Topic: VGA output (Read 42112 times) previous topic - next topic
stimmer
After working out how to do a timer interrupt I've had a go at making a VGA framebuffer. It is rather low-res at present(160x240) and fuzzy but I hope to be able to improve that. It has 8-bit colour (RRRGGGBB).
I cannot get Eagle to run right now so will have to describe the schematic in text:
Due pin 2 -> VGA pin 13 (HSync)
Due pin 3 -> VGA pin 14 (VSync)
Due pin 25 -> 820R resistor -> VGA pin 3 (blue)
Due pin 26 -> 390R resistor -> VGA pin 3 (blue)
Due pin 27 -> 2k2 resistor -> VGA pin 2 (green)
Due pin 28 -> 1k resistor -> VGA pin 2 (green)
Due pin 14 -> 470R resistor -> VGA pin 2 (green)
Due pin 15 -> 2k2 resistor -> VGA pin 1 (red)
Due pin 29 -> 1k resistor -> VGA pin 1 (red)
Due pin 11 -> 470R resistor -> VGA pin 1(red)
Due pin GND -> VGA pins 5,6,7,8,10
Code: [Select]
inline void digitalWriteDirect(int pin, boolean val){
  if(val) g_APinDescription[pin].pPort -> PIO_SODR = g_APinDescription[pin].ulPin;
  else    g_APinDescription[pin].pPort -> PIO_CODR = g_APinDescription[pin].ulPin;
volatile short line;
byte fb[240][160];
void TC0_Handler()
    long dummy=REG_TC0_SR0;
    if(line < 480){
        int i,j=line>>1;
        for(i=0;i<160;i++) REG_PIOD_ODSR = fb[j][i];
        REG_PIOD_ODSR = 0;
    if(line==490) digitalWriteDirect(3,1);
    if(line==492) digitalWriteDirect(3,0);
    line++; if(line == 525) line=0;
void setup(){
  for(int i=0;i<160;i++)for(int j=0;j<240;j++)fb[j][i]=j+i;
  pinMode(3,OUTPUT);  pinMode(2,OUTPUT);                      // vsync=3 hsync=2
  pinMode(25,OUTPUT); pinMode(26,OUTPUT);                     // blue  (26=msb,25=lsb)
  pinMode(27,OUTPUT); pinMode(28,OUTPUT); pinMode(14,OUTPUT); // green (14=msb,28,27=lsb)
  pinMode(15,OUTPUT); pinMode(29,OUTPUT); pinMode(11,OUTPUT); // red   (11=msb,29,15=lsb)
  REG_PIOD_OWER= 0xff;
  REG_PMC_PCER0= 1<<27;
  REG_PIOB_PDR = 1<<25;
  REG_PIOB_ABSR= 1<<25;
  REG_TC0_WPMR = 0x54494D00;
  REG_TC0_CMR0 = 0b00000000000010011100010000000000;
  REG_TC0_RC0  = 1334;
  REG_TC0_RA0  = 1174;
  REG_TC0_CCR0 = 0b101;
  REG_TC0_IER0 = 0b00010000;
  REG_TC0_IDR0 = 0b11101111;
  NVIC_EnableIRQ(TC0_IRQn);
#include <complex>
using namespace std;
const byte cmap[]={0b00000000,0b11100000,0b11100100,0b11101000,0b11101100,0b11110000,0b11110100,0b11111000,0b11111100,
                   0b11011100,0b10111100,0b10011100,0b01111100,0b01011100,0b00111100,0b00011100,0b00011101,0b00011110,
                   0b00011111,0b00011011,0b00010111,0b00010011,0b00001111,0b00001011,0b00000111,0b00000011,0b00100011,
                   0b01000011,0b01100011,0b10000011,0b10100011,0b11000011,0b11100011,0b11100010,0b11100001,0b11100000,0b00000000};
void loop(){
  for(int i=0;i<160;i++){
    for(int j=0;j<240;j++){
      complex<float> z(0,0),c(i/320.0,(j+240.0)/640.0);
      int n;
      for(n=1;n<sizeof(cmap);n++){
        z=z*z+c;
        if(norm(z)>4.0)break;
      fb[j][i]=cmap[sizeof(cmap)-n];
  for(;;);
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
stimmer
#1
Nov 05, 2012, 02:59 am Last Edit: Nov 05, 2012, 03:41 am by stimmer Reason: 1
I unrolled a loop and now it is 320x240 8) The resolution could go higher but 320x240x8 is 77Kbytes of RAM already.
Code: [Select]
/* Arduino Due VGA-Out v0.2 by stimmer
http://arduino.cc/forum/index.php/topic,130742.0.html */
byte fb[240][320];
#define do20(x) x x x x x x x x x x x x x x x x x x x x
#define do80(x)  do20(x) do20(x) do20(x) do20(x)
#define do320(x) do80(x) do80(x) do80(x) do80(x)
#define MNOP(x) asm volatile (" .rept " #x "\n\t nop \n\t .endr \n\t")
void TC0_Handler()
   if(line < 480){
       byte * p=fb[line>>1];
       MNOP(160);
       do320(REG_PIOD_ODSR = *p++;MNOP(2);)
       REG_PIOD_ODSR = 0;
   if(line==490) digitalWriteDirect(3,1); //or digitalWriteDirect(3,0); to invert vsync
   if(line==492) digitalWriteDirect(3,0); //or digitalWriteDirect(3,1); to invert vsync
void setup(){
 for(int i=0;i<320;i++)for(int j=0;j<240;j++)fb[j][i]=j+i;
//  REG_TC0_CMR0 = 0b00000000000001101100010000000000; // this inverts hsync
 REG_TC0_RC0  = 1334;
 REG_TC0_RA0  = 1174;
#include <complex>
void loop(){
  for(int i=0;i<320;i++){
      complex<float> z(0,0),c((i+180.0)/1280.0,(j+640.0)/1280.0);
      int n;
        z=z*z+c;
  for(;;);
cmaglie
:smiley-surprise:
stimmer, you've got some serious skills here!
nice work!
C
C.
micnossub
it is possible to only display black and white and get a better resolution?
stimmer
640x480 black and white only should be possible. It might even be possible with 2 bit greyscale.
There's a chance 800x600 black and white might work. Anything more than that takes too much memory.
micnossub
#5
Nov 06, 2012, 02:52 am Last Edit: Nov 07, 2012, 12:34 am by micnossub Reason: 1
that would be nice 640x480! but just one bit!
canter
This project can work with arduino uno?
Thanks.
MichaelMeissner
Thanks.
No, the UNO only has enough memory for something like a 120x96 black and white image.
If that is fine, there are two shields that use the TVout library that are supposed to make the job easier:
I have the Video Experimenter, but it is on my to-do pile, and I haven't tried it out yet
JLS1
This is very usefull for me - thanks
Is possible post source code for 640x480 or 800x600 black/white ?
Many thanks
Kamil
http://jlswbs.blogspot.com
cjdelphi
How long before we see a GPU or a graphics card from 1995 get modified to work with due/uno and a VGA monitor? :)
neslekkim
#11
Nov 12, 2012, 08:02 pm Last Edit: Nov 12, 2012, 08:03 pm by neslekkim Reason: 1
why 95?
Someone have done it with stm32 based boards: http://hackaday.com/2012/10/08/stm32-driving-a-pcie-video-card/
and Gameduino produces vga(I think) using an FPGA adapterboard.
and, btw, the Propeller, with its 8 "core's" produces vga for games and such, if one could interface more memory on the Due (wish that could be possible on the next SAM based card) one could have kinda ok graphics.
