Topic: arduino gsm door alarm (Read 8553 times) previous topic - next topic
mark7w
So, i have messed around with the code. if I removed the sms block in the original code I dont get any SMS. So I have cut the code right down to this.
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial module(2,3);  // We need to create a serial port on D2/D3 to talk to the GSM module
char mobilenumber[] = "07xxxxxxxx4";  // Replace xxxxxxxx with the recipient's mobile number
int doorContactPin = 4; // pin door contact is attached to
// NEW CODE
unsigned long doorOpenTime = 0;
unsigned long doorClosTime = 0;
unsigned long time_threshold = 10000; //time in ms => 10 sec.
int currDoorState;
int prevDoorState = LOW; // Assumes that LOW means closed and that the door is closed when the Arduino starts
  module.begin(9600); //Initialize serial ports for communication.
  delay(35000); // give the GSM module time to initialise, locate network etc.
  pinMode(doorContactPin,INPUT);
  digitalWrite(doorContactPin,LOW);
void sendSMS()
  //send sms message
  module.println("AT+CMGF=1"); // set SMS mode to text
  module.print("AT+CMGS=");  // now send message...
  module.write(34); // ASCII equivalent of "
  module.print(mobilenumber);
  module.println();
  delay(500); // give the module some thinking time
  module.println("Door Open Alert");   // our message to send
  module.write(26);  // ASCII equivalent of Ctrl-Z
  delay(5000); // the SMS module needs time to return to OK status
  // ----------------------time delay before SMS is sent--------------------------
  // telling millis not to start if prevDoorState == LOW
  millis() == 0;
  while((prevDoorState == LOW)&&(millis() < time_threshold)){
    delay(100);// debounce
  // if millis is longer than time_threshold, read the state of doorcontactpin and change currdoorstate should be HIGH
  if (millis() >= time_threshold){
    digitalRead(doorContactPin);
  //---------------------new code -------------------------------------------------------------
  currDoorState = digitalRead(doorContactPin);
  if(currDoorState != prevDoorState)
    // Door was closed and is now open or door was open and is now closed
    if(currDoorState == LOW)
      // Door is now closed
      doorClosTime = millis();
      // Door is now open
      doorOpenTime = millis();
  prevDoorState = currDoorState;
  //---------------------------- commented out incase re-use later---------------------------
  // Now see if the door was opened
  //if(doorOpenTime > 0);
  // It was. Was it closed?
  //  if(doorClosTime > 0);
  //Yes. How far apart?
  //   if(doorClosTime - doorOpenTime >= time_threshold)
  //    sendSMS();
  //    doorOpenTime = 0;
  //    doorClosTime = 0;
  //  else
  // Door is still open. How long has it been open?
  if(millis() - doorOpenTime >= time_threshold)
    sendSMS();
    doorOpenTime = 0;
    //doorClosTime = 0;
  //} commented out
  //} commented out
now I get SMS before the door is open..
So, I also load this code but dont get the delay from the time-threshold 10 sec. but do gey sms continuously
Code: [Select]
// NEW CODE
int currDoorState;
void sendSMS()
  //send sms message
  module.println();
  //new code
      // Door is now open
        sendSMS();
        doorOpenTime = 0;
        doorClosTime = 0;
        sendSMS();
        doorOpenTime = 0;
        doorClosTime = 0;
no matter what I do or Read about. I just cant get this to do what i want.
1. open door
2. if after X seconds unit has not been turned of (one) SMS is sent.
3. if door closes and opens again
4. after X seconds (one) SMS is sent. etc
thanks again in advance :smiley-sad-blue:
wildbill
Try this:
Code: [Select]
static bool DoorIsClosed=true; // Let's assume it's closed for starting
static bool SMSSent=false;     // Tells us whether we've sent an SMS for the latest instance of the door being open
if(currDoorState != prevDoorState)   // Door was closed and is now open or door was open and is now closed
    DoorIsClosed=true;
    // Door is now open
    DoorIsClosed=false;
  SMSSent=false; // Door state changed, we may have a new opportunity to send SMS
// Now see if the door is open
if(!DoorIsClosed)
    sendSMS();
    SMSSent=true;
Not tested, not even compiled.
mark7w
Thanks, I have added your code to my Sketch. As with other codes, I get the SMS but I get more than one SMS. As long as the door is open I will get SMS every X seconds.
Heres my code
Code: [Select]
int currDoorState;
int prevDoorState; // Assumes that LOW means closed and that the door is closed when the Arduino starts
void sendSMS()
  module.println();
  module.println("Unit Door Open");   // our message to send
  delay(15000); // the SMS module needs time to return to OK status
  int currDoorState = digitalRead(doorContactPin);
      DoorIsClosed=true;
      // Door is now open
      DoorIsClosed=false;
  if(!DoorIsClosed)
      sendSMS();
      SMSSent=true;
I have a basic set up comprising, 1 x reed switch connected to Pin 4 with other wire end going to GND. My GSM module is on Pins 2 and 3. The reed switch is closed when the magnet is close by and open when the magnet removed. hope this helps alittle.
wildbill
oops. Never checked SMSsent. Is this better?
Code: [Select]
if(!DoorIsClosed && !SMSSent)
Ashton
Mark
Have you accomplished your objectives in this project?
Quote
1. open door
vinman1000
I took this thread and got it working. I do not have a GSM shield so replaced the SMS code with a simple LED connected to pin 8. Now when the door is opened longer than 10 seconds the LED will blink once. If the door is closed and then reopened the LED will blink again after 10 seconds.
Code: [Select]
int doorContactPin = 2; // pin door contact is attached to
int ledPin = 8; // led connected to pin 8 thru resistor to gnd
int prevDoorState = digitalRead(doorContactPin); // Assumes that LOW means closed and door is closed when the Arduino starts
boolean DoorIsClosed=true; // Let's assume it's closed for starting
boolean SMSSent=false;     // Tells us whether we've sent an SMS for the latest instance of the door being open
pinMode(ledPin, OUTPUT);
//next function was for sending an SMS but I didn't have one so replaced the code with a simple LED on/off
void sendSMS()
digitalWrite(ledPin,HIGH);
digitalWrite(ledPin,LOW);
    DoorIsClosed=true;
    // Door is now open
    DoorIsClosed=false;
//    digitalWrite(ledPin,HIGH);
//    delay(500);
//    digitalWrite(ledPin,LOW);
    sendSMS();
    SMSSent=true;
