Loading...
Pages: [1]   Go Down
Author Topic: How to modify "sweep" code for straight line drive  (Read 723 times)
Offline Offline
Newbie
View Profile
My overall goal is to use an arduino uno to control a servo to rotate continuously in order to drive my robot in a straight line. First of all, when I use the regular, unedited Sweep code with my servo, it rotates one nearly full rotation, stops, then rotates again in the same direction. It should be rotating back and forth, not in one direction. However, I only need to go in one direction anyways, so I don't necessarily care to know how to fix this.
My main problem is the motor stopping. I tried taking the delay out, or setting it to 0, and it still did not rotate continuously. How can I modify this code, or is there any other code out there that I could use to make my servo rotate continuously without stopping?
The "servo" I'm using is actually a Vex 2 wire motor with a 3 wire motor controller 29. The motor controller 29 is supposed to make it able to be programmed as if it were a servo. It's actually a dc gear motor. This motor is made specifically to drive robots, so I assume I shouldn't have to take any sort of mechanical stop out of it like I've seen in some continuous drive servo guides.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
This requires modified servos. What kind do you have?
Quote
Why are you running code for regular servos with your modified servos?
Quote
So, don't tell it to stop. Continuous rotation servos (which really aren't servos) are driven using the writeMicroseconds() method, not the write() method. The values range from somewhere around 600 for maximum speed in one direction to around 2400 for maximum speed in the other direction. In between, the values result in slower speeds, until some value (or small range of values) causes the "servo" to stop. You'll need to experiment to find the values that represent max speed each way and stopped.
Quote
Isn't there any documentation you can refer to (or link to so we can read)?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Servo test code that might be of use.
Code:
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    int n = readString.toInt();  //convert readString into a number
    // auto select appropriate value, copied from someone elses code.
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
    readString=""; //empty for next input
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Pages: [1]   Go Up
Print
Jump to:
