Topic: max6675+ethernet+sd card (Read 15911 times) previous topic - next topic
jmaxado
Hello
I am trying to combine all these devices with no luck.
I know because all of them use the spi that I have to enable/disable each one to get the other one working.
But so far I dont get any luck.
I have the program running until I use the ethernet to write data to an mysql server. It jams...
Before i use the max6675 library I disable pin 53 on mega, to disable ethernet, and then enable it again after reading.
Is this right ?
I read somewhere that to use hte sd card library I have to disable the ethernet chip.
But so far I didn't understand how do I do it....
Another thing I noticed is that if I use array to store my data the program keeps haging.
I am using arduino mega+oficial ethernet shield+max6675 I set up.
Can someone help me understand why my program hangs ?
Any help would be great.
Thanks
José
From Portugal.
PaulS
Quote
Can anyone but you see your code?
jmaxado
Please keep in mind that I am still a bbeginner. So my programing skill are not the best.
That is why I didnt posted the code in the first post because I am afraid you are not able to follow it.
So if you have any questions please ask.
here you have the main code:
Code: [Select]
#include <OneWire.h>
#include <SPI.h>
#include <Ethernet.h>
#include <DHT.h>
#include "max6675.h"
#define DHTPIN 23     // what pin we're connected to
#define DHTTYPE DHT22   // DHT 22  (AM2302)
DHT dht(DHTPIN, DHTTYPE);
int thermoDO = 31;
int thermoCS = 26;
int thermoCLK = 29;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO); // Inicialization of the MAX6675 board used for the thermocouple of the Caldeira
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
EthernetServer server(80);
OneWire  ds22(22);  // on pin 22 Sensor colocado no anexo
OneWire  ds24(24);  // on pin 24 sensor colocado junto ao quadro electrico
OneWire  ds27(27);  // on pin 27 sensor colocado na cozinha por cima do armário
OneWire  ds25(25);  // on pin 25 sensor colocado na sala por cima da televisão
OneWire  ds30(30);   // on pin 30 2 sensores colocados um no tubo de entrada da caldeira e outro no tubo de saida
byte sensor1[8] = {
  0x28, 0xF0, 0xA9, 0xA5, 0x03, 0x00, 0x00, 0x60};
byte sensor2[8]= {
  0x28, 0x6, 0x9F, 0xA5, 0x03, 0x00, 0x00, 0xB8};
byte sensor3[8]= {
  0x28, 0x3D, 0xB4, 0xA5, 0x03, 0x00, 0x00, 0x25};
byte sensor4[8]= {
  0x28, 0xDD, 0xC2, 0xA5, 0x03, 0x00, 0x00, 0xFD};
byte sensor5[8]= {
  0x10, 0x54, 0xF0, 0x3B, 0x02, 0x08, 0x00, 0x4A}; //Sensor colocado no tubo de entrada de água para a caldeira
byte sensor6[8]= {
  0x10, 0x8D, 0xE9, 0x3B, 0x02, 0x08, 0x00, 0x97}; //Sensor colocado no tubo de saida de água para a caldeira
int count=0;
int count2=0;
double sumlight;
double avrlight;
double sumtext;
double avrtext;
double sumhum1;
double avrhum1;
double sumtanex;
double sumtcor;
double avrtanex;
double avrtcor;
double avrtcoz;
double sumtcoz;
double avrtsal;
double sumtsal;
double avrcaldin;
double sumcaldin;
double avrcaldout;
double sumcaldout;
double avrcaldeira;
double sumcaldeira;
void setup(void) {
  // start the serial library:
  pinMode(10, OUTPUT);
  dht.begin();
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)
  // print your local IP address:
  Serial.print("My IP address: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.print(Ethernet.localIP()[thisByte], DEC);
    Serial.print(".");
  server.begin();
void loop(void) {
  int i=0;
  double temparray[6];
  String namearray[9];
  float dataarray[9];
  float sumarray[9];
  float avrarray[9];
  namearray[0]="Exterior";
  namearray[1]="Humidade";
  namearray[2]="Luminusidade";
  namearray[3]="Anexo";
  namearray[4]="Corredor";
  namearray[5]="Cozinha";
  namearray[6]="Sala";
  namearray[7]="Caldeira";
  namearray[8]="Entrada";
  namearray[9]="Saida";
  dataarray[0]=dht.readTemperature();
  dataarray[1]=dht.readHumidity();
  dataarray[2]=analogRead(A0);
  dataarray[3]=getTemperature(22,sensor1);
  dataarray[4]=getTemperature(24,sensor2);
  dataarray[5]=getTemperature(27,sensor3);
  dataarray[6]=getTemperature(25,sensor4);
  dataarray[7]=thermocouple.readCelsius();
