Topic: Trouble with our Keypad Code (Read 999 times) previous topic - next topic
Hello fellow programmers!
It's a late night here at CCM, having trouble with our Midterm for our Special Topics Class. Our code is having a lot of syntax problems, and we are having exceptional difficulty making the (##) portion of our assignment, as (#) also funtions as an enter key as well. Here is the official assignment:
Four Digit Key PAD UN-LOCK- CODE
   RED/GREEN LED is Flashing  GREEN……. One flash every two seconds…
   Each time a key is pushed the RED/GREEN LED flashes one time GREEN and is then off… (if another key is not pressed in 5 seconds….Lock the KEYPAD)
   After the correct four digits and the enter key, the RED/GREEN LED  Flashes 4 times and stays on GREEN
Here is what we have so far (very hodge podge coding, brace yourself)
int i, k, pwcount=0;
char password[] = "1342", entry[10];
int ledGreen = 9;
int ledRed = 10;
for(i=2; i<=5; i++)
pinMode(i, INPUT);
  for(i=6; i<=9; i++)
pinMode(i, OUTPUT);
  pinMode(ledGreen, OUTPUT);
pinMode(ledRed, OUTPUT);
  for(i=6; i<=8; i++){
  reset();
  digitalWrite(i, HIGH);
  if(digitalRead(2)==HIGH && i==6){
    blinker();
    entry[pwcount] = '1';
    pwcount++;
   delay(300);
  Serial.print('1');
  if(digitalRead(3)==HIGH && i==6){
    blinker();
    entry[pwcount] = '4';
    pwcount++;
   delay(300);
  Serial.print('4');
  if(digitalRead(4)==HIGH && i==6){
    blinker();
    entry[pwcount] = '7';
    pwcount++;
   delay(300);
  Serial.print('7');
   if(digitalRead(5)==HIGH && i==6){
     blinker();
    entry[pwcount] = '*';
    pwcount++;
   delay(300);
  Serial.print('*');
   if(digitalRead(2)==HIGH && i==7){
     blinker();
    entry[pwcount] = '2';
    pwcount++;
   delay(300);
  Serial.print('2');
  if(digitalRead(3)==HIGH && i==7){
    blinker();
    entry[pwcount] = '5';
    pwcount++;
   delay(300);
  Serial.print('5');
  if(digitalRead(4)==HIGH && i==7){
    blinker();
    entry[pwcount] = '8';
    pwcount++;
   delay(300);
  Serial.print('8');
   if(digitalRead(5)==HIGH && i==7){
     blinker();
   entry[pwcount] = '0';
    pwcount++;
   delay(300);
  Serial.print('0');
    if(digitalRead(2)==HIGH && i==8){
      blinker();
    entry[pwcount] = '3';
    pwcount++;
   delay(300);
  Serial.print('3');
  if(digitalRead(3)==HIGH && i==8){
    blinker();
   entry[pwcount] = '6';
    pwcount++;
   delay(300);
  Serial.print('6');
  if(digitalRead(4)==HIGH && i==8){
    blinker();
   entry[pwcount] = '9';
    pwcount++;
   delay(300);
  Serial.print('9');
   if(digitalRead(5)==HIGH && i==8){
    blinker();
   delay(300);
  Serial.println('#');
  pwcount=0;
  for(k=0; k<=4; k++){
   if(k==4){
   Serial.println("Access Granted");
   digitalWrite(ledGreen, HIGH);
   digitalWrite(ledGreen, LOW);
   break;
   if(password[k] != entry[k]){
     Serial.println("Denied");
     digitalWrite(ledRed, HIGH);
     delay (500);
     digitalWrite(ledRed, LOW);
     delay (500);
     delay (500);
     delay (500);
     break;
  for(k=0; k<10; k++)
  entry[k]=0;
void reset(){
   int j;
   for(j=6; j<=8; j++)
   digitalWrite(j, LOW);
void blinker(){
  delay(20);
Nick Gammon
          delay (500);
          delay (500);
          delay (500);
          delay (500);
Better read up on how to make a loop.
More info:
Sorry, we are very very very new and are attempting to stumble our way through this until we fall flat on our faces with some wisdom.
AWOL
