Loading...
Pages: [1]   Go Down
Author Topic: Arduino UNO and Arduino Motor Shield and a 200 ohm potentiometer  (Read 232 times)
Offline Offline
Newbie
View Profile
Hi!
I'm having trouble to read the voltage value of the potenciometer's wiper "leg".
I connected it to the 5V-GND of the Arduino, and connect the wiper into A0 analog pin. At 100ohms, I should have read 2.5V, but instead, I got 0,49V! I'm using Matlab instead of IDE.
I set the A0 pin in two different ways to see if it was a syntax error :
pinMode(A0,'input') and pinMode(14, 'input');
potencmt=a.analogRead(0)/1023*5
but none worked as supposed.Therefore, I connected the Arduino's 5V to A0 to see if I would get 5V, no problem. But with the potentiometer it's inconsistent.
Do I really have to set A0 as input(I believe I dont) in order to "tell" Arduino to increase its impedance?
Do I need to use any special potenciometer functions to read the values?(I believe I dont either)
This is the script I have been trying to run:
Function motor
a=arduino('COM3')
    a.pinMode(12,'output');        %DIR A
    a.pinMode(13,'output');        %DIR B
    a.pinMode(9,'output');         %BRAKE A
    a.pinMode(8,'output');         %BRAKE B
    a.pinMode(3,'output');         %PWM A
    a.pinMode(11,'output');        %PWM B
    a.pinMode(14,'input');         % ??
b=0;
    while(b==0)
        a.digitalWrite(12,1); %
        a.digitalWrite(9,0);
        a.analogWrite(3, 255);
        pause(5);
        potmcmt=a.analogRead(0)/1024*5
        a.digitalWrite(9,1);
        pause(5);
        a.digitalWrite(12,0);
        pause(5);
end
end
But the values returned by a.analogRead(0) don't correspond to the ones read by the multimeter
Logged
Pages: [1]   Go Up
Print
Jump to:
