Offline
Newbie
« on: November 02, 2012, 06:02:12 pm » |
I've been searching through the library code as well as thoroughly searched Google and haven't come across any working timer interrupt code for the Due. I could do this on the Uno in my sleep, but have yet to figure it out on the Due. Any pointers ( http://xkcd.com/138/) or example code would be greatly appreciated. Basically I want to get a function to run once every X microseconds. Thanks.
Logged
Offline
Jr. Member
« Reply #1 on: November 03, 2012, 06:23:54 am » |
Yeah, I was hoping to get timer interrupt hints on my thread for Tone.cpp code. I've done timers on Uno and Maple, but Maple IO architecture is quite different from DUE. There is PWM timer code in hardware/arduino/sam/cores/arduino/wiring_analog.c but no interrupt code. The Timer/Counter support routines (no interrupt routines) are in hardware/arduino/sam/system/libsam/source/tc.c with the #define's in hardware/arduino/sam/system/CMSIS/Device/ATMEL/sam3sd8/include/component/component_tc.h The ISR handler's are named TCx_Handler(), e.g. TC0_Handler()
I'm guessing (don't have a DUE yet) that interrupt enable would be something like tc->TC_CHANNEL[chan].TC_IER = TC_IER_CPCS; but there is also an interrupt mask register TC_IMR?
not much help, but hopeful ...
Logged
Online
Sr. Member
« Reply #2 on: November 03, 2012, 10:17:16 pm » |
I think I'm getting somewhere with this... try this: volatile boolean l;
void TC0_Handler() { long dummy=REG_TC0_SR0; // vital - reading this clears some flag // otherwise you get infinite interrupts l= !l; }
void setup(){ pinMode(13,OUTPUT); pinMode(2,OUTPUT); // port B pin 25 analogWrite(2,255); // sets up some other registers I haven't worked out yet REG_PIOB_PDR = 1<<25; // disable PIO, enable peripheral REG_PIOB_ABSR= 1<<25; // select peripheral B REG_TC0_WPMR=0x54494D00; // enable write to registers REG_TC0_CMR0=0b00000000000010011100010000000000; // set channel mode register (see datasheet) REG_TC0_RC0=100000000; // counter period REG_TC0_RA0=30000000; // PWM value REG_TC0_CCR0=0b101; // start counter REG_TC0_IER0=0b00010000; // enable interrupt on counter=rc REG_TC0_IDR0=0b11101111; // disable other interrupts
NVIC_EnableIRQ(TC0_IRQn); // enable TC0 interrupts
void loop(){ digitalWrite(13,l); }
The timer controls the output of pin 2 and the interrupt toggles a flag which is output on pin 13.
Logged
Dubai, UAE
Offline
Edison Member
« Reply #3 on: November 04, 2012, 12:21:56 am » |
Hi, Whats the best resource you have found for describing the timer registers ? Thanks Duane B rcarduino.blogspot.com
Logged
Offline
Newbie
« Reply #4 on: November 04, 2012, 04:55:08 am » |
Not what you're looking for, but on a similar topic: I wanted to use the TC* timers to create a software servo library but I couldn't find out how to use the timers so I ended up using the PWM clock to generate the output. While testing the PWM pulse I used attachInterrupt on the same pin to measure the pulse timing, effectively creating software interrupts. It's a hack, but if you're interested the code is here: http://arduino.cc/forum/index.php/topic,130631.0.htmlIt doesn't use any registers, so I can't tell you about those - just add attachInterrupt()
Logged
Offline
Jr. Member
« Reply #5 on: November 04, 2012, 07:06:18 am » |
timer/counter registers are detailed in chapter 37 of datasheet
Logged
Offline
Newbie
« Reply #6 on: November 04, 2012, 10:14:02 am » |
The timer controls the output of pin 2 and the interrupt toggles a flag which is output on pin 13. I'll give this a shot thanks. I am curious though why you didn't do a digitalWrite() inside the handler? Arduino's digitalWrite() function is pretty clock-cycle heavy, but the following code works just fine for writing a digital output and only takes a couple of clock cycles if that was the primary concern. static inline void pinOutput(int pin, int val) { if (val) g_APinDescription[pin].pPort->PIO_SODR = g_APinDescription[pin].ulPin; else g_APinDescription[pin].pPort->PIO_CODR = g_APinDescription[pin].ulPin; } On another note, Maple uses a different processor, but gives as good of an explanation / example of how timers work as I've found so far: http://leaflabs.com/docs/timers.htmlhttp://leaflabs.com/docs/lang/api/hardwaretimer.htmlhttp://leaflabs.com/docs/libmaple/api/timer.htmlI haven't tried to implement any of their code yet, but thought I'd share the links.
Logged
Online
Sr. Member
« Reply #7 on: November 04, 2012, 03:20:16 pm » |
I recognize that code fragment  As for digitalWrite not being in the handler, actually it was there originally, but you have to understand that I'd been struggling for hours with interrupt code that wouldn't fire, then it only fired once, then it got hammered with constant interrupts, and I didn't know what was going on. So I did what is pretty much standard debugging practice and changed the interrupt handler to do the absolute bare minimum just to be sure that digitalWrite wasn't causing a side effect (there's some architectures where you can't write certain registers in an interrupt). But the important thing turned out to be the dummy read of TC_SR0. By then it was late so I just posted what I'd done. Since then I have tried putting digitalWrite and direct port writes back in and they don't seem to cause any odd side effects. The Maple hardware is completely different unfortunately and the registers are incompatible.
