Topic: error "teleduino was not declared in this scope"???? (SOLUCIONADO) (Read 2532 times) previous topic - next topic
junco
me da este error al cargar este codigo , tiene solucion o no puedo usarlo, gracias
 TeleduinoEthernetClientProxy.ino - TeleduinoEthernetClientProxy example
 Version 328-0.6.7
 Nathan Kennedy 2012
 http://www.teleduino.org
 This sketch is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
#include <EEPROM.h>
#include <Servo.h>
#include <Wire.h>
#include <Teleduino328.h>
#include <SPI.h>
#include <Ethernet.h>
// User configurable variables
byte useDhcp = true;
byte useDns = true;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress deviceIp(192, 168, 1, 100); // Only if useDhcp is false
IPAddress gatewayIp(192, 168, 1, 1); // Only if useDhcp is false
IPAddress dnsIp(192, 168, 1, 1); // Only if useDhcp is false
IPAddress subnet(255, 255, 255, 0); // Only if useDhcp is false
IPAddress serverIp(173, 230, 152, 173); // Only if useDns is false
char serverName[] = "us01.proxy.teleduino.org"; // Only if useDns is true
unsigned int serverPort = 5353; // Can be set to either 53 or 5353
byte statusLedPin = 8;
// User configurable key, this is used to authenticate with the proxy server
// This is checked against the EEPROM on boot and written if necessary
// The proxy server retreives the key from the EEPROM
byte key[] = {  };
// Other required variables
byte data[257];
byte dataLength;
byte hexStage;
unsigned long lastInstruction = 0;
unsigned long lastRefresh = 0;
byte stage = 0;
// Declare client object
EthernetClient Client;
 // Load presets
 Teleduino.loadPresets();
 // Set status LED pin
 Teleduino.setStatusLedPin(statusLedPin);
 Teleduino.setStatusLed(1); // Initialisation
 // Check the EEPROM header and check to see if the key is correct
 // This is to ensure the key is not cleared from the EEPROM
 if(EEPROM.read(0) != '#')
   EEPROM.write(0, '#');
 if(EEPROM.read(1) != 0)
   EEPROM.write(1, 0);
 if(EEPROM.read(2) != '#')
   EEPROM.write(2, '#');
 if(EEPROM.read(160) != '#')
   EEPROM.write(160, '#');
 for(byte i = 0; i < 16; i++)
   if(EEPROM.read(161 + i) != key)
     EEPROM.write(161 + i, key);
 if(EEPROM.read(177) != '#')
   EEPROM.write(177, '#');
 // Start network and attempt to connect to proxy server
 Teleduino.setStatusLed(2); // Network configuration
 if(useDhcp)
   if(!Ethernet.begin(mac))
     Teleduino.setStatusLed(2, false, 10000);
     Teleduino.reset();
   Ethernet.begin(mac, deviceIp, dnsIp, gatewayIp, subnet);
 Teleduino.setStatusLed(3); // Connect to server
 if((useDns && !Client.connect(serverName, serverPort)) || (!useDns && !Client.connect(serverIp, serverPort)))
   Teleduino.setStatusLed(3, false, 10000);
   Teleduino.reset();
 lastInstruction = millis();
 if(Client.connected())
   // What we need to do depends on which 'stage' we are at
   switch(stage)
     case 0: // Wait for start byte
       if(Client.available())
         char c = Client.read();
         if(c == '?')
           stage++;
     case 1: // Reset variables
       dataLength = 0;
       hexStage = 0;
       stage++;
     case 2: // Instruction byte
         if(c == '?')
           stage = 1;
         else if(c == '\r' || c == '\n' || c == '.')
           stage = 0;
         if(!hexStage)
           data[0] = Teleduino.hexDecode(c) * 16;
           data[0] += Teleduino.hexDecode(c);
         hexStage = !hexStage;
         if(!hexStage)
           stage++;
     case 3: // Data length byte
         if(c == '?')
           stage = 1;
           stage = 0;
         if(!hexStage)
           data[1] = Teleduino.hexDecode(c) * 16;
           data[1] += Teleduino.hexDecode(c);
         if(!hexStage)
           stage++;
     case 4: // Data
         if(c == '?')
           stage = 1;
           if(dataLength == data[1])
             stage++;
             stage = 0;
         if(!hexStage)
           data[2 + dataLength] = Teleduino.hexDecode(c) * 16;
           data[2 + dataLength] += Teleduino.hexDecode(c);
         if(!hexStage)
           dataLength++;
     case 5: // Execute instruction and return result
       Teleduino.instruction(data);
       Client.write('!');
       for(int i = 0; i < data[1] + 2; i++)
         Client.write(Teleduino.hexEncode(data / 16));
         Client.write(Teleduino.hexEncode(data % 16));
       Client.write('\n');
       stage = 0;
   Teleduino.setStatusLed(10);
   Teleduino.reset();
 // Has the instruction timeout been reached?
 if(millis() - lastInstruction > 30000)
   Client.flush();
   Client.stop();
   Teleduino.setStatusLed(9);
   Teleduino.reset();
 // Process refreshes every 50ms
 if(millis() - lastRefresh >= 50)
   Teleduino.pinTimers();
   Teleduino.shiftRegisterTimers();
   Teleduino.shiftRegisters();
   lastRefresh = millis();
 // Check to see if reset has been requested
 Teleduino.checkReset();
}ar el codigo , tiene solucion? o no puedo usar este codigo
JRodrigo
Pues a mi me compila bien  :|
Bájate la librería Teleduino328, que a mi me huele que te falta  ;)
junco
Eres un crack tio muchas gracias y disculpa mi torpeza :~
