Author Topic: error: expected unqualified-id before 'if'  (Read 406 times)
I get this error, when I try to compile it. My code begins like so:
#include <EEPROM.h>
const int buttonPin = 2;  //pushbutton
byte backlights = EEPROM.read(0);
if (backlights == 0){
  int Leds[10] = {3,4,5,6,7,8,13,13,13,13};  // array of the led numbers used, backlights will be turned on in setup()
else{
  int Leds[10] = {3,4,5,6,7,8,9,10,11,12};  // array of the led numbers used, boot normal
int reading;
boolean firstRun;
Why am I getting this error? Am I not allowed to use "if" outside a void?
« Last Edit: November 05, 2012, 05:20:12 am by Hasi321 » Logged
North Queensland, Australia
Online Online
if cannot be used at global scope like that, you need to do that setup routine in the setup() function.
Oh, ok thanks!
Online Online
Could set up common stuff globally, then do the unique stuff in setup().
int Leds[10] = {3,4,5,6,7,8};
void setup(){
  if( backlights ){
    Leds[ 6 ] = 9;
    Leds[ 7 ] = 10;
    Leds[ 8 ] = 11;
    Leds[ 9 ] = 12;
  }else{
    Leds[ 6 ] = Leds[ 7 ] = Leds[ 8 ] = Leds[ 9 ] = 13;
