I m not good at java C. There are the code from the internet, it completely matched with the hardware no bugs, errors, library imported. I have test the hardware with the sample code from the arduino library, it's work on the ping client and server and sensors. However i cannot receive and transfer any data in the serial monitor. PLZ HELP me to combine the DHT11 and NRF24L01 code. Thank you very much!!!
http://arduino-info.wikispaces.com/nRF24L01-Mirf-ExamplesWiring
Nrf24L01 GND ¡V GND, VCC ¡V 3.3V, CS ¡V D8, CSN ¡V D9, SCK ¡V D10, MOSI ¡V D11, MISO ¡V D12, IRQ ¡V D13
DHT11 GND ¡V GND, VCC ¡V 3.3V, Data ¡V A0
Problems:
-Nrf24L01 cannot communication
-Nrf24L01 + DHT11 combine problem
-Is there any missing or config that i need?
Receive:
#include <Mirf.h>
#include <MirfHardwareSPIDriver.h>
#include <MirfSPIDriver.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <SPI.h>
Serial.begin(57600);
Mirf.init();
// name the receiving channel - must match tranmitter setting!
Mirf.setRADDR((byte *)"TX_01");
// just a single byte is transmitted
Mirf.payload = 1;
// we use channel 90 as it is outside of WLAN bands
// or channels used by wireless surveillance cameras
Mirf.channel = 90;
// now config the device....
Mirf.config();
// Set 1MHz data rate - this increases the range slightly
Mirf.configRegister(RF_SETUP,0x06);
byte c;
// is there any data pending?
if( Mirf.dataReady() )
// well, get it
Mirf.getData(&c);
// ... and write it out to the PC
Serial.print(c);
Sensor:
#include <Mirf.h>
#include <MirfHardwareSpiDriver.h>
#include <MirfSpiDriver.h>
#include <RF24.h>
#include <SPI.h>
// converts a float into a char
// and sends it via nRF24L01
void transmit( float v)
byte c;
char buf[10];
dtostrf(v,9,3,buf);
for( int i=0 ; i<8 ; i++ )
c = buf[i];
Mirf.send(&c);
while( Mirf.isSending() ) ;
// sends a string via the nRF24L01
void transmit(const char *string)
byte c;
for( int i=0 ; string[i]!=0x00 ; i++ )
c = string[i];
Mirf.send(&c);
// send a CR/LF sequence via the nRF24L01
void transmitlf(void)
byte c;
c = '\r';
Mirf.send(&c);
c = '\n';
Mirf.send(&c);
// init the transceiver
Mirf.init();
// we transmit only a single byte each time
Mirf.payload = 1;
// selecting a channel which is not too noisy
Mirf.channel = 90;
Mirf.config();
// Set address - this one must match the
// address the receiver is using!
Mirf.setTADDR((byte *)"TX_01");
float v01,v02;
// read in some values
v01 = analogRead(0);
v02 = analogRead(1);
// transmit a fixed token
transmit(" : ");
// transmit the first value
transmit(v01);
// transmit a separator
transmit(" : ");
// transmit a second token
transmit(v02);
// transmit a CR/LF for the PC
// software to sync to
transmitlf();
// ... just take your time
delay(100);
DHT11
#define dht_dpin 14
byte bGlobalErr;//for passing error code back from complex functions.
byte dht_dat[4];//Array to hold the bytes sent from sensor.
void setup(){
InitDHT();//Do what's necessary to prepare for reading DHT
delay(300);//Let system settle
Serial.println("Humidity and temperature\n\n");
delay(700);//Wait rest of 1000ms recommended delay before
//accessing sensor
}//end "setup()"
void loop(){
ReadDHT();//This is the "heart" of the program.
switch (bGlobalErr){
case 0:
Serial.print("Current humdity = ");
Serial.print(dht_dat[0], DEC);
Serial.print(".");
Serial.print(dht_dat[1], DEC);
Serial.print("% ");
Serial.print("temperature = ");
Serial.print(dht_dat[2], DEC);
Serial.print(".");
Serial.print(dht_dat[3], DEC);
Serial.println("C ");
case 1:
Serial.println("Error 1: DHT start condition 1 not met.");
case 2:
Serial.println("Error 2: DHT start condition 2 not met.");
case 3:
Serial.println("Error 3: DHT checksum error.");
default:
Serial.println("Error: Unrecognized code encountered.");
}//end "switch"
delay(800);//Don't try to access too frequently... in theory
}// end loop()
/*Below here: Only "black box" elements which can just be plugged unchanged
unchanged into programs. Provide InitDHT() and ReadDHT(), and a function
one of them uses.*/
void InitDHT(){
if (dht_dpin-14 != dht_PIN){Serial.println("ERROR- dht_dpin must be 14 more than dht_PIN");};//end InitDHT
pinMode(dht_dpin,OUTPUT);// replaces DDRC... as long as dht_dpin=14->19
digitalWrite(dht_dpin,HIGH);//Replaces PORTC |= if dht_pin=14->19
}//end InitDHT
void ReadDHT(){
bGlobalErr=0;
byte dht_in;
byte i;
// Send "start read and report" command to sensor....
// First: pull-down i/o pin for 18ms
digitalWrite(dht_dpin,LOW);//Was: PORTC &= ~_BV(dht_PIN);
delay(18);
delay(5);//TKB, frm Quine at Arduino forum
digitalWrite(dht_dpin,HIGH);//Was: PORTC |= _BV(dht_PIN);
delayMicroseconds(40);//DHT22 datasheet says host should
pinMode(dht_dpin,INPUT);//Was: DDRC &= ~_BV(dht_PIN);
dht_in=digitalRead(dht_dpin);//Was: dht_in = PINC & _BV(dht_PIN);
if(dht_in){
bGlobalErr=1; //Was: Serial.println("dht11 start condition 1 not met");
return;
}//end "if..."
delayMicroseconds(80);
if(!dht_in){
bGlobalErr=2;//Was: Serial.println("dht11 start condition 2 not met");
return;
}//end "if..."
for (i=0; i<5; i++)
dht_dat[i] = read_dht_dat();
pinMode(dht_dpin,OUTPUT);//Was: DDRC |= _BV(dht_PIN);
byte dht_check_sum =
dht_dat[0]+dht_dat[1]+dht_dat[2]+dht_dat[3];
/*Condition in following "if" says "if fifth byte from sensor
not the same as the sum of the first four..."*/
if(dht_dat[4]!= dht_check_sum)
bGlobalErr=3;
byte read_dht_dat(){
byte i = 0;
byte result=0;
for(i=0; i< 8; i++){
while(digitalRead(dht_dpin)==LOW);//Was: while(!(PINC & _BV(dht_PIN)));
delayMicroseconds(30);//AFTER pin is high, wait further period, to be
if (digitalRead(dht_dpin)==HIGH)//Was: if(PINC & _BV(dht_PIN))
result |=(1<<(7-i));// "add" (not just addition) the 1
while (digitalRead(dht_dpin)==HIGH);//Was: while((PINC & _BV(dht_PIN)));
}//end of "for.."
return result;
}//end of "read_dht_dat()"
