Topic: char key = keypad.getKey(); command interference sms prgramming (Read 3872 times) previous topic - next topic
roy0926
Nov 02, 2012, 06:55 am Last Edit: Nov 02, 2012, 07:40 am by roy0926 Reason: 1
Code: [Select]
#include <Password.h>
#include <LiquidCrystal.h>
#include <Keypad.h>
#include <SoftwareSerial.h>
#include <String.h>
SoftwareSerial mySerial(7, 8);
int fallalert = LOW;
LiquidCrystal lcd(22, 24, 26, 28, 30, 32);
Password password = Password( "4321" );
const byte ROWS = 4; // Four rows
const byte COLS = 4; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
 {'1','2','3','F'},
 {'4','5','6','E'},
 {'7','8','9','D'},
 {'A','0','B','C'},
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = {39, 41, 43, 45}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {31, 33, 35, 37}; //connect to the column pinouts of the keypad
const int buttonPin = 2;
int buttonState = 0;
int count=0;
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
const int ledPin =  13;
void setup(){
pinMode(buttonPin, INPUT);
lcd.begin(16, 2);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW); // sets the LED OFF
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
keypad.setDebounceTime(250);
 mySerial.begin(19200);               // the GPRS baud rate
 pinMode(12, INPUT);
void loop(){
  fallalert = digitalRead(12);
  buttonState = digitalRead(buttonPin);
 if (buttonState == HIGH)
    lcd.clear();
 if(fallalert == HIGH)
   SendTextMessage();
   Serial.println("t");
  fallalert = LOW;
  delay(2000);
 if (Serial.available())
   switch(Serial.read())
    case 't':
      SendTextMessage();
 if (mySerial.available())
   Serial.write(mySerial.read());
 ///SendTextMessage()
///this function is to send a sms message
void SendTextMessage()
 mySerial.print("AT+CMGF=1\r");    //Because we want to send the SMS in text mode
 delay(100);
 mySerial.println("AT + CMGS = \"+6583989586\"");//send sms message, be careful need to add a country code before the cellphone number
 delay(100);
 mySerial.println("SUCCESSFULLY SEND FROM GPRS");//the content of the message
 delay(100);
 mySerial.println((char)26);//the ASCII code of the ctrl+z is 26
 delay(100);
 mySerial.println();
//take care of some special events
void keypadEvent(KeypadEvent eKey)
switch (keypad.getState())
case PRESSED:
lcd.print(eKey);
switch (eKey)
case 'E': guessPassword(); break;
default:
password.append(eKey);
void guessPassword(){
if (password.evaluate()){
digitalWrite(ledPin,HIGH); //activates garaged door relay
digitalWrite(ledPin,LOW); //turns off door relay after .5 sec
lcd.setCursor(0, 1);
lcd.print("PASS   "); //
password.reset(); //resets password after correct entry
lcd.print("Welcome");
delay(2000);
lcd.clear();
else{
lcd.print("WRONG ");
password.reset(); //resets password after INCORRECT entry
lcd.clear();
My project is use arduino uno and sim900. I want make a keypad control and also need send message.
This my code , if I remove char key = keypad.getKey(); command , sms function can work but the keypad function can not work.
nickgammon
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
roy0926
Code: [Select]
#include <Keypad.h>
#include <String.h>
  {'1','2','3','F'},
  {'4','5','6','E'},
  {'7','8','9','D'},
  {'A','0','B','C'},
int count=0;
void setup(){
lcd.begin(16, 2);
  pinMode(12, INPUT);
void loop(){
     lcd.clear();
    SendTextMessage();
   fallalert = LOW;
   delay(2000);
     case 't':
       SendTextMessage();
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  mySerial.println();
case PRESSED:
lcd.print(eKey);
switch (eKey)
default:
delay(2000);
lcd.clear();
else{
lcd.clear();
This is my code , if I remove" char key = keypad.getKey(); "command , sms function can work but the keypad function can not work.
nickgammon
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
I asked you to edit your post. Not to start a totally new thread.
- Moderator
