Loading...
Pages: 1 [2]   Go Down
Author Topic: storing data from sensors  (Read 857 times)
UK
Offline Offline
Tesla Member
View Profile
Quote
You didn't answer the first question.
I don't know how many values will be stored, it will depend on how long is the path that the car that has the sensors will pass. I imagine will be a lot of values since I have a sensor reading every 35ms
You need to know the answer to this question. If you can't produce an exact answer, then work out what would be the upper limit you need to support. Just saying 'a lot' could mean anything from 100 to 100,000,000.
Logged
Dee Why NSW
Offline Offline
Full Member
View Profile
Quote
I submit you should just cut to what the real problem is, and forget about answering unanswerable questions, for which you probably already have a solution.
You have already done the bleeding obvious and gotten a SD card module, which probably cost $1.50. In the (highly) unlikely event that the data you need to store doesn't really justify an SD card, then it's still only $1.50, which would be struggling to be 5% of your Arduino investment, and it will do the job anyway.  If you have too much data, either get a bigger card or come to terms with the fact that Arduino might be the wrong choice to start with, and it cost you $1.50 to find that out.
I believe the real problem is just a matter of code, not storage. The first bit you attach in reply #12 is simply a one-shot to ensure everything is kosher, but contains the seeds for proper employment.  I know nothing about the second bit, I can't even see how you can say it works, but it does, so all you need now is to splice them together.
I know this sounds a bit glib but the Arduino sends information to its various receptors in the same way. The one-shot shows the way
open file
myFile.print(data)
close file
you just need to put it in the loop which, in your code, currently does nothing. So:-
aquire data// tralala
  Serial.print(data);
      myFile = SD.open("name.txt", FILE_WRITE); //+++++++++++++OPEN
  myFile.print(data); // just like serial
      myFile.print("  ,    "); // comma separation
    myFile.close();//++++++++++++++++++++++++ CLOSE
// and go round again
The file is typically a CSV, i.e. comma separated, suitable for a spreadsheet, which is an array of data, and I guess it is the sort of thing you need.
Is that what you need?
Logged
Offline Offline
Jr. Member
View Profile
that was what I needed thank you. but now how can I use the values that I stored on the file, I was able to read the files back from the file and now I need to use these values. can I go backwards and read these values 3 by 3 as I was reading from the sensors?
Logged
Dee Why NSW
Offline Offline
Full Member
View Profile
I'm sure the answer is yes, even though I have not progressed far enough myself to be sure I understand the question - particularly the last sentence.
Essentially: no matter what you want to do, if you can see it sensibly, you can use it sensibly. Even if you can't see it sensibly, i.e. just a continuous stream of numbers, it is still possible to use it sensibly but it involves a lot of work you would probably rather not know about.
Sticking with the first, by seeing sensibly, I mean easily understood on the monitor. A properly formed CSV file is formed the same way as a properly formed display on the screen. It can even be exactly the same, whereby the file is derived from the monitor.
So the code in the loop looks like
Serial.print(var1);
myFile.print(var1);
Serial.print("   ,  ");
Serial.print(var2);
myFile.print(var2);
Serial.print(var3);
myFile.print(var3;
Serial.println("   ,  ");
myFile.println("  ,  ");
which gives three columns, one row for each loop. The println at the end is the vital punctuation.  You don't actually need the commas in the serial stuff, just the spacing. The commas don't get printed on a spread sheet. They are just signals.
I'm not sure this helps, principally because I'm not sure what you want to do.  I'm a newbie too and, at the moment, II don't use the SD to disseminate data, it is just a backup.
Logged
UK
Offline Offline
Tesla Member
View Profile
I submit that you need to sort out what data you're dealing with (i.e. the type and quantity) and what you want to do with it, before you design mechanisms to store it. These questions ought to be easy to answer, and if you can't answer them then what hope do you have of choosing the most appropriate design?
Logged
Offline Offline
Jr. Member
View Profile
what I am doing right now is building a car that goes through a path using 3 ultrasonic sensors and I am storing the values the values the sensors return during the run. I want to use this values on a second car, so essentially the file on the sd card would be the "sensors". Do you think that by running the code that you wrote I will be able to do that?
Logged
UK
Offline Offline
Tesla Member
View Profile
On the first car, the sensor inputs inform it about the environment. On the second car, the sketch may think it's getting feedback but actually it isn't. If you sketch is intended to respond to the sensor inputs and you want the second car to follow the same path as the first then I suspect that you will get better repeatability by replaying the movements (i.e. the outputs of the control algorithm) rather than the inputs.
Logged
Dee Why NSW
Offline Offline
Full Member
View Profile
If you are alluding to what I wrote in #16 and #18 above, then no.  It's not code per se, it's just snippets to establish the principle. I'm only talking about storage and I know nothing about robot cars. However, if I understand you correctly, I can't help but agree with the other guy.
Car#1 establishes the course to be steered by feeling its way with sensors.
Car#2 follows the same course without sensors, but using the sensor data from car#1
It would seem more sensible for car#2 to use the mechanical commands that car#1 used to achieve the desired result.  That would tell car#2 what to actually do rather than describe the view out the window.
The storage issue is essentially the same - and just as easily solved!
Logged
Offline Offline
Jr. Member
View Profile
I understand. so how can I store the directions the car took? I use if statements to analyze the values for the sensors for example:
Code:
if(sensor on right<20cm)
turnRight()// this is a function of the motor shield
and how can I use the information that I put on the file?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
You need a lot more information than just "the car turned". You need to know WHEN the car turned, and how much the car turned (or how long it spent turning).
Even with that information, do not expect another car making the same turns and the same time for the same length of turn/amount of turn to follow the same path.
What you really need are encoders on the wheels so that you can determine exactly how fast each wheel is turning. Then, quite often, you need to record that information. Much more often then the sensor data.
When replaying it in the other car, you'll need to use the encoder feedback to determine that you are going the same speed. Even if that all works, the two cars will follow only roughly the same path.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
If you had a position system in both cars then car 1 could provide an obstacle map that car 2 could use to avoid obstacles regardless of exact paths. But then you'd need a position system.....
Logged
Examples can be found at Learning in the Main Site and at the Playground
Dee Why NSW
Offline Offline
Full Member
View Profile
I can only guess. It might be a speadsheet where each column represents a stepper motor function and each row is a pulse applied to a stepping drive motor. The simplest robot vehicle is probably on three wheels. Two opposite each other are independently driven by steppers, thereby enabling them to do the steering, and the third is just a dumb castor. The course and distance is simply  two streams of interrelated pulses, which are just numbers on the aforementioned SD card.
(This is the astronomer talking, not the robot car builder....)
Logged
UK
Offline Offline
Tesla Member
View Profile
Code:
At what sort of interval do those steering actions occur? If the original vehicle is jittering left and right due to high frequency steering commands due to the sensor inputs, then you will get very poor repeatability (because the car will be accelerating a lot, and this tends to cause wheel slip which is not consistent). Even if you replay exactly the same sequence of movements to the wheels, the vehicle will not follow exactly the same path. The less frequent the changes speed/direction, and the lower the acceleration used during those changes, the better repeatability you will get.
Assuming you can design your original sketch to produce a manageably small number of speed/direction changes, your problem now it to store a sequence of actions that occur at irregular intervals. Given that your speed and direction changes are based on sensor input it seems likely that you won't know how far you've moved or turned until after the event, so I would design your encoding scheme to suit that. The most obvious way is to encode each change as an action and a quantity. For example you could define a set of byte values for action codes MOVE_FORWARDS, TURN_LEFT, TURN_RIGHT and follow each action with a number that specifies the number of degrees turned (or milliseconds spent turning, or however you want to represent it) or the distance moved (or time spent moving, etc). In this way the action code could be written at the start of each action, and the quantity could be written at the end of the action.
From the replay point of view it follows the same structure but now reads the action code and starts the action, reads the quantity and stops the action when the quantity has been reached, then starts the next action.
In both cases I'd use a read-ahead and write-behind to decouple the actions from the storage, so that the timing of the actions is not affected by the time to read and write from/to your storage device.
Probably the repeatability of the vehicle movement will be the limiting factor, rather than the storage capacity of your storage device; I suspect you will find the repeatability is so poor the replay is effectively unusable after a few dozen speed/direction changes and the quantity of data you're dealing with here may even be small enough to keep in EEPROM if you wanted to.
Logged
Offline Offline
Jr. Member
View Profile
I just tested my whole system with the car reading the information from the array with the information of the sensors, and the second car went through the exactly same path. I just had to adjust the delay of the array reading.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
