Topic: Need testers for a new IDE (Read 10960 times) previous topic - next topic
graynomad
OK, downloaded and runs.
First thing, it looks good, I don't often use the IDE but when I do I'm inclined to use this one just because it is a more modern look and feel.
There is a list of examples in the right panel, how do you load them? Clicking, double-clicking, clicking the "Clone" button all have no obvious affect.
So to get some source code I ran the normal IDE to get the blink sketch.
It fails to compile
Code: [Select]
INFO: assembling sketch in directory: C:\Users\Rob\Documents\Arduino\Blink
INFO: using temp dir: C:\tmp\blah
INFO: generating C/C++ file: C:\tmp\blah\Blink.cpp
INFO: error!
INFO: null
INFO: java.lang.NullPointerException
at com.joshondesign.arduino.common.CompileTask.assemble(CompileTask.java:129)
at com.joshondesign.arduinox.Actions$2$1.run(Actions.java:73)
at java.lang.Thread.run(Unknown Source)
Turns out C:\tmp\blah\Blink.cpp does not exist, at least not after the event but it may have been cleaned up.
I just repeated the exercise and the first line is now
Code: [Select]
INFO: assembling sketch in directory: C:\ArduinoX\win
A different folder to the last time.
Also it doesn't remember the window location and size and ^A doesn't highlight all the text even though the menu option does. I assume the "Meta" key is not set for Windows? ^C and ^V work.
_____
Rob
Rob Gray aka the GRAYnomad www.robgray.com
UnaClocker
Downloading it now. I'm trying out the Mac version. I'll give it a try for a few days and report back. Thanks for taking the time to do this. :)
joshmarinacci
Thank you for the feedback. That's the only way it will get better.
The clone button on the examples panel didn't work. I just implemented the code and pushed out a commit. In the newest build should work now. Press the clone button to open up a new instance of that example sketch.  Eventually I'd like to make the example search be full text, including the example source, but for now it's just the description and tags.
Regarding the compile error, can you tell me more?  Does c:\tmp not exist on your computer? I may need to find a different way of calculating the temp directories that is cross platform.
The window settings are stored per sketch. If it's not remembering them then it's because it's not saving the settings for some reason.  Can you send me some console logs?
The keystrokes are hard coded right now for the Mac.  ^C and ^V work only because they are built into Java. I will to create a new set for Windows.  Since I'm not a regular Windows user I could use some suggestions on what you would like.
Thanks!
- Josh
It fails to compile
Code: [Select]
INFO: error!
INFO: null
Code: [Select]
_____
Rob
joshmarinacci
BTW. I just added colorized output to the compiler console. Now you should see info and warnings in different colors and weights from compiler output and errors.
graynomad
Quote
The folder exists and has a subfolder names "blah" but no files.
Quote
LIke this you mean?
Code: [Select]
ResourceManager resource configuration:
- Resource category: JAVA
- Current directory: C:\ArduinoX\win\
- Property count: 18
- Property:  =<>
- Property: arguments=<>
- Property: bundledvm=<jre>
- Property: classpath=<lib\ArduinoX.jar;lib\RXTXcomm.jar;lib\arduinocompile.jar
;lib\jsyntaxpane-0.9.6.jar;lib\swing-layout-1.0.4.jar;lib\XMLLib.jar>
- Property: currentdir=<${EXECUTABLEPATH}>
- Property: embedjar=<false>
- Property: javapropertiescount=<1>
- Property: javaproperty_name_0=<java.library.path>
- Property: javaproperty_value_0=<./lib>
- Property: jvmsearch=<bundled>
- Property: mainclassname=<com.joshondesign.arduinox.Start>
- Property: maxversion=<>
- Property: minversion=<1.6>
- Property: skel_Debug=<1>
- Property: skel_JniSmooth=<0>
- Property: skel_PressKey=<1>
- Property: skel_SingleInstance=<0>
- Property: skel_SingleProcess=<1>
Main class: com.joshondesign.arduinox.Start
Currentdir: C:\ArduinoX\win
Now searching the JVM installed on the system...
JVM Lookup: found VM (V(1)(6)(0)) in registry.
JVM Lookup: Env-Var JAVA_HOME not defined on this system.
JVM Lookup: Env-Var JRE_HOME not defined on this system.
JVM Lookup: Env-Var JDK_HOME not defined on this system.
Found a vm bundled with the application: (jre)
Current directory is C:\ArduinoX\win\
Running now <C:\ArduinoX\win\jre><><0.0.0>, instanciate=no
Launching <C:\ArduinoX\win\jre><><0.0.0>
RuntimeLibPath used: C:\ArduinoX\win\jre\bin\client\jvm.dll
No version, trying with 1.6.0
Saving jnismoothjar in C:\Users\Rob\AppData\Local\Temp\temp4.jar
Created temporary filename to hold the jar (C:\Users\Rob\AppData\Local\Temp\temp
4.jar)
ClassPath element is C:\ArduinoX\win\ + lib\ArduinoX.jar
ClassPath element 0=C:\ArduinoX\win\lib\ArduinoX.jar
ClassPath element is C:\ArduinoX\win\ + lib\RXTXcomm.jar
ClassPath element 1=C:\ArduinoX\win\lib\RXTXcomm.jar
ClassPath element is C:\ArduinoX\win\ + lib\arduinocompile.jar
ClassPath element 2=C:\ArduinoX\win\lib\arduinocompile.jar
ClassPath element is C:\ArduinoX\win\ + lib\jsyntaxpane-0.9.6.jar
ClassPath element 3=C:\ArduinoX\win\lib\jsyntaxpane-0.9.6.jar
ClassPath element is C:\ArduinoX\win\ + lib\swing-layout-1.0.4.jar
ClassPath element 4=C:\ArduinoX\win\lib\swing-layout-1.0.4.jar
ClassPath element is C:\ArduinoX\win\ + lib\XMLLib.jar
ClassPath element 5=C:\ArduinoX\win\lib\XMLLib.jar
VM Created successfully
DLL Setup on 1.6.0
Classpath: -Djava.class.path=C:\Users\Rob\AppData\Local\Temp\temp4.jar;C:\Arduin
oX\win\lib\ArduinoX.jar;C:\ArduinoX\win\lib\RXTXcomm.jar;C:\ArduinoX\win\lib\ard
uinocompile.jar;C:\ArduinoX\win\lib\jsyntaxpane-0.9.6.jar;C:\ArduinoX\win\lib\sw
ing-layout-1.0.4.jar;C:\ArduinoX\win\lib\XMLLib.jar;
Option added:-Djava.library.path=./lib
VM 1.2+ Created successfully !!
Looking up for class <jsmooth/Native>
Result code on DLL: 1
Looking up for class <com/joshondesign/arduinox/Start>
Looking up for class <java/lang/String>
Invoke Static main ([Ljava/lang/String;)V
the toolchain path = null
WARNING:  RXTX Version mismatch
        Jar version = RXTX-2.2pre1
        native lib Version = RXTX-2.2pre2
resources dir = C:\ArduinoX\win\resources
parsing: C:\ArduinoX\win\resources\hardware\boards\diecimila.xml
parsing: C:\ArduinoX\win\resources\hardware\boards\mega2560.xml
parsing: C:\ArduinoX\win\resources\hardware\boards\uno.xml
basedir = C:\ArduinoX\win\resources\examples
Loaded settings: 3
Nov 20, 2012 10:50:08 PM jsyntaxpane.DefaultSyntaxKit loadConfig
INFO: unable to load configuration for: class jsyntaxpane.syntaxkits.CSyntaxKit
from: jsyntaxpane/syntaxkits/CSyntaxKit/config.properties
installing font: java.awt.Font[family=Courier New,name=Courier New,style=plain,s
ize=12]
prop = componentPopupMenu
prop = document
preferred size = 26.0
prop = editorKit
prop = background
prop = caretColor
prop = selectionColor
ize=12]
prop = font
preferred size = 28.0
prop = font
prop = ancestor
prop = ancestor
saved settings to : C:\settings.properties
serial port = COM11
serial port = COM11
This is from an invocation after using the app with a maximised window. It came up at the standard small size.
______
Rob
rexlee
Thought I would try this as I need some functionality which I cannot get with standard IDE. (Win 7/64 bit & Arduino UNO)
Getting quite a few compile warnings  regarding HardwareSerial.  Does not stop the sketch running though!
I really need to be able to "cut" from the Serial terminal output, for debugging/documentation purpose.
Unfortunatily,  ArduinoX does not do that at this time!  Will it be able to in the future?
I will keep an eye on this development, as the standard IDE is not all that good!
avenue33
I tried to compile and get the following error message:
Quote
-do-compile:
    [javac] Compiling 21 source files to /Users/reivilo/Downloads/arduinox-master/build/classes
    [javac] javac: invalid target release: 1.7
    [javac] Usage: javac <options> <source files>
    [javac] use -help for a list of possible options
There was another nice project called Cocoduino (forum, GitHub).
Are you using the same approach based on ino (website, GitHub)?
You can even use Xcode, the excellent and free IDE provided with every Mac. Check the embedXcode project (website, download, forum!
joshmarinacci
You must have Java 7 installed to compile it. I've switched to Java 7 because it's identical across all platforms now that the builds are provided directly by Oracle/Sun instead of Apple.
If you just want to try it out, download the pre-built version here:
http://hudson.joshy.org:9001/job/ArduinoX/lastSuccessfulBuild/artifact/dist/
Quote
-do-compile:
joshmarinacci
I've put up a new build here:
This improves compiler output and now uses a proper temp directory. Does this fix the issue?
- J
Quote
Quote
LIke this you mean?
Code: [Select]
- Property:  =<>
4.jar)
DLL Setup on 1.6.0
Loaded settings: 3
ize=12]
prop = document
prop = editorKit
prop = background
prop = caretColor
ize=12]
prop = font
prop = font
prop = ancestor
prop = ancestor
serial port = COM11
serial port = COM11
______
Rob
avenue33
Quote
Thank you!