JLS1
Simple Game of Life example :-)
Code: [Select]
#define GRID_X 100
#define GRID_Y 92
#define MAX_GENERATIONS 250
uint8_t grid[2][GRID_X][GRID_Y];
uint8_t current_grid = 0;
uint8_t generations = 0;
byte fb[240][320];
void TC0_Handler()
    if(line < 480){
        MNOP(160);
        REG_PIOD_ODSR = 0;
void setup(){
  REG_TC0_RC0  = 1334;
  REG_TC0_RA0  = 1174;
  initGrid();
  drawGrid();
void loop(){
  runGrid();
drawGrid();
generations++;
if (generations > MAX_GENERATIONS) {
generations = 0;
initGrid();
void initGrid()
int i, j;
int t;
current_grid = 0;
for (i = 0; i < GRID_X; i++) {
for (j = 0; j < GRID_Y; j++) {
if (rand()%2) {
grid[0][i][j] = 2;
grid[0][i][j] = 0;
void runGrid()
uint8_t x, y;
int count;
uint8_t value = 0;
uint8_t new_grid;
new_grid = 1 - current_grid;
for (y = 0; y < GRID_Y; y++) {
for (x = 0; x < GRID_X; x++) {
count = count_neighbours(x, y);
if (count < 2 || count > 3) { value = 0; }
else if (count == 3) { value = 3; }
else { value = grid[current_grid][x][y]; }
grid[new_grid][x][y] = value;
current_grid = new_grid;
int count_neighbours(int x, int y)
int i, j;
int sx;
int result = 0;
x--;
y--;
for (i = 0; i < 3; i++) {
if (y < 0 || y > (GRID_Y - 1)) { continue; }
for (j = 0; j < 3; j++) {
if (x < 0 || x > (GRID_X - 1)) { continue; }
if (i==1 && j == 1) { x++; continue; }
if (grid[current_grid][x][y]) { result++; }
x++;
y++;
x -= 3;
return result;
void drawGrid()
uint8_t  x,  y;
uint8_t cx, cy;
uint8_t grid_next_colour = 0;
cx = 0;
cy = 0;
cx = 0;
if (grid[1-current_grid][x][y] != grid[current_grid][x][y]) {
  if(grid[current_grid][x][y]) {
    fb[cy][cx]=rand()%255;
    else {
    fb[cy][cx]=0;
cx += 2;
cy += 2;
stimmer
#13
Nov 14, 2012, 11:45 am Last Edit: Nov 14, 2012, 11:48 am by stimmer Reason: 1
Nice work  :D (I accidentally left it running all night, it's still going strong!)
Here's a quick status update for the VGA output project. Basically to get any further with this I need to learn ARM inline assembler, which is what I've been doing. With the code above the output is shimmering slightly and if you look closely some of the pixels are bigger than others. I do have code which solves the wide pixels problem and reduces the shimmering, however it is unreliable (sometimes it doesn't compile, sometimes it compiles but doesn't work, sometimes it works perfectly). I guess I have a little more to learn.
I haven't started on 640x480 1bpp yet but I still think it is viable. I don't know about 800x600 (the pixel rate would be 40Mpixels/sec) but there might be a way...
Finally when reading the datasheet I noticed that the SAM3X has some DMA controllers. I am strongly tempted to evaluate whether I can use them rather than the inline assembler. This is even more to learn (I've never used DMA before) but if it does work it would be a much better solution. It would use much less CPU for one thing  :smiley-mr-green:
JLS1
Simple Wolfram 1D Cellular Automata example :-)
Code: [Select]
/* Wolfram Cellular Automata 1D v1.0 */
byte fb[240][320];
void TC0_Handler()
    if(line < 480){
        MNOP(160);
        REG_PIOD_ODSR = 0;
void setup(){
  REG_TC0_RC0  = 1334;
  REG_TC0_RA0  = 1174;
void loop(){
  int iteration = 240;
  int lenght = 320;
  int row = 0;
  int state[lenght];
  int newstate[lenght];
  int i,j,k;
  int rules[8] = {
  int (rand()%2),
  int (rand()%2),
  int (rand()%2),
  int (rand()%2),
  int (rand()%2),
  int (rand()%2),
  int (rand()%2),
  int (rand()%2)};
  for (i=0;i<lenght;i++) state[i]= int (rand()%2);
   for (i=0;i<iteration;i++) {
      for (j=0;j<lenght;j++)
         newstate[j] = 0;
      for (j=0;j<lenght;j++) {
         k = 4*state[(j-1+lenght)%lenght] + 2*state[j] + state[(j+1)%lenght];
         newstate[j] = rules[k];
        state[j] = newstate[j];
        DisplayState(state,lenght,row);
        row = row + 1;
void DisplayState(int s[],int len, int row)
   int i;
   for (i=0;i<len;i++) {
      if (s[i] == 1){
       fb[row][i]=255;
      else{
       fb[row][i]=0;
