Loading...
Pages: [1]   Go Down
Author Topic: "analogWrite" vs "digitalWrite"  (Read 611 times)
Offline Offline
Newbie
View Profile
What is the difference between analogWrite() and digitalWrite()?  I will show two different blocks of code that gave me the exact same output on my hardware. There are the codes;
int led=1, brightness=255;
pinmode (led, brighness);
digitalwrite(led, brightness);
and
int led=1;
pinmode(led, output);
digitalwrite(led, high);
When I write these codes I can change digital to analog and get the exact same results. Why is this? What is the difference? Is one preferable over the other?
and yes i know that half the code is missing and that there are no caps, but you should be able to understand what I'm trying to say.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Pin 1 is not a PWM pin (3, 5, 6, 9, 10, and 11 are on the UNO).  For a non-PWM pin, analogWrite() with a value below 128 is tha same a digitalWrite(LOW) and analogWrite() with a value above 127 is tha same a digitalWrite(HIGH).
You don't need pinMode() for PWM pins.  The analogWrite() function takes care of that.
The PWM value 255 is full brightness.  You won't see a difference between that and digitalWrite(HIGH).
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
@alexval1323, please do not cross-post.
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
That depends how the LED is wired.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Pages: [1]   Go Up
Print
Jump to:
