Topic: VGA output (Read 43074 times) previous topic - next topic
JLS1
#15
Nov 19, 2012, 09:30 pm Last Edit: Nov 19, 2012, 09:31 pm by JLS1 Reason: 1
Chua chaotic oscillator example :-)
Code: [Select]
/* Chua Chaotic Oscillator v1.0 */
inline void digitalWriteDirect(int pin, boolean val){
 if(val) g_APinDescription[pin].pPort -> PIO_SODR = g_APinDescription[pin].ulPin;
 else    g_APinDescription[pin].pPort -> PIO_CODR = g_APinDescription[pin].ulPin;
volatile short line;
byte fb[240][320];
#define do20(x) x x x x x x x x x x x x x x x x x x x x
#define do80(x)  do20(x) do20(x) do20(x) do20(x)
#define do320(x) do80(x) do80(x) do80(x) do80(x)
#define MNOP(x) asm volatile (" .rept " #x "\n\t nop \n\t .endr \n\t")
void TC0_Handler()
   long dummy=REG_TC0_SR0;
   if(line < 480){
       byte * p=fb[line>>1];
       MNOP(160);
       do320(REG_PIOD_ODSR = *p++;MNOP(2);)
       REG_PIOD_ODSR = 0;
   if(line==490) digitalWriteDirect(3,1); //or digitalWriteDirect(3,0); to invert vsync
   if(line==492) digitalWriteDirect(3,0); //or digitalWriteDirect(3,1); to invert vsync
   line++; if(line == 525) line=0;
void setup(){
 pinMode(3,OUTPUT);  pinMode(2,OUTPUT);                      // vsync=3 hsync=2
 pinMode(25,OUTPUT); pinMode(26,OUTPUT);                     // blue  (26=msb,25=lsb)
 pinMode(27,OUTPUT); pinMode(28,OUTPUT); pinMode(14,OUTPUT); // green (14=msb,28,27=lsb)
 pinMode(15,OUTPUT); pinMode(29,OUTPUT); pinMode(11,OUTPUT); // red   (11=msb,29,15=lsb)
 REG_PIOD_OWER= 0xff;
 REG_PMC_PCER0= 1<<27;
 REG_PIOB_PDR = 1<<25;
 REG_PIOB_ABSR= 1<<25;
 REG_TC0_WPMR = 0x54494D00;
 REG_TC0_CMR0 = 0b00000000000010011100010000000000;
//  REG_TC0_CMR0 = 0b00000000000001101100010000000000; // this inverts hsync
 REG_TC0_RC0  = 1334;
 REG_TC0_RA0  = 1174;
 REG_TC0_CCR0 = 0b101;
 REG_TC0_IER0 = 0b00010000;
 REG_TC0_IDR0 = 0b11101111;
 NVIC_EnableIRQ(TC0_IRQn);
 float x = 0.5;
 float y = 0.25;
 float z = 0.125;
 float h = 0;
 float dt = 0.005;
 float alpha = 15.6;
 float beta = 28.58;
 float a = -1.14286;
 float b = -0.714286;
void loop(){
 float oldx = x;
 float oldy = y;
 float oldz = z;
 h = (b * x) + (0.5 * (a - b) * (abs(x+1) - abs(x-1)));
 x = oldx + dt * (alpha * (oldy - oldx - h));
 y = oldy + dt * (oldx - oldy + oldz);
 z = oldz + dt * (-beta * oldy);
 fb[120+int(65*4*y)][160+int(65*x)]=255;
http://jlswbs.blogspot.com
stimmer
Nice :-) It looks great in colour too, change the last line to this:
Code: [Select]
  static int c=0;
  fb[120+int(65*4*y)][160+int(65*x)]=(c++)>>12;
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
mbanzi
stimmer do you think your code can be packaged up as a library?
it would make it very simple to make nice graphics apps with the Due
m
stimmer
Yes, but please not just yet. I am still evaluating better ways of generating the VGA signal, which may be more steady and use less CPU. This might mean changing the pins the signal is output on. However I am not likely to change the format of the framebuffer (240x320 array) so any nice demo code people make now should still work and would be easy to use as example code in a library if authors wanted.
