I had to turn my 4 displays 90 degrees and re-wire them, (and then flipped the columns in the code anyway) to have the LED at Anode7, Cathode7 be the upper left, and Anode0, Cathode0 be the lower right.
Logged
Pages: 1 ... 4 5 [6]   Go Up
Print
Jump to:
