Topic: Arduino IDE 1.0.2 (Read 8192 times) previous topic - next topic
leo72
E' uscita l'IDE versione 1.0.2:
http://arduino.cc/en/Main/Software
Ecco le novità:
ARDUINO 1.0.2 - 2012.11.05
[hardware]
* Added support for the Arduino Micro.
* Added support for the LilyPad Arduino USB.
* For Arduino Mega, having avrdude use "wiring" not "stk500v2" for
  uploads (to improve auto-reset behavior).
  http://code.google.com/p/arduino/issues/detail?id=806
[environment]
* Find-In-Reference now works whether or not text is selected.
  http://code.google.com/p/arduino/issues/detail?id=940
* Not generating prototypes for functions that already have them.
  (Lars J. Nielsen).
  http://code.google.com/p/arduino/issues/detail?id=973
* Improved line numbers for error messages. (Paul Stoffregen)
  http://code.google.com/p/arduino/issues/detail?id=907
* Automatically create libraries folder in the sketchbook.
  (Paul Stoffregen)
  http://code.google.com/p/arduino/issues/detail?id=986
* Tutorial on installing libraries (linked from readme.txt in the
  libraries folder). (Limor Fried)
* Fix to allow selection of Norwegian. (Rune Fauske)
* Fix to race condition / occasional error in compilation. (gandrewstone)
  http://code.google.com/p/arduino/issues/detail?id=950
* Don't break long C++ comments during auto-format.
  http://code.google.com/p/arduino/issues/detail?id=255
[core / libraries]
* Included WiFi library and wifi shield firmware.
* Added ability to specify serial configuration (data bits, stop bits
  and parity check) in Serial.begin(). (Alarus)
  http://code.google.com/p/arduino/issues/detail?id=770
* Avoided overruns of the incoming serial (CDC) buffer on the Leonardo.
  (Peter Van Hoyweghen)
* Avoided auto-reset of the Leonardo when opening serial port after
  upload without specifying a baud rate. (Peter Van Hoyweghen)
* Fix for tone() on the Leonardo. (Shigeru Kanemoto)
  http://code.google.com/p/arduino/issues/detail?id=960
* Fix for SD library on Leonardo.
  http://code.google.com/p/arduino/issues/detail?id=931
* Added other write functions on Leonardo.
  http://code.google.com/p/arduino/issues/detail?id=958
* Added support for Leonardo interrupts 2 and 3. (Kristian Lauszus)
* Print ovf, inf, or nan accordingly in Serial.print(). (Nick Gammon)
  http://code.google.com/p/arduino/issues/detail?id=946
  http://code.google.com/p/arduino/issues/detail?id=961
  http://code.google.com/p/arduino/issues/detail?id=967
* Fix initialization of SPI data lines. (gandrewstone)
  http://code.google.com/p/arduino/issues/detail?id=888
* Serial.flush() waits for last byte to transmit. (michele.mazzucchi)
  http://code.google.com/p/arduino/issues/detail?id=871
* Adding overloads so Serial.write(0) works.
  http://code.google.com/p/arduino/issues/detail?id=1006
[build]
* Fix Linux arduino script when there are spaces in directory name.
* Pass Linux command line arguments from arduino script through to the
  Java code. (Allows specifying sketch to open on command line.)
[examples]
* Included examples for the starter kit.
testato
ma l'errore sul serial monitor per il quale si deve settare per forza l'inglese non doveva essere risolto su questa release ?
menniti
Leo, dobbiamo cambiare o aspettiamo un minimo....?
Articoli ElettronicaIN
leo72
Ti dirò di più, sulle versioni di sviluppo intermedie tra la 1.0.1 e la 1.0.2 il bug non c'era più. Come cavolo hanno fatto a farcelo rientrare nuovamente?  :smiley-sweat:
L'unica novità degna di nota è la possibilità di impostare il tipo di seriale (bit di dati, parità, bit di stop), per il resto questa 1.0.2 introduce il supporto a del nuovo HW ed i controlli per il 644P (manca sempre il bootloader).
Una cosa che ho notato è che questa versione mi pare crashi con facilità, per lo meno sul mio sistema. Ah, per dirla tutta non ho scaricato il pacchetto precompilato ma l'ho compilata dai sorgenti. Spesso crasha aprendo un esempio oppure aprendo una nuova finestra oppure ancora aprendo la seriale. Mah... Michele, per ora resta sulla 1.0.1, se ti funziona bene.
menniti
non volevo sentire altro XD
Pelletta
uwefed
chi é michele.mazzucchi?
testato
Me lo sono chiesto anche io, strano che non si senta sul forum visto che il nome è italiano
PaoloP
#8
Nov 06, 2012, 09:54 am Last Edit: Nov 06, 2012, 09:58 am by PaoloP Reason: 1
Hanno integrato la 1.0.2 nella 1.5.1.
--> https://github.com/arduino/Arduino/commit/23c7536dc76f34d72e585cc4edda20ccda1681a2
Stasera scarico e provo.
Vedrò se ci sono differenze con la build creata da me la settimana scorsa.  ;)
Nel changelog non c'è il fix della seriale del serial monitor.  :smiley-eek:
leo72
Che potete scaricare da qui:
http://arduino.cc/en/Main/SoftwareDue
Molto peggio! Leggi:
Il bug è tornato fuori nonostante nelle beta intermedie fosse stato corretto! Incredibile...  :smiley-roll-blue:
Madwriter
#10
Nov 06, 2012, 12:17 pm Last Edit: Nov 06, 2012, 12:19 pm by Madwriter Reason: 1
Nella mia azienda mi avrebbero fucilato per una cosa del genere  :smiley-yell:
ps chiamatemi antiquato ma io mi trovo bene con la mia 0.22  :D
PaoloP
Forse i troppi impegni...
Aspettiamo delucidazioni da Massimo Banzi.
EDIT: Ma secondo voi Massimo ha un alert sulla pronuncia del nome... come Lord Voldemort.  :smiley-mr-green:
Madwriter
tu scherzi ma guarda che è molto probabile  :smiley-mr-green:
testato
sicuramente c'e', perche' l'ho notata anche io questa cosa, ogni suo intervento se ci fate caso arriva se nel post e' stato scritto il suo nome.
Il che, attenzione, e' una buona cosa, e' bello vedere "Il Capo" in corsia  :)
Nell'IDE 1.0.1 era stato tolto il supporto ad ArduinoMicro, ora e' stato rimesso, quindi approfitto per fargli una domanda, ArduinoMicro quando verra' prodotta ? esistono gia' gli schemi o qualche foto ?
testato
Ma questo significa che possiamo usare la 1.5.1 anche con arduino UNO ?
