Topic: Can this be achieved (Loading a skech from an sd card) (Read 2172 times) previous topic - next topic
cepa
All right guys, I am working on a project that requires me to load a sketch (.hex file) from an sd card. Is this possible?
The way I am thinking of doing is to write some sort of loader on to the atmega chip, the loader would have the ability to load sketches from the SD, if I reset the arduino, the loader would start up by default. Can this be achieved?
johnwasser
The bootloader section of memory can write into the application section of memory so it is theoretically possible.  Currently the bootloader doesn't provide a function that you can call from a sketch to write into the application space.  You would probably have to start with that.
Another option is to have an Arduino with an SD card act as an ICSP device (like the ArduinoISP sketch) and program a separate Arduino through the ICSP header. I'm pretty sure that has already been done.
Grumpy_Mike
The other option is to run bitlash from the SD card. It is an interpretive language.
cepa
so by that you mean that I would need two Arduinos connected. The first one boots up, flashes the second one, then the second one boots up and does everything I need.
Grumpy_Mike
#4
Nov 05, 2012, 10:40 pm Last Edit: Nov 05, 2012, 10:45 pm by Grumpy_Mike Reason: 1
No just the one arduino with a modified boot loader.
cepa
Could you provide some examples of this or at least point into a general direction?