There's also some design decisions to make - if it turns out 640x480 works, should it be a separate library or the same one? Being the same library could make code larger and slower, but might allow mode changes at runtime. Also a library would need standard graphics functions (lines, text, bitmaps) - this is different in an 8bpp mode to a 1bpp mode. And whether to support composite output - 320x200 or 240 8-bit greyscale would be possible. I think that a single library would be more easily maintainable.
stimmer
Attached are some screenshots of JLS1's demo programs. Chua oscillator has my modification for colour. Life is Conway's famous 'game' we all know and love.
Cellular automata are explained in Wolfram's 'A New Kind Of Science' chapter 6 - he classifies them into four main types (uniform, structured, random, and complex) and others which are rarer and hard to classify. Attached are two examples, cell2 is complex and cell1 is one that doesn't fit the main types.
JLS1
Mira-Gumowski Fractal nice colour example :-)
Code: [Select]
/* Mira Gumowski Fractal v1.0 */
byte fb[240][320];
void TC0_Handler()
    if(line < 480){
        MNOP(160);
        REG_PIOD_ODSR = 0;
void setup(){
  REG_TC0_RC0  = 1334;
  REG_TC0_RA0  = 1174;
   float a = -0.6624;
   float c = 2*(1-a);
   float x = 14.7176;
   float y = -14.6602;
   float f = 0;
   int xx,yy;
   int cnt = 0;
   int col = 255;
void loop(){
    double oldx = x;
    x = f+1*y;
    f = a*x+c*x*x/(1+x*x);
    y = f-oldx;
    xx = 160+3*x;
    yy = 120+4*y;
    if (cnt == 2000) {
col = rand();
cnt = 0; }
    cnt++;
    if ((xx>=0)&(xx<=319)&(yy>=0)&(yy<=239)) {
  fb[yy][xx]=col; }
JLS1
Hopalong Orbit Fractal example :-)
Code: [Select]
/* Hopalong Orbit Fractal v1.0 */
byte fb[240][320];
void TC0_Handler()
    if(line < 480){
        MNOP(160);
        REG_PIOD_ODSR = 0;
void setup(){
  REG_TC0_RC0  = 1334;
  REG_TC0_RA0  = 1174;
   float a = 0.5;
   float b = -0.6;
   float c = 0.7;
   float x = 1;
   float y = 0;
   int xx,yy;
   int cnt = 0;
   int col = 255;
void loop(){
    double oldx = x;
    double oldy = y;
    x = oldy-(oldx/abs(oldx))*sqrt(abs(b*oldx-c));
    y = a-oldx;
    xx = 160+8*x;
    yy = 120+8*y;
    if (cnt == 2000) {
col = rand();
cnt = 0; }
    cnt++;
  fb[yy][xx]=col; }
stimmer
This is the latest version of the code. The output pins have changed completely and are now more convenient. Also I have attempted to reduce/eliminate the shimmering problem.
The connections are now:
Due pin 34 -> 820R resistor -> VGA pin 3 (blue)
Due pin 35 -> 390R resistor -> VGA pin 3 (blue)
Due pin 36 -> 2k2 resistor -> VGA pin 2 (green)
Due pin 37 -> 1k resistor -> VGA pin 2 (green)
Due pin 38 -> 470R resistor -> VGA pin 2 (green)
Due pin 39 -> 2k2 resistor -> VGA pin 1 (red)
Due pin 40 -> 1k resistor -> VGA pin 1 (red)
Due pin 41 -> 470R resistor -> VGA pin 1(red)
Due pin 42 -> VGA pin 14 (VSync)
Due pin 43 -> VGA pin 13 (HSync)
Due pin GND -> VGA pins 5,6,7,8,10
Code: [Select]
/* Arduino Due VGA-Out v0.8 by stimmer
http://arduino.cc/forum/index.php/topic,130742.0.html */
int bins[256];
void  __attribute__((aligned(64))) doLine(byte *p){
       asm volatile (
       "isb \n\t"
       "dsb \n\t"
       "movw r1,#0x4254 \n\t"
       "movt r1,#0x4009 \n\t"
       "ldr r0,[r1] \n\t"
       "subs r0,#66 \n\t"
       "lsls r0,r0,#1 \n\t"
       "orr r0,#1 \n\t"
       "add r0,pc \n\t"
       "isb \n\t"
       ".align 5 \n\t"
       "bx r0 \n\t"
       ".rept 160 \n\t"
       "nop \n\t"
       ".endr \n\t"
       //this is debugging code, but because the timimg is so sensitive I have to leave it in
       "ldr r0,[r1] \n\t"
       "subs r0,#128 \n\t"
       "ldr r2,[%[bins],r0,lsl #2] \n\t"
       "adds r2,#1 \n\t"
       "str r2,[%[bins],r0,lsl #2] \n\t"
       "movw r1,#0x1238 \n\t"
       "movt r1,#0x400e \n\t"
       ".rept 320 \n\t"
       "ldrb r0,[%[bytes]],#1 \n\t"
       "lsls r0,r0,#2 \n\t"
       "str r0,[r1] \n\t"
       ".endr \n\t"
       "mov r0,#0 \n\t"
       "str r0,[r1] \n\t"
       :[bytes]"+r"(p)
       :[bins]"r"(bins)
       :"r0","r1","r2"
byte fb[240][320];
void PWM_Handler()
   long dummy=REG_PWM_ISR1;
   if(line < 480){
       doLine(p);
   if(line==490) digitalWriteDirect(42,1); //or digitalWriteDirect(42,0); to invert vsync
   if(line==492) digitalWriteDirect(42,0); //or digitalWriteDirect(42,1);
void setup(){
 pinMode(42,OUTPUT); pinMode(43,OUTPUT);                     // vsync=42 hsync=43
 pinMode(34,OUTPUT); pinMode(35,OUTPUT);                     // blue  (35=msb,34=lsb)
 pinMode(36,OUTPUT); pinMode(37,OUTPUT); pinMode(38,OUTPUT); // green (38=msb,37,36=lsb)
 pinMode(39,OUTPUT); pinMode(40,OUTPUT); pinMode(41,OUTPUT); // red   (41=msb,40,39=lsb)
 REG_PIOC_OWER= 0x3fc;
 REG_PIOA_PDR |=1<<20;
 REG_PIOA_ABSR|=1<<20;
 REG_PMC_PCER1= 1<<4;
 REG_PWM_WPCR= 0x50574dfc;
 REG_PWM_CLK= 0x00010001;
 REG_PWM_DIS= 1<<2;
 REG_PWM_CMR2=0x0;   //  REG_PWM_CMR2=0x200;  //to invert hsync polarity
 REG_PWM_CPRD2=2668;
 REG_PWM_CDTY2=2348;
 REG_PWM_SCM=0;
 REG_PWM_IER1=1<<2;
 REG_PWM_ENA= 1<<2;
 NVIC_EnableIRQ(PWM_IRQn);
void loop(){
 for(int x=0;x<320;x++){
   int my=240;
   for(float Z=-15.02;Z<15.0;Z+=0.01){
     float X=(x-159.98)/16.0;
     float R=sqrt(X*X+Z*Z);
     float Y=150.0*(1.0+sin(R)/R);
     int y=320.0-(Z*4.0)-Y;
     if(y<my && y>=0){
       byte c=Y;
       fb[y][x]=c;
       my=y;
stimmer
#23
Nov 24, 2012, 08:39 pm Last Edit: Nov 24, 2012, 10:04 pm by stimmer Reason: 1
I have had some success with 640x480 1bpp. This version is using SPI and DMA - this has the advantage that now the CPU can carry on working most of the time while the screen is being drawn. Therefore it is much faster than the 320x240x8bpp code. The downside is that the video output is on the SPI connector (MOSI - middle pin of lower row - look at http://arduino.cc/forum/index.php/topic,132130.0.html if you can't find it). Connect MOSI through a 100R resistor to VGA R,G and B. VSync is on pin 42 and HSync is on pin 43.
There is slight shimmering in this version which I hope to be able to correct. Also the timings are quite a way out (pixel clock is 10% too fast) hopefully most LCDs will be able to stretch the picture enough. If anyone does try it and it does/doesn't work please tell me.
If you make any demos with this please use the putPixel/getPixel functions if they are fast enough, as I might yet change the underlying format of the framebuffer.