Logged
Offline
Newbie
« Reply #8 on: November 04, 2012, 04:00:30 pm » |
I understand. Thanks
Logged
Offline
Newbie
« Reply #9 on: November 05, 2012, 03:48:40 pm » |
Using this code, you can set a timer for any of the ISRs TC0_Handler through TC8_Handler, see table of parameters below. It is possible to use the timers without a physically mapped pin, such as TC1 channel 0 (TC3_Handler) shown here: volatile boolean l;
//TC1 ch 0 void TC3_Handler() { TC_GetStatus(TC1, 0); digitalWrite(13, l = !l); }
void startTimer(Tc *tc, uint32_t channel, IRQn_Type irq, uint32_t frequency) { pmc_set_writeprotect(false); pmc_enable_periph_clk((uint32_t)irq); TC_Configure(tc, channel, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK4); uint32_t rc = VARIANT_MCK/128/frequency; //128 because we selected TIMER_CLOCK4 above TC_SetRA(tc, channel, rc/2); //50% high, 50% low TC_SetRC(tc, channel, rc); TC_Start(tc, channel); tc->TC_CHANNEL[channel].TC_IER=TC_IER_CPCS; tc->TC_CHANNEL[channel].TC_IDR=~TC_IER_CPCS; NVIC_EnableIRQ(irq); }
void setup(){ pinMode(13,OUTPUT); startTimer(TC1, 0, TC3_IRQn, 4); //TC1 channel 0, the IRQ for that channel and the desired frequency }
void loop(){ }
Here is the table of parameters: | ISR/IRQ | TC | Channel | Due pins | | TC0 | TC0 | 0 | 2, 13 | | TC1 | TC0 | 1 | 60, 61 | | TC2 | TC0 | 2 | 58 | | TC3 | TC1 | 0 | none <- this line in the example above | | TC4 | TC1 | 1 | none | | TC5 | TC1 | 2 | none | | TC6 | TC2 | 0 | 4, 5 | | TC7 | TC2 | 1 | 3, 10 | | TC8 | TC2 | 2 | 11, 12 |
Logged
Offline
Jr. Member
« Reply #10 on: November 05, 2012, 05:40:10 pm » |
Sebastian:
Well done! thanks
Logged
Offline
Newbie
« Reply #11 on: November 19, 2012, 12:32:46 pm » |
void loop(){ }
Noob question here, could someone please explain the inputs to the startTimer function? What is channel, and how do we use the frequency input? Also, what are the pins in the table for?
« Last Edit: November 19, 2012, 12:36:02 pm by mnpumar »
Logged
Offline
Newbie
« Reply #12 on: November 23, 2012, 08:52:35 am » |
Same question; please explain the inputs to the startTimer function.
Logged
Forum Administrator
Milano, Italy
Offline
Full Member
« Reply #14 on: November 24, 2012, 04:04:22 am » |
A brief explanation: The SAM3X8E CPU has 3 Timer Counters (TC) they are called TC0, TC1, TC2. Every Timer Counter contains 3 Channels numbered 0, 1 and 2 (this give us a total of 9 Channels). Every Channel has its own counters and interrupt handler that are independent from other Channels. In other words each Channel can be considered as a separate "Timer", and is like having 9 separate timers. To initialize a Channel you need the following parameters: TC0/TC1/TC2 - The Timer Counter instance 0 / 1 / 2 - The Channel number inside Timer Counter If you want to use interrupts you must enable the NVIC (Nested Vector Interrupt Controller) for that channel with: NVIC_EnableIRQ(TCx_IRQn);
where TCx_IRQn is the ID of the interrupt to enable. These id are listed in the following table together with the ISR handler function name: | TC | Chan | NVIC "irq" | IRQ handler function | PMC id | | TC0 | 0 | TC0_IRQn | TC0_Handler | ID_TC0 | | TC0 | 1 | TC1_IRQn | TC1_Handler | ID_TC1 | | TC0 | 2 | TC2_IRQn | TC2_Handler | ID_TC2 | | TC1 | 0 | TC3_IRQn | TC3_Handler | ID_TC3 | | TC1 | 1 | TC4_IRQn | TC4_Handler | ID_TC4 | | TC1 | 2 | TC5_IRQn | TC5_Handler | ID_TC5 | | TC2 | 0 | TC6_IRQn | TC6_Handler | ID_TC6 | | TC2 | 1 | TC7_IRQn | TC7_Handler | ID_TC7 | | TC2 | 2 | TC8_IRQn | TC8_Handler | ID_TC8 |
(note that TC 2_IRQn is the irq id for TC0-channel-2 not for TC2...) but this is still not enough! Every peripheral in the SAM3X is off by default (to save power) and should be turned on. To turn on you need to run the following command: pmc_enable_periph_clk(id); where id is found on the last column of the above table (ID_TCx). It happened that ID_TCx constant equals TCx_IRQn, so Sebastian Vik has simplified a bit the function using TCx_IRQn as input for pmc_enable_periph_clk: pmc_enable_periph_clk((uint32_t)irq); Hope this helps to decode whats happening with timers inside SAM3X. Nope, there are no libs neither tutorials. I've planned a SAM3Timer library (to simplify implementation of Arduino Core and some libraries) but I didn't started it yet. Volunteers?
« Last Edit: November 24, 2012, 04:15:53 am by cmaglie »
Logged
C.
