Author Topic: error "teleduino was not declared in this scope"???? (SOLUCIONADO)  (Read 712 times)
me da este error al cargar este codigo , tiene solucion o no puedo usarlo, gracias
  TeleduinoEthernetClientProxy.ino - TeleduinoEthernetClientProxy example
  Version 328-0.6.7
  Nathan Kennedy 2012
  http://www.teleduino.org
  This sketch is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
#include <EEPROM.h>
#include <Servo.h>
#include <Wire.h>
#include <Teleduino328.h>
#include <SPI.h>
#include <Ethernet.h>
// User configurable variables
byte useDhcp = true;
byte useDns = true;
IPAddress deviceIp(192, 168, 1, 100); // Only if useDhcp is false
IPAddress gatewayIp(192, 168, 1, 1); // Only if useDhcp is false
IPAddress dnsIp(192, 168, 1, 1); // Only if useDhcp is false
IPAddress subnet(255, 255, 255, 0); // Only if useDhcp is false
IPAddress serverIp(173, 230, 152, 173); // Only if useDns is false
char serverName[] = "us01.proxy.teleduino.org"; // Only if useDns is true
unsigned int serverPort = 5353; // Can be set to either 53 or 5353
byte statusLedPin = 8;
// User configurable key, this is used to authenticate with the proxy server
// This is checked against the EEPROM on boot and written if necessary
// The proxy server retreives the key from the EEPROM
byte key[] = {  };
// Other required variables
byte data[257];
byte dataLength;
byte hexStage;
unsigned long lastInstruction = 0;
unsigned long lastRefresh = 0;
byte stage = 0;
// Declare client object
EthernetClient Client;
  // Load presets
  Teleduino.loadPresets();
  // Set status LED pin
  Teleduino.setStatusLedPin(statusLedPin);
  Teleduino.setStatusLed(1); // Initialisation
  // Check the EEPROM header and check to see if the key is correct
  // This is to ensure the key is not cleared from the EEPROM
  if(EEPROM.read(0) != '#')
    EEPROM.write(0, '#');
  if(EEPROM.read(1) != 0)
    EEPROM.write(1, 0);
  if(EEPROM.read(2) != '#')
    EEPROM.write(2, '#');
  if(EEPROM.read(160) != '#')
    EEPROM.write(160, '#');
  for(byte i = 0; i < 16; i++)
    if(EEPROM.read(161 + i) != key)
      EEPROM.write(161 + i, key);
  if(EEPROM.read(177) != '#')
    EEPROM.write(177, '#');
  // Start network and attempt to connect to proxy server
  Teleduino.setStatusLed(2); // Network configuration
  if(useDhcp)
    if(!Ethernet.begin(mac))
      Teleduino.setStatusLed(2, false, 10000);
      Teleduino.reset();
    Ethernet.begin(mac, deviceIp, dnsIp, gatewayIp, subnet);
  Teleduino.setStatusLed(3); // Connect to server
  if((useDns && !Client.connect(serverName, serverPort)) || (!useDns && !Client.connect(serverIp, serverPort)))
    Teleduino.setStatusLed(3, false, 10000);
    Teleduino.reset();
  lastInstruction = millis();
  if(Client.connected())
    // What we need to do depends on which 'stage' we are at
    switch(stage)
      case 0: // Wait for start byte
        if(Client.available())
          char c = Client.read();
          if(c == '?')
            stage++;
        break;
      case 1: // Reset variables
        dataLength = 0;
        hexStage = 0;
        stage++;
        break;
      case 2: // Instruction byte
          if(c == '?')
            stage = 1;
            break;
          else if(c == '\r' || c == '\n' || c == '.')
            stage = 0;
            break;
          if(!hexStage)
            data[0] = Teleduino.hexDecode(c) * 16;
            data[0] += Teleduino.hexDecode(c);
          hexStage = !hexStage;
          if(!hexStage)
            stage++;
        break;
      case 3: // Data length byte
          if(c == '?')
            stage = 1;
            break;
            stage = 0;
            break;
          if(!hexStage)
            data[1] = Teleduino.hexDecode(c) * 16;
            data[1] += Teleduino.hexDecode(c);
          if(!hexStage)
            stage++;
        break;
      case 4: // Data
          if(c == '?')
            stage = 1;
            break;
            if(dataLength == data[1])
              stage++;
              break;
              stage = 0;
              break;
          if(!hexStage)
            data[2 + dataLength] = Teleduino.hexDecode(c) * 16;
            data[2 + dataLength] += Teleduino.hexDecode(c);
          if(!hexStage)
            dataLength++;
        break;
      case 5: // Execute instruction and return result
        Teleduino.instruction(data);
        Client.write('!');
        for(int i = 0; i < data[1] + 2; i++)
          Client.write(Teleduino.hexEncode(data / 16));
          Client.write(Teleduino.hexEncode(data % 16));
        Client.write('\n');
        stage = 0;
        break;
    Teleduino.setStatusLed(10);
    Teleduino.reset();
  // Has the instruction timeout been reached?
  if(millis() - lastInstruction > 30000)
    Client.flush();
    Client.stop();
    Teleduino.setStatusLed(9);
    Teleduino.reset();
  // Process refreshes every 50ms
  if(millis() - lastRefresh >= 50)
    Teleduino.pinTimers();
    Teleduino.shiftRegisterTimers();
    Teleduino.shiftRegisters();
    lastRefresh = millis();
  // Check to see if reset has been requested
  Teleduino.checkReset();
}ar el codigo , tiene solucion? o no puedo usar este codigo
« Last Edit: November 06, 2012, 09:51:42 am by junco » Logged
COM22
Pues a mi me compila bien  smiley-neutral
Bájate la librería Teleduino328, que a mi me huele que te falta  smiley-wink
Eres un crack tio muchas gracias y disculpa mi torpeza smiley-confuse