Code: [Select]
/* Arduino Due VGA-Out 640x480 v0.4 by stimmer
int bins[256];
       asm volatile (
       "isb \n\t"
       "dsb \n\t"
       "ldr r0,[r1] \n\t"
       "subs r0,#35 \n\t"
       "orr r0,#1 \n\t"
       "add r0,pc \n\t"
       "isb \n\t"
       ".align 5 \n\t"
       "bx r0 \n\t"
       ".rept 200 \n\t"
       "nop \n\t"
       ".endr \n\t"
       "ldr r0,[r1] \n\t"
       "subs r0,#128 \n\t"
       "adds r2,#1 \n\t"
       "movw r1,#0x4104 \n\t"
       "movt r1,#0x400C \n\t"
       "str %[bytes],[r1] \n\t"
       "movw r1,#0x4110 \n\t"
       "movw r0,80 \n\t"
       "movt r0,#0x0000 \n\t"
       "str r0,[r1] \n\t"
       "movw r1,#0x4028 \n\t"
       "mov r0,1<<5 \n\t"
       "str r0,[r1] \n\t"
       "movw r1,#0x0e04 \n\t"
       "mov r0,1<<26 \n\t"
       ".rept 26\n\t nop\n\t .endr\n\t"
       "str r0,[r1] \n\t"
       :[bytes]"+r"(p)
       :[bins]"r"(bins)
       :"r0","r1","r2"
void __attribute__((aligned(64))) DMAC_Handler()
   REG_SPI0_TDR=0;
   asm volatile("nop\n\t nop\n\t nop\n\t");
   REG_PIOA_PER  = 1<<26;
   uint32_t dummy=REG_DMAC_EBCISR;
byte fb[480][80] __attribute__((aligned(256)));
void __attribute__((aligned(64))) PWM_Handler()
   if(line < 480){
       byte * p=fb[line];
       doLine(p);
   line++; if(line == 525){
     line=0;
void setup(){
 // video output is on SPI MOSI pin (bottom middle on SAM3 3x2 SPI connector)
 REG_PIOA_PDR  =1<<20;
 REG_PWM_DIS= 1<<2;
 REG_PWM_CPRD2=2668;
 REG_PWM_CDTY2=2348;
 REG_PWM_SCM=0;
 REG_PWM_IER1=1<<2;
 REG_PWM_ENA= 1<<2;
 REG_PMC_PCER1= 1<<7;
 REG_DMAC_WPMR=DMAC_WPMR_WPKEY(0x444d4143);
 REG_DMAC_EN=1;
 REG_DMAC_GCFG=0x00;
 REG_DMAC_EBCIER=1<<5;
 REG_DMAC_DADDR5=(uint32_t)&REG_SPI0_TDR;
 REG_DMAC_DSCR5=0;
 REG_DMAC_CTRLB5=0x20310000;
 REG_DMAC_CFG5=  0x21012210;
 NVIC_EnableIRQ(DMAC_IRQn);
 REG_PIOA_PDR  = (1<<25)|(1<<27)|(1<<28);
 REG_PIOA_ABSR&=~((1<<25)|(1<<27)|(1<<28));
 REG_PMC_PCER0= 1<<24;
 REG_SPI0_WPMR=0x53504900;
 REG_SPI0_CR=0x1;
 REG_SPI0_MR=0x00000011;
 SPI0->SPI_CSR[0]=0x00000300;
inline void putPixel(int x,int y,byte c=1){
 if((x<0)||(x>=640)||(y<0)||(y>=480))return;
 byte mask=1<<((~x)&7);
 if(c) fb[y][x>>3]|= mask;
 else  fb[y][x>>3]&=~mask;
inline int getPixel(int x,int y){
 if((x<0)||(x>=640)||(y<0)||(y>=480))return -1;
 return (fb[y][x>>3] & mask)?1:0;
inline void clearBuffer(byte c=0){
 memset(fb,c?255:0,sizeof(fb));
void loop(){
 float c[3][2]={{random(640),random(480)},{random(640),random(480)},{random(640),random(480)}};
 static int j=1;
 if(random(10)==0){clearBuffer(j);j=1-j;}
 for(int x=0;x<640;x+=2){putPixel(x,0);putPixel(x,479);}
 for(int y=0;y<480;y+=2){putPixel(0,y);putPixel(639,y);}
 float x=c[0][0],y=c[0][1];
 for(int t=0;t<40000;t++){
   int i=random(0,3);
   x=(x+c[i][0])/2;
