Loading...
Pages: [1]   Go Down
Author Topic: how to wire LCD with SPI  (Read 309 times)
Offline Offline
Newbie
View Profile
HI, guys.
I have one question about how to wire up LCD to Arduino
In my project, I connect MCP4822 with Arduino through SPI. So pin 12 and pin 10 are used for Arduino. Now I want to use LCD to show the output current. But Most of tutorials show the LCD using 12-10 for RS and RW. So I want to know could I use Pin 1-3 instead of pin 12-10.
I just want to make sure this.
Thanks
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
If you are not using Pin 13 for SCK, then you are not using SPI.
Maybe faking it with software SPI.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
I mean it looks like they are conflict with each other
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
With SPI, pins 13-12-11 are connected to all devices. Unique Slave Select pins are used to enable one device at a time.
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
If you are using a ST7920-based graphic LCD, then unfortunately it does not have a CS input. This means that it cannot share the SPI pins with another device. Here are a few solutions:
1. Drive one of the devices using software SPI. The ST7920 can be drive using ShiftOut, although ShiftOut is unnecessarily slow, and it'e easy to write a faster version.
2. If you are not using the UART, you can use the UART in SPI mode to get a second SPI channel.
3. Use an external and-gate to gate the clock to the ST7920.
However, if it's a text LCD (which uses about 5 other pins as well), then you can use any pins you like for RS and RW.
« Last Edit: November 03, 2012, 01:53:34 pm by dc42 » Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Pages: [1]   Go Up
Print
Jump to:
