Topic: A function to handle multiple datatypes (Read 21494 times) previous topic - next topic
cjparish
I tried to compile a sketch including the code you posted and I get the following errors:
Code: [Select]
sketch_nov01a:2: error: expected ',' or '...' before '&' token
sketch_nov01a:2: error: ISO C++ forbids declaration of 'T' with no type
Using Arduino 1.0.1 on a Mac
pico
#16
Nov 02, 2012, 08:32 am Last Edit: Nov 02, 2012, 08:34 am by pico Reason: 1
If you buy a gun, you can shoot yourself in the foot. If you want to.
True. It really comes down to whether or not you have the skill to handle the gun. You have to know the limits of your competence.
So I guess you never do any assembly language programming at all then, huh? How dangerous is that? No type checking at all. Every line of code a virtual death trap.  :smiley-roll:
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
cjparish
Wow. Well this could always be settled with a duel. Handbags at dawn perhaps?
However, in the mean time.... why won't my code work?  =(
cjparish
Well whist you guys were fighting I tried this and it seems to work. Thanks
Code: [Select]
template <class T> void sendAnything(const T& value)
    const byte* p = (const byte*)(const void*)&value;
    unsigned int i;
    for (i = 0; i < sizeof(value); i++) {
      if (*p == 0x7E || *p == 0x7D) { //byte stuffing
        Serial.write(0x7D);
        Serial.write(*p++ ^ 0x20);
        Serial.write(*p++);
cjparish
Just one other quick question:
How might I modify the above code to send the bytes MSB first?
Coding Badly
How do you expect that to work when you call sendAnything with a string?
cjparish
Oh yeah, duh.
As I said. Just finished a night shift. Not optimum time for writing code.....
nickgammon
What is this assembly language of which you speak?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
While you were fixing dinner I was making a sandwich.
michael_x
Well, it works somehow. You might rename it to sendAnyValueOrItsAddress ;)
Arduino is famous for  NoErrorHandling Software, so I'd max. add a comment in the library .cpp source code.
@Chris: rather look at the Serial.print() ( resp. hardware\arduino\cores\arduino\Print.h  / .cpp ) code
for a nice sample of function overloading.
nickgammon
Quote
Code: [Select]
You lost me on that line. Perhaps I should learn assembler?
nickgammon
Arduino is famous for  NoErrorHandling Software ...
So is Microsoft.
michael_x
Quote
Code: [Select]
It's plain good old C, and provides } as an escape character to avoid ever sending a tilde character ~ 0x7e
Don't ask my why, nor why some might consider this "fun".
nickgammon
Quote
Code: [Select]
Oh I see. It's so obvious now. So really:
Code: [Select]
      if (*p == '~' || *p == '}') { //byte stuffing
        Serial.write('}');
That would certainly stuff the bytes. Particularly if the data type was, say, an int.
And the point of this line?
Code: [Select]
Honestly, this is why you shouldn't fiddle with pointers if you don't understand what you are doing.
michael_x
#29
Nov 02, 2012, 11:57 am Last Edit: Nov 02, 2012, 12:02 pm by michael_x Reason: 1
Quote
Nick, are you joking?
It's sending  a ~ as }^ and a real } as }]
It's allowing to insert meta data in the stream, marked by a ~ starting character.
Or add other special characters -- by prefixing them with }