   y=(y+c[i][1])/2;
   putPixel(x,y,j);
stimmer
Great news - SVGA 800x600x1bpp is possible  :smiley-mr-green: Connections are the same as 640x480 above (Video out on SPI MOSI, VSync on pin 42 and HSync on pin 43)
Code: [Select]
/* Arduino Due SVGA-Out 800x600 v0.3 by stimmer
Please do not attempt to understand this code :-) */
int bins[256];
        asm volatile (
        "isb \n\t"
        "dsb \n\t"
        "ldr r0,[r1] \n\t"
        "subs r0,#40 \n\t"
        "orr r0,#1 \n\t"
        "add r0,pc \n\t"
        "isb \n\t"
        ".align 5 \n\t"
        "bx r0 \n\t"
        ".rept 90 \n\t"
        "nop \n\t"
        ".endr \n\t"
        "ldr r0,[r1] \n\t"
        "subs r0,#128 \n\t"
        "adds r2,#1 \n\t"
        //"movw r1,#0x40DC \n\t"
        //"movt r1,#0x400C \n\t"
        //"str %[bytes],[r1] \n\t"
        "movw r1,#0x40E8 \n\t"
        "movw r0,26 \n\t"
        "movt r0,#0x1203 \n\t"
        "str r0,[r1] \n\t"
        "mov r0,1<<4 \n\t"
        "str r0,[r1] \n\t"
        "mov r0,1<<26 \n\t"
        ".rept 12\n\t nop\n\t .endr\n\t"
        "str r0,[r1] \n\t"
        :[bytes]"+r"(p)
        :[bins]"r"(bins)
        :"r0","r1","r2"
uint16_t fb[600][52] __attribute__((aligned(256)));
    if(line < 600){
        //byte * p=fb[line];
        doLine(0);
    if(line==601) digitalWriteDirect(42,1); //or digitalWriteDirect(42,0); to invert vsync
    if(line==605) digitalWriteDirect(42,0); //or digitalWriteDirect(42,1);
    line++; if(line == 628){
      REG_DMAC_SADDR4=(uint32_t)fb;
      line=0;
void setup(){
  REG_PWM_DIS= 1<<2;
  REG_PWM_CPRD2=2218;
  REG_PWM_CDTY2=1949;
  REG_PWM_SCM=0;
  REG_PWM_IER1=1<<2;
  REG_PWM_ENA= 1<<2;
  REG_DMAC_EN=1;
  REG_DMAC_GCFG=0x00;
  REG_DMAC_EBCIER=1<<4;
  REG_DMAC_DADDR4=(uint32_t)&REG_SPI0_TDR;
  REG_DMAC_DSCR4=0;
  REG_DMAC_CTRLB4=0x20310000;
  REG_DMAC_CFG4=  0x01412210;
  REG_SPI0_CR=0x1;
  SPI0->SPI_CSR[0]=0x00000280;
  if((x<0)||(x>=800)||(y<0)||(y>=600))return;
  uint16_t mask=1<<((~x)&15);
  if(c) fb[y][x>>4]|= mask;
  else  fb[y][x>>4]&=~mask;
  if((x<0)||(x>=800)||(y<0)||(y>=600))return -1;
  return (fb[y][x>>4] & mask)?1:0;
#define sgn(x) (((x)>0)?1:((x)<0)?-1:0)
void drawLine(int x0, int y0, int x1, int y1,int c){
   int dx=abs(x1-x0), dy=abs(y1-y0),sx=sgn(x1-x0),sy=sgn(y1-y0);
   int err=dx-dy;
   do{ putPixel(x0,y0,c<2?c:!getPixel(x0,y0));
       int e2=2*err;
       if (e2 > -dy){err-=dy;x0+=sx;}
       if (e2 <  dx){err+=dx;y0+=sy;}
   }   while ((x0!=x1)||(y0!=y1));
void loop(){
  int j=random(6)-221;
  for(int i=j;i<800-j;i++)drawLine(i,j-100,799-i,699-j,2);
  for(int i=799-j;i>=j;i--)drawLine(j,i-100,799-j,699-i,2);
JLS1
Hi Stimmer
800x600 is great work many thanks :-)
Kamil
P.S. is possible 640x480 with some colors ?
JLS1
#26
Nov 26, 2012, 11:05 pm Last Edit: Nov 26, 2012, 11:09 pm by JLS1 Reason: 1
SVGA Hopalong Orbit Fractal :-)
Code: [Select]
/* Hopalong Orbit Fractal v1.1 by JLS 2012 */
int bins[256];
       asm volatile (
       "isb \n\t"
       "dsb \n\t"
       "ldr r0,[r1] \n\t"
       "subs r0,#40 \n\t"
       "orr r0,#1 \n\t"
       "add r0,pc \n\t"
       "isb \n\t"
       ".align 5 \n\t"
       "bx r0 \n\t"
       ".rept 90 \n\t"
       "nop \n\t"
       ".endr \n\t"
       "ldr r0,[r1] \n\t"
       "subs r0,#128 \n\t"
       "adds r2,#1 \n\t"
       "movw r0,26 \n\t"
       "str r0,[r1] \n\t"
       "mov r0,1<<4 \n\t"
       "str r0,[r1] \n\t"
       "mov r0,1<<26 \n\t"
       "str r0,[r1] \n\t"
       :[bytes]"+r"(p)
       :[bins]"r"(bins)
       :"r0","r1","r2"
   if(line < 600){
       doLine(0);
     line=0;
void setup(){
 REG_PWM_DIS= 1<<2;
 REG_PWM_CPRD2=2218;
 REG_PWM_CDTY2=1949;
 REG_PWM_SCM=0;
 REG_PWM_IER1=1<<2;
 REG_PWM_ENA= 1<<2;
 REG_DMAC_EN=1;
 REG_DMAC_GCFG=0x00;
 REG_DMAC_DSCR4=0;
 REG_SPI0_CR=0x1;
  int err=dx-dy;
      int e2=2*err;
  float a = 0.5;
  float b = -0.6;
  float c = 0.7;
  float x = 1;
  float y = 0;
  int xx,yy;
  int cnt = 0;
  int col = 1;
void loop(){
   double oldx = x;
   double oldy = y;
   y = a-oldx;
   xx = 400+10*x;
   yy = 300+10*y;
   if (cnt == 1000) {
col = rand()%2;
cnt = 0; }
   cnt++;
   if ((xx>=0)&(xx<=799)&(yy>=0)&(yy<=599)) putPixel(xx,yy,col);
JLS1
SVGA Three Ply Orbit Fractal :-)
Code: [Select]
/* Three Ply Orbit Fractal v1.1 by JLS 2012 */
int bins[256];
        asm volatile (
        "isb \n\t"
        "dsb \n\t"
        "ldr r0,[r1] \n\t"
        "subs r0,#40 \n\t"
        "orr r0,#1 \n\t"
        "add r0,pc \n\t"
        "isb \n\t"
        ".align 5 \n\t"
        "bx r0 \n\t"
        ".rept 90 \n\t"
        "nop \n\t"
        ".endr \n\t"
        "ldr r0,[r1] \n\t"
        "subs r0,#128 \n\t"
        "adds r2,#1 \n\t"
        "movw r0,26 \n\t"
        "str r0,[r1] \n\t"
        "mov r0,1<<4 \n\t"
        "str r0,[r1] \n\t"
        "mov r0,1<<26 \n\t"
        "str r0,[r1] \n\t"
        :[bytes]"+r"(p)
        :[bins]"r"(bins)
        :"r0","r1","r2"
    if(line < 600){
        doLine(0);
      line=0;
void setup(){
  REG_PWM_DIS= 1<<2;
  REG_PWM_CPRD2=2218;
  REG_PWM_CDTY2=1949;
  REG_PWM_SCM=0;
  REG_PWM_IER1=1<<2;
  REG_PWM_ENA= 1<<2;
  REG_DMAC_EN=1;
  REG_DMAC_GCFG=0x00;
  REG_DMAC_DSCR4=0;
  REG_SPI0_CR=0x1;
   int err=dx-dy;
       int e2=2*err;
   float a = -55;
   float b = -1;
   float c = -41;
   float x = 1;
   float y = 0;
   int xx,yy;
   int cnt = 0;
   int col = 1;
void loop(){
    double oldx = x;
    double oldy = y;
    x = oldy-(oldx/abs(oldx))*abs(sin(oldx)*cos(b)+c-oldx*sin(a+b+c));
    y = a-oldx;
    xx = 400+x/5;
    yy = 300+y/5;
    if (cnt == 1000) {
col = rand()%2;
cnt = 0; }
    cnt++;
stimmer
Hi Stimmer
Kamil
I don't think 640x480 with 2 bits per pixel will be possible unfortunately. 640x480x3bpp is definitely impossible as there is not enough memory. With 2bpp there is enough memory but not enough speed. I got 640x480 working by using the SPI hardware but there is only one fast SPI channel on the Due.
What might be possible is a 640x480 overlay on a much lower resolution background. I've attached a screenshot of one of my experiments, this is 640x480 over an 80x60 grid of background colours (although the timing is all wrong at the moment). This isn't so useful for graphics demos, but could be good if I added text and fonts because it would give some control over text background colour. But I don't know if I can get it working well enough yet.
JLS1
Thanks info
Kamil
