Loading...
Pages: [1] 2 3   Go Down
Author Topic: name lookup of 'i' changed for new ISO 'for' scoping  (Read 1641 times)
Offline Offline
Jr. Member
View Profile
I've written a simple brushless motor testing program, but i'm getting a weird error I've never seen before  smiley-eek-blue!
What does this error mean and how do I fix it? Thanks in advance!
BTW the error happens somewhere in the for loop where 'i' is between 1500 and 1000 I think. The code works fine up till that point.
Code:
#include <LiquidCrystal.h>
#include <Servo.h> //Notice how you can use the standard servo library!
Servo bldc_motor; //creates a "servo" object (the ESC and motor)
LiquidCrystal LCD (2, 3, 4, 5, 6, 7); ///create an LCD
  bldc_motor.attach (9); //attach the motor to pin 9
  LCD.begin (16, 2); //initialise the LCD
  LCD.clear();
  bldc_motor.writeMicroseconds(1500); //provides a "neutral" pulse. The ESC won't start without this.
  LCD.print ("BLDC Motor Test");
  LCD.setCursor (0, 1);
  LCD.print ("Starting in ");
  for (int i = 4; i >= 0; i --) //countdown timer
    LCD.setCursor (12, 1);
    LCD.print (i+1);
    LCD.print ("s");
    delay (1000);
  LCD.print ("                "); //clears the bottom line of the LCD
  LCD.setCursor (5, 1);
  LCD.print ("forward"); //writing it here so it doesn't keep rewriting this in the for loop
  while(1)
    for (int i = 1500; i <= 2000; i++)
      int speed_value = map (i, 1500, 2000, 0, 100); //maps the signal pulse to a percentage
      LCD.print ("   "); //clears any previous number;
      LCD.print (speed_value); //prints the percentage to the LCD
      LCD.print ('%'); //notice the single quotation marks. I've just sent a char value, not a string because it's only 1 character
      bldc_motor.writeMicroseconds (i); //actually write the value to the motor
      delay(10);// small delay so you can see what's happening
    LCD.print ("                "); // clears the bottom of the LCD screen;
    LCD.print ("braking in");
      LCD.print (i+1);
      LCD.print ("s");
      delay (1000);
    bldc_motor.writeMicroseconds (1000); //full reverse. The ESC will automatically brake the motor.
    delay (500); //small delay to let things happen
    bldc_motor.writeMicroseconds (1500); //give a neutral signal
    LCD.print ("motor stopped");
    delay (3000); //keep it that way for a while
    LCD.print ("                "); //clear the bottom line of the LCD
    LCD.print ("backward");
    for (int i = 1500; i >= 1000; i --);
      int speed_value = map (i, 1500, 1000, 0, 100); //maps the signal pulse to a percentage
    LCD.print ("                "); //clear bottom line of LCD
    delay (3000);
Error messages:
sketch_nov03a.cpp: error: In funcion 'void loop()':
sketch_nov03a:77: error: name lookup of 'i' changed for new ISO 'for' scoping
sketch_nov03a:37: error: using obsolete binding at 'i' (what on earth does this mean too?)
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Add a declaration for "i" after loop, eg.
Code:
  int i;
Then remove the multiple declarations of "i" elsewhere, eg.
Change:
Code:
to:
Code:
  for (i = 4; i >= 0; i --) //countdown timer
Effectively it is warning you about multiple redeclarations of "i".
Logged
Online Online
Sr. Member
View Profile
Code:
You've accidentally put a ; after the for line.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
and then referencing i after the end of the for loop, which isn't allowed.
Logged
Offline Offline
Jr. Member
View Profile
Ah, thanks! That stray semicolon really gave me a headache  smiley-roll-sweat
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
Any decent C++ compiler will warn about that stray semicolon, but unfortunately the Arduino IDE turns most of the gcc compiler warnings off.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Well spotted, PaulS!
Older versions of the compiler would allow the "i" declared in the loop to remain in scope, so it would be valid to do this:
Code:
void setup ()
  for (int i = 0; i < 42; i++)
    // whatever
  int j = i;      // <------ now raises an error
  }  // end of setup
void loop ()  {    }  // end of loop
However more recently "i" is scoped to the loop only, and thus the assignment to "j" fails.
Logged
UK
Offline Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
View Profile
WWW
Quote
Why?  That's a perfectly valid thing to do, and I do it often.  Especially when traversing to the end of a linked list:
Code:
for(ptr=head; ptr->next; ptr=ptr->next);
ptr->next = newelement;
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Wouldn't it be easier and faster to keep a pointer to tail?
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Quote
faster?  yes.  easier?  no.
You have to always ensure you update said pointer every time to add something to the tail.  It just takes one moment of forgetfulness when you don't add the tail pointer updating, and you have a rather nasty bug.  Memory-leaks-r-us.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
I'll take your word for it. I've never bothered with singly linked lists. Very little extra memory and effort is required to create doubly linked lists that can then be traversed in either direction. With doubly linked lists, you don't have the luxury of forgetfulness.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Standard Template Library.
Then you don't have to re-invent the wheel every time you want a linked list for a different data type.
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Fine if you want to use C++ I guess.  Not if you either can't or don't want to.
Logged
Online Online
Sr. Member
View Profile
Quote
Code:
Yes but have you ever intentionally written for(LinkedList * ptr=head; ptr->next; ptr=ptr->next); and then immediately followed it with a { ?
As far as I know there is no GCC warning for this kind of mistake anyway.
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Quote
Code:
Can't say as I have, no, however there is no syntactical reason why that would be wrong.
There is nothing to say that a { HAS to follow a for/while/if etc - it can just be on its own.  You can use it to group blocks of code to make it easier to read.  I don't know anyone that actually does that, but it's perfectly valid.
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
