Topic: My SD card is being corrupted. (Read 966 times) previous topic - next topic
spierepf
Greetings,
I'm using WaveShare's Micro SD storage board, and the SD library, and something appears to be corrupting my SD card.
After formatting the card on my laptop, and running the CardInfo sketch, I get:
Initializing SD card...Wiring is correct and a card is present.
Card type: SD2
Volume type is FAT32
Volume size (bytes): 1967448064
Volume size (Kbytes): 1921336
Volume size (Mbytes): 1876
Files found on the card (name, date and size in bytes):
Then I run the ReadWrite sketch and get:
Initializing SD card...initialization done.
Writing to test.txt...done.
test.txt:
which appears to have written nothing to test.txt
But if I run CardInfo again I get:
Card type: SD2
TEST.TXT      1998-02-02 16:00:00 66052
The @. above is actually followed by a great deal of gobbeldygook that I am unable to cut and paste here.
Has anyone experienced anything similar?
Peter.
SurferTim
#1
Nov 21, 2012, 02:38 pm Last Edit: Nov 21, 2012, 03:29 pm by SurferTim Reason: 1
How are you powering the card? If you are using the 3.3v pin on the Arduino, that may not provide enough current for a read/write. According to the hardware datasheet, that pin is limited to 50ma, and the card could use more than that when writing. That could take 60-100ma, depending on the card.
edit: If you do not have a 3.3v regulated power supply, try powering the SD card with 2 new AA batteries in series. Keep the ground connected to the Arduino. That should provide enough voltage and current to test the theory about the power supply.
Zack_Johnston
Make sure to keep it connected to ground. Secure your connections, too.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
