Pages: [1] 2 3 4   Go Down
Author Topic: VGA output  (Read 13069 times)
Online Online
After working out how to do a timer interrupt I've had a go at making a VGA framebuffer. It is rather low-res at present(160x240) and fuzzy but I hope to be able to improve that. It has 8-bit colour (RRRGGGBB).
I cannot get Eagle to run right now so will have to describe the schematic in text:
Due pin 2 -> VGA pin 13 (HSync)
Due pin 3 -> VGA pin 14 (VSync)
Due pin 25 -> 820R resistor -> VGA pin 3 (blue)
Due pin 26 -> 390R resistor -> VGA pin 3 (blue)
Due pin 27 -> 2k2 resistor -> VGA pin 2 (green)
Due pin 28 -> 1k resistor -> VGA pin 2 (green)
Due pin 14 -> 470R resistor -> VGA pin 2 (green)
Due pin 15 -> 2k2 resistor -> VGA pin 1 (red)
Due pin 29 -> 1k resistor -> VGA pin 1 (red)
Due pin 11 -> 470R resistor -> VGA pin 1(red)
Due pin GND -> VGA pins 5,6,7,8,10
inline void digitalWriteDirect(int pin, boolean val){
  if(val) g_APinDescription[pin].pPort -> PIO_SODR = g_APinDescription[pin].ulPin;
  else    g_APinDescription[pin].pPort -> PIO_CODR = g_APinDescription[pin].ulPin;
volatile short line;
byte fb[240][160];
void TC0_Handler()
    long dummy=REG_TC0_SR0;
    if(line < 480){
        int i,j=line>>1;
        for(i=0;i<160;i++) REG_PIOD_ODSR = fb[j][i];
        REG_PIOD_ODSR = 0;
    if(line==490) digitalWriteDirect(3,1);
    if(line==492) digitalWriteDirect(3,0);
    line++; if(line == 525) line=0;
void setup(){
  for(int i=0;i<160;i++)for(int j=0;j<240;j++)fb[j][i]=j+i;
  pinMode(3,OUTPUT);  pinMode(2,OUTPUT);                      // vsync=3 hsync=2
  pinMode(25,OUTPUT); pinMode(26,OUTPUT);                     // blue  (26=msb,25=lsb)
  pinMode(27,OUTPUT); pinMode(28,OUTPUT); pinMode(14,OUTPUT); // green (14=msb,28,27=lsb)
  pinMode(15,OUTPUT); pinMode(29,OUTPUT); pinMode(11,OUTPUT); // red   (11=msb,29,15=lsb)
  REG_PIOD_OWER= 0xff;
  REG_PMC_PCER0= 1<<27;
  REG_PIOB_PDR = 1<<25;
  REG_PIOB_ABSR= 1<<25;
  REG_TC0_WPMR = 0x54494D00;
  REG_TC0_CMR0 = 0b00000000000010011100010000000000;
  REG_TC0_RC0  = 1334;
  REG_TC0_RA0  = 1174;
  REG_TC0_CCR0 = 0b101;
  REG_TC0_IER0 = 0b00010000;
  REG_TC0_IDR0 = 0b11101111;
  NVIC_EnableIRQ(TC0_IRQn);
#include <complex>
using namespace std;
const byte cmap[]={0b00000000,0b11100000,0b11100100,0b11101000,0b11101100,0b11110000,0b11110100,0b11111000,0b11111100,
                   0b11011100,0b10111100,0b10011100,0b01111100,0b01011100,0b00111100,0b00011100,0b00011101,0b00011110,
                   0b00011111,0b00011011,0b00010111,0b00010011,0b00001111,0b00001011,0b00000111,0b00000011,0b00100011,
                   0b01000011,0b01100011,0b10000011,0b10100011,0b11000011,0b11100011,0b11100010,0b11100001,0b11100000,0b00000000};
void loop(){
  for(int i=0;i<160;i++){
    for(int j=0;j<240;j++){
      complex<float> z(0,0),c(i/320.0,(j+240.0)/640.0);
      int n;
      for(n=1;n<sizeof(cmap);n++){
        z=z*z+c;
        if(norm(z)>4.0)break;
      fb[j][i]=cmap[sizeof(cmap)-n];
  for(;;);
Online Online
I unrolled a loop and now it is 320x240 smiley-cool The resolution could go higher but 320x240x8 is 77Kbytes of RAM already.
/* Arduino Due VGA-Out v0.2 by stimmer
http://arduino.cc/forum/index.php/topic,130742.0.html */
byte fb[240][320];
#define do20(x) x x x x x x x x x x x x x x x x x x x x
#define do80(x)  do20(x) do20(x) do20(x) do20(x)
#define do320(x) do80(x) do80(x) do80(x) do80(x)
#define MNOP(x) asm volatile (" .rept " #x "\n\t nop \n\t .endr \n\t")
void TC0_Handler()
    if(line < 480){
        byte * p=fb[line>>1];
        MNOP(160);
        do320(REG_PIOD_ODSR = *p++;MNOP(2);)
        REG_PIOD_ODSR = 0;
    if(line==490) digitalWriteDirect(3,1); //or digitalWriteDirect(3,0); to invert vsync
    if(line==492) digitalWriteDirect(3,0); //or digitalWriteDirect(3,1); to invert vsync
void setup(){
  for(int i=0;i<320;i++)for(int j=0;j<240;j++)fb[j][i]=j+i;
//  REG_TC0_CMR0 = 0b00000000000001101100010000000000; // this inverts hsync
  REG_TC0_RC0  = 1334;
  REG_TC0_RA0  = 1174;
#include <complex>
void loop(){
  for(int i=0;i<320;i++){
      complex<float> z(0,0),c((i+180.0)/1280.0,(j+640.0)/1280.0);
      int n;
        z=z*z+c;
  for(;;);
« Last Edit: November 04, 2012, 09:41:21 pm by stimmer » Logged
Forum Administrator
Milano, Italy
 smiley-surprise
stimmer, you've got some serious skills here!
nice work!
C
C.
Quebec, Canada
it is possible to only display black and white and get a better resolution?
Online Online
640x480 black and white only should be possible. It might even be possible with 2 bit greyscale.
There's a chance 800x600 black and white might work. Anything more than that takes too much memory.
Quebec, Canada
that would be nice 640x480! but just one bit!
« Last Edit: November 06, 2012, 06:34:45 pm by micnossub » Logged
This project can work with arduino uno?
Thanks.
Ayer, Massachusetts, USA
Thanks.
No, the UNO only has enough memory for something like a 120x96 black and white image.
If that is fine, there are two shields that use the TVout library that are supposed to make the job easier:
I have the Video Experimenter, but it is on my to-do pile, and I haven't tried it out yet
Brazil
Wusik Dot Com
Superb!
Czech
This is very usefull for me - thanks
Is possible post source code for 640x480 or 800x600 black/white ?
Many thanks
Kamil
How long before we see a GPU or a graphics card from 1995 get modified to work with due/uno and a VGA monitor? smiley
why 95?
Someone have done it with stm32 based boards: http://hackaday.com/2012/10/08/stm32-driving-a-pcie-video-card/
and Gameduino produces vga(I think) using an FPGA adapterboard.
and, btw, the Propeller, with its 8 "core's" produces vga for games and such, if one could interface more memory on the Due (wish that could be possible on the next SAM based card) one could have kinda ok graphics.
« Last Edit: November 12, 2012, 02:03:42 pm by neslekkim » Logged
Czech
Simple Game of Life example :-)
#define GRID_X 100
#define GRID_Y 92
#define MAX_GENERATIONS 250
uint8_t grid[2][GRID_X][GRID_Y];
uint8_t current_grid = 0;
uint8_t generations = 0;
byte fb[240][320];
void TC0_Handler()
    if(line < 480){
        MNOP(160);
        REG_PIOD_ODSR = 0;
void setup(){
  REG_TC0_RC0  = 1334;
  REG_TC0_RA0  = 1174;
  initGrid();
  drawGrid();
void loop(){
  runGrid();
 drawGrid();
 generations++;
 if (generations > MAX_GENERATIONS) {
 generations = 0;
 initGrid();
void initGrid()
 int i, j;
 int t;
 current_grid = 0;
 for (i = 0; i < GRID_X; i++) {
 for (j = 0; j < GRID_Y; j++) {
 if (rand()%2) {
 grid[0][i][j] = 2;
 grid[0][i][j] = 0;
void runGrid()
 uint8_t x, y;
 int count;
 uint8_t value = 0;
 uint8_t new_grid;
 new_grid = 1 - current_grid;
 for (y = 0; y < GRID_Y; y++) {
 for (x = 0; x < GRID_X; x++) {
 count = count_neighbours(x, y);
 if (count < 2 || count > 3) { value = 0; }
 else if (count == 3) { value = 3; }
 else { value = grid[current_grid][x][y]; }
 grid[new_grid][x][y] = value;
 current_grid = new_grid;
int count_neighbours(int x, int y)
 int i, j;
 int sx;
 int result = 0;
 x--;
 y--;
 for (i = 0; i < 3; i++) {
 if (y < 0 || y > (GRID_Y - 1)) { continue; }
 for (j = 0; j < 3; j++) {
 if (x < 0 || x > (GRID_X - 1)) { continue; }
 if (i==1 && j == 1) { x++; continue; }
 if (grid[current_grid][x][y]) { result++; }
 x++;
 y++;
 x -= 3;
 return result;
void drawGrid()
 uint8_t  x,  y;
 uint8_t cx, cy;
 uint8_t grid_next_colour = 0;
 cx = 0;
 cy = 0;
 cx = 0;
 if (grid[1-current_grid][x][y] != grid[current_grid][x][y]) {
  if(grid[current_grid][x][y]) {
    fb[cy][cx]=rand()%255;
    else {
    fb[cy][cx]=0;
 cx += 2;
 cy += 2;
Online Online
Nice work  smiley-grin (I accidentally left it running all night, it's still going strong!)
Here's a quick status update for the VGA output project. Basically to get any further with this I need to learn ARM inline assembler, which is what I've been doing. With the code above the output is shimmering slightly and if you look closely some of the pixels are bigger than others. I do have code which solves the wide pixels problem and reduces the shimmering, however it is unreliable (sometimes it doesn't compile, sometimes it compiles but doesn't work, sometimes it works perfectly). I guess I have a little more to learn.
I haven't started on 640x480 1bpp yet but I still think it is viable. I don't know about 800x600 (the pixel rate would be 40Mpixels/sec) but there might be a way...
Finally when reading the datasheet I noticed that the SAM3X has some DMA controllers. I am strongly tempted to evaluate whether I can use them rather than the inline assembler. This is even more to learn (I've never used DMA before) but if it does work it would be a much better solution. It would use much less CPU for one thing  smiley-mr-green
« Last Edit: November 14, 2012, 05:48:30 am by stimmer » Logged
Czech
Simple Wolfram 1D Cellular Automata example :-)
/* Wolfram Cellular Automata 1D v1.0 */
byte fb[240][320];
void TC0_Handler()
    if(line < 480){
        MNOP(160);
        REG_PIOD_ODSR = 0;
void setup(){
  REG_TC0_RC0  = 1334;
  REG_TC0_RA0  = 1174;
void loop(){
  int iteration = 240;
  int lenght = 320;
  int row = 0;
  int state[lenght];
  int newstate[lenght];
  int i,j,k;
  int rules[8] = {
  int (rand()%2),
  int (rand()%2),
  int (rand()%2),
  int (rand()%2),
  int (rand()%2),
  int (rand()%2),
  int (rand()%2),
  int (rand()%2)};
  for (i=0;i<lenght;i++) state[i]= int (rand()%2);
   for (i=0;i<iteration;i++) {
      for (j=0;j<lenght;j++)
         newstate[j] = 0;
      for (j=0;j<lenght;j++) {
         k = 4*state[(j-1+lenght)%lenght] + 2*state[j] + state[(j+1)%lenght];
         newstate[j] = rules[k];
        state[j] = newstate[j];
        DisplayState(state,lenght,row);
        row = row + 1;
void DisplayState(int s[],int len, int row)
   int i;
   for (i=0;i<len;i++) {
      if (s[i] == 1){
       fb[row][i]=255;
      else{
       fb[row][i]=0;
Pages: [1] 2 3 4   Go Up
