Loading...
Pages: [1]   Go Down
Author Topic: Make a Drum Machine  (Read 1537 times)
Italy
Offline Offline
Newbie
View Profile
How can I make a drum machine without use my Arduino UNO as a MIDI device?
How can I manage the 8 pads I want to use?
Thanks for the attention !
Logged
Netherlands
Online Online
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Check this - http://www.instructables.com/id/Secret-Knock-Detecting-Door-Lock/ -
it is not a drum, but it gives you insight how to detect a beat.
You can use 8 pins for 8 sensors and use three PWM pins to control the output, might need an amplifier.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Italy
Offline Offline
Newbie
View Profile
Logged
South England
Offline Offline
Full Member
View Profile
Do you want to actually synthesize the drum sounds, or just make a trigger pad to midi converter? One's relatively hard, the other's supposed to be quite easy.
Logged
Dubai, UAE
Offline Offline
Edison Member
View Profile
WWW
   If you want to synthesis the drum sounds, I can probably help -
http://rcarduino.blogspot.com/2012/08/the-must-build-arduino-project-illutron.html
Its not going to be midi quality, but it is a fun quick to build project and with a little modding you can stop the main sequence and trigger the drums directly if you want.
Duane B
Logged
Italy
Offline Offline
Newbie
View Profile
South England
I want to use flstudio(music software) with arduino...the pc must relieve arduino as a midi device...for example: I want to play a musical keyboard and the computer receives the notes with fl studio.
This is the video:
It's only that i have 8 pads instead of a musical keyboard
I hope you understand what i want to do
sorry for my english!
Logged
South England
Offline Offline
Full Member
View Profile
Well, for my project idea (which may or may not ever get built!!) I was thinking of two different approaches to accomplish the same thing - do an analog read on 8 pads and act accordingly.
As my project plan was for a modular system similar to the old Simmons kits, my first plan was for a master trigger module, and its job would be managing the input pads and MIDI/trigger signals to other stuff. This is how I imagined such a module MIGHT work (it also might very well NOT work, as I have had no time to build, code and test it):
Going by the highest midi timing resolution feasible on whatever micro I ended up using, first perform a sequential analog read on all inputs to determine which pads were hit in that "time slot" and how hard. Let's say for argument's sake that the 8 inputs could be polled sequentially every millisecond or so, and the 8 values obtained put in an array, which could be passed to another function responsible for generating the MIDI data.
My idea to test this if I ever got around to it would be to write a Processing app consisting simply of 8 coloured boxes which could change from green to red when a pad is triggered and display the velocity (0-127) in the box, and hope that if it LOOKED like it was responding correctly and quick enough, it would sound "in time".
I suppose with all the libraries available for midi/serial stuff, it wouldn't be too hard to take the pad data and assign it to MIDI notes... but then, this is all just pure speculation and untested by me.
I have attached a schematic from a project called "EDrum" which demonstrates how to hook up the pads to your micro's analog inputs. Perhaps you'll find it useful!
Logged
Pages: [1]   Go Up
Print
Jump to:
