Topic: liquid crystal library (Read 1 time) previous topic - next topic
zarobhr
i was looking at the autoscroll function and tested it out with the example and when autoscrolling was wandering if there is a way to make it only autoscroll 1 line and not all lines
liudr
What display? Which library?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
zarobhr
liquidcrystal libray that comes with arduino 1.01
the display is a CU20025ECPB-U1J VFD which is LCD compatible
liudr
the display is LCD compatible
OK if you say so. HD44780 displays can only auto shift all lines together. There is no scroll. If you shift back, the characters that passed the display boarder are forever gone. Another member asked this question a week ago already:
http://arduino.cc/forum/index.php/topic,128968.0.html
floresta
Quote
Are you sure about that?  When you use the shift instructions that are inherent in the LCD controller nothing gets erased from its RAM.  Therefore when you shift the display back the original characters reappear.  Of course things may be different when using a library.
Don
zarobhr
floresta
#6
Nov 04, 2012, 04:48 am Last Edit: Nov 04, 2012, 04:50 am by floresta Reason: 1
Quote
You really ought to qualify this for the sake of those who read this thread in the future.  As we established toward the end of another thread (http://arduino.cc/forum/index.php/topic,129962.msg978412.html#msg978412) the display appears to use the same instruction set as the HD44780 type LCDs but some timing differences seem to render it partially incompatible.
Don
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
