Topic: Leonardo giving me problems (Read 998 times) previous topic - next topic
StrixA
I just purchased a Leonardo and I'm having issues with it on 7. I plug it in and for about ten seconds it recognizes the device as an Arduino Leonardo under "Other divices". Then it switches to an unknown device under usb controllers. I rush to check the hardware ids before it changes and get
USB\VID_2341&PID_0036&REV_0001
Under unknown device it has no information whatsoever.
When I try updating the drivers windows tells me it already has the best drivers for it.
I've tried the 1.0 and 1.01 ide's drivers and none work. Could it be a bootloader issue?
I also have a duemilanove that works fine.
Thanks in advance,
Strix
spcomputing
Yeah, the Leonardo is a fussy one.  First thing I can suggest is to try another USB port.  Not all USB ports are made equal when it concerns Windows.
Second is to find a USB hub to test for stability.  I noticed that with my Leonardo, it would hang during the sketch upload.  When I switched to the USB hub, that eliminated that problem.  Also, make sure you have all your Windows 7 updates.
Lastly, try eried's modified IDE.  It is pretty slick with the driver installation.
http://arduino.cc/forum/index.php/topic,118440.0.html
StrixA
Thanks, I'll try the modified IDE. As for USB ports, I tried all of them on two laptops and a desktop all with all x64 win 7 updates. I'll try a hub if the IDE doesn't work but I won't get to check it until Tuesday so if anyone else has troubleshooting suggestions please feel free to post.