  dataarray[8]=getTemperature(30,sensor5);
  dataarray[9]=getTemperature(30,sensor6);
  count++;
  count2++;
  for (byte i=0;i<9;i++){
    sumarray[i]=sumarray[i]+dataarray[i];
    avrarray[i]=sumarray[i]/count2;
  Serial.print("Temp Exterior=");
  Serial.println(dataarray[0]);
  Serial.print("Humidade=");
  Serial.println(dataarray[1]);
  Serial.print("Luz=");
  Serial.println(dataarray[2]);
  Serial.print("Temp Anexo=");
  Serial.println(dataarray[3]);
  Serial.print("Temp Corredor=");
  Serial.println(dataarray[4]);
  Serial.print("Temp Cozinha=");
  Serial.println(dataarray[5]);
  Serial.print("Temp Sala=");
  Serial.println(dataarray[6]);
  Serial.print("Temp caldeira in=");
  Serial.println(dataarray[8]);
  Serial.print("Temp caldeira out=");
  Serial.println(dataarray[9]);
  Serial.print("Temp caldeira=");
  Serial.println(dataarray[7]);
    Serial.println(sumarray[i]);
    Serial.println(avrarray[i]);
  Serial.print(" Numero medicoes: ");
  Serial.println(count);
  Serial.println(count2);
  if (count2==60) {
    Serial.print(" Count2=60. Connecting .... ");
    temparray[0]=dataarray[0];
    temparray[1]=dataarray[1];
    temparray[2]=dataarray[2];
    temparray[3]=dataarray[3];
    temparray[4]=dataarray[4];
    temparray[5]=dataarray[5];
    temparray[6]=dataarray[6];
    escreve(temparray); // chama a função para escrever dados na BD do servidor domotica
      sumarray[i]=0;
      avrarray[i]=0;
    count2=0;
  delay (5000);
I will make another post with the code for the functions.
Please help me...
José
jmaxado
Here you can see the code I have for the functions that are in a separed tab
Code: [Select]
//Temperatura
float getTemperature(int porta, byte* address){
double celsius;
  byte data[12];
  byte present = 0;
   byte type_s;
  switch (address[0]) {
    case 0x10:
      type_s = 1;
    case 0x28:
      type_s = 0;
    case 0x22:
     type_s = 0;
   switch(porta){
      case 22:
  //reset the bus
         ds22.reset();
  //select our sensor
         ds22.select(address);
  //CONVERT T function call (44h) which puts the temperature into the scratchpad
         ds22.write(0x44,1);
  //reset the bus
         present=ds22.reset();
  //select our sensor
  //read the scratchpad (BEh)
          ds22.write(0xBE);
              data[i] = ds22.read();
            case 24:
  //reset the bus
         ds24.reset();
  //select our sensor
         ds24.select(address);
         ds24.write(0x44,1);
  //reset the bus
          present=ds24.reset();
  //select our sensor
          ds24.write(0xBE);
              data[i] = ds24.read();
                  case 27:
  //reset the bus
         ds27.reset();
  //select our sensor
         ds27.select(address);
         ds27.write(0x44,1);
  //reset the bus
          present=ds27.reset();
  //select our sensor
          ds27.write(0xBE);
              data[i] = ds27.read();
      case 25:
  //reset the bus
         ds25.reset();
  //select our sensor
         ds25.select(address);
         ds25.write(0x44,1);
  //reset the bus
          present=ds25.reset();
  //select our sensor
          ds25.write(0xBE);
              data[i] = ds25.read();
            case 30:
  //reset the bus
         ds30.reset();
  //select our sensor
         ds30.select(address);
         ds30.write(0x44,1);
  //reset the bus
         present=ds30.reset();
  //select our sensor
          ds30.write(0xBE);
              data[i] = ds30.read();
unsigned int raw = (data[1] << 8) | data[0];
   if (type_s) {
    raw = raw << 3; // 9 bit resolution default
    if (data[7] == 0x10) {
      // count remain gives full 12 bit resolution
      raw = (raw & 0xFFF0) + 12 - data[6];
    unsigned char t_mask[4] = {0x7, 0x3, 0x1, 0x0};
    byte cfg = (data[4] & 0x60) >> 5;
    raw &= ~t_mask[cfg];
  celsius = (float)raw / 16.0;
return celsius;}
//Escever dados na base de dados
void escreve(double temparray[5]){
  int i;
if (client.connect("192.168.1.15", 80)) {
    Serial.println("connecting...");}
  client.print("GET /arduino.php?");
  Serial.print("GET /arduino.php?");
  for (i=0; i<7; i++)
    client.print("t");
    Serial.print("t");
    client.print(i);
    Serial.print(i);
    client.print("=");
    Serial.print("=");
    client.print(temparray[i]);
    Serial.print(temparray[i]);
    if (i < 7-1)
      client.print("&&");
      Serial.print("&&");
  client.println(" HTTP/1.1");
  Serial.println(" HTTP/1.1");
  client.println("Host: 192.168.1.15");
  Serial.println("Host: 192.168.1.15");
  client.println("User-Agent: Arduino");
  Serial.println("User-Agent: Arduino");
  client.println("Accept: text/html");
  Serial.println("Accept: text/html");
  client.println("Connection: close");
  Serial.println("Connection: close");
  client.println();
  delay(500);                                                //
  while (client.connected() && client.available()) {          // when connected and availabe:
    char c = client.read();                                    // read the answer of the server and
    Serial.print(c);                                            // print it to serial port
  Serial.println();                                            //
  client.stop();                                              //  stop the connection and set
Again any help will be apreciated.
José
PaulS
Code: [Select]
 float dataarray[9];
 float sumarray[9];
 float avrarray[9];
Is there some reason to delete and recreate these every pass through loop?
Have you some reason for needing to wrap the char array data in a resource intensive class?
Code: [Select]
Why do you need to make a copy of this data before passing it to a function? You should simply write the function so it doesn't mangle the input data.
Your indenting
         makes your code very
   hard to read. Use the Tools
                                 + Auto Format menut
      item to indent consistently.
Code: [Select]
<snip>
Why pass a 7 element array to a function that expects a 5 element array?
Why store 7 elements in a 6 element array?
Code: [Select]
 for (i=0; i<7; i++)
Why use 7 elements of a 5 element array?
Code: [Select]
You never use anything, that I can see, from this file. Why include it?
jmaxado
Hello Paul
First of all thank you for all your help and comments.
Like I said I knew my code was not ok, that's why I didn't posted at the beginning.
I will go trough your comments.
The first one , do you suggest doing this in another way ? I thought that array's were a good thing, or is it because its a string array ?
Second, the idea is to pass the avrarray, but I am trying to fix my problem and then go and optimize the code.
What do you mean by using tools+auto format menu ?
The indexes of the arrays will be correct after I solve my problem.
Regarding the
Code: [Select]
#include "max6675.h" this is the library for the MAX6675.
My major problem is the combination of multiple SPI devices and the way to disable one in order to use the other.
THanks
José
PaulS
Quote
I'd suggest making them global arrays, and using char * instead of String.
Quote
Making sure that the declared array size is appropriate for the data that you want to store in it, and making sure that the function knows the correct size of the array is NOT optimization that can be put off until later.
Quote
Exactly what I said. There is a Tools menu. Look for it. I'm sure you've used it before. There is an item on that menu, Auto Format. Use it. Regularly until you get in the habit of properly indenting code as you go.
Quote
If you deliberately leave mistakes in you code, don't expect us to keep trying to help you.
Quote
Regarding the...this is the library for the MAX6675.
That you are not using in the code.
What slave select pin are you going to use for the device? What does the device do? Do you know how to communicate with the device?
Looking at the SD library or the Ethernet library, to see how they manage to activate the correct SPI device would be useful. That there is a library to communicate with your device gives hope that that library also knows how to activate the correct SPI device.
Without doing anything explicit to choose the device, what problems are you having?
jmaxado
Yes I know I have mistakes, but for now I want to  figure out how to call the devices.
The
Code: [Select]
dataarray[7]=thermocouple.readCelsius(); uses the max6675 library.
My problem is that the program hangs randomly,
Its running fine until it simply stops, when I use the Ethernet shield it always stops.
I believe it has to do with the fact that both the Ethernet shield and the max6675 works on the SPI bus and when I am using one of them I am not calling the functions on the correct manner.
Meaning that I should use the slave pin as an input when I call the functions in order to the device to be activated.
Was I clear enough ?
Thanks
José
SurferTim
#8
Nov 05, 2012, 02:13 pm Last Edit: Nov 05, 2012, 02:22 pm by SurferTim Reason: 1
How is the max6675 slave select connected to the Mega?
The w5100 uses digital pin 10 for the slave select.
The SD uses digital pin 4 for the slave select.
The max6675 uses what pin for the slave select?
edit: It may be better to explain exactly how the max6675 SPI interface is connected to the Arduino, not just the slave select.
jmaxado
The Max31855 is newer than the Max6675, but I had the max6675 already in house.
Adafruit has a nice tutorial how to use the Max6675/Max31855
http://learn.adafruit.com/thermocouple/using-a-thermocouple
Basically you have besides the vcc and the grd pins, the following connections:
    CLK (clock) is an input to the MAX6675/MAX31855 (output from microcontroller) which indicates when to present another bit of data
    DO (data out) is an output from the MAX6675/MAX31855 (input to the microcontroller) which carries each bit of data
    CS (chip select) is an input to the MAX6675/MAX31855 (output from the microcontroller) which tells the chip when its time to read the thermocouple and output more data.
For example, how do use the SD card together with the ethernet part ?
Do I have to put the pin 4 high in order to use the sd card ?
After reading the card, do I have to put it low in order for the Ethernet to work ? Or can I simply move forward and leave the pin 4 high ?
José
SurferTim
Quote
I know all that. I want to know where they are connected on the Arduino. Fill out the form:
CLK = digital pin ___
D0 = digital pin ___
CS = digital pin ___
If you give me that, I can give you a setup function that will get them all working together.
jmaxado
Sorry I didn't understand your question at first.
Here are the pin connections.
Code: [Select]
int thermoDO = 31;
int thermoCS = 26;
int thermoCLK = 29;
Please keep in mind that I am using arduino mega.
Thanks
José
SurferTim
I use a Mega also. That is what I was counting on.
I do not understand why that library does not use the hardware SPI bus. It uses the standard mode 0 configuration. It seems easy enough to set the interface.
Are you willing to experiment? If so, do you have other devices connected to other pins? I am planning on using digital pin 9 as the slave select pin for the max. Is anything on that pin?
Here is the plan:
CLK = digital pin 52 (SCK)
DO = digital pin 50 (MISO)
CS = digital pin 9
I'm not going to use their library, and go directly to the IC itself. Is that ok with you? You can always change it back if you don't like the results.  ;)
jmaxado
Thanks
Yes I am willing to try anything.
So you think the Mac6675 is not using the SPI bus ?
Should I look for a diferent library ? One that uses the SPI ?
Why use the digital 9 ? Why not the 49 for example to keep the wires together ?
Thanks
José
SurferTim
#14
Nov 05, 2012, 04:30 pm Last Edit: Nov 05, 2012, 04:39 pm by SurferTim Reason: 1
OK! Digital pin 49 is the slave select for the max. The others should be connected as above.
Try this code to start. This will check that the SD and w5100 are starting ok with the max connected.
Code: [Select]
#include <SPI.h>
#include <SD.h>
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
 // disable w5100 SPI
 pinMode(10,OUTPUT);
 digitalWrite(10,HIGH);
 // disable max6675
 pinMode(49,OUTPUT);
 digitalWrite(49,HIGH);
 Serial.print("Starting SD..");
 if(!SD.begin(4)) Serial.println("fail");
 else Serial.println("ok");
 Serial.print("Starting w5100..");
 if(!Ethernet.begin(mac)) Serial.println("failed");
 else Serial.println(Ethernet.localIP());
  // the w5100 begin function returns with the SPI enabled, so disable it
 Serial.println("Setup complete");
The SD.begin(4) function will fail if no card in the slot.
Do those two devices start ok?
edit: My web browser is double posting copy and paste again. I removed the additional code. ??
