Loading...
Pages: 1 [2]   Go Down
Author Topic: Will these devices compatible with each other?  (Read 682 times)
Offline Offline
Newbie
View Profile
Okay, but it can be done with some kind of program what i upload to lilypad, right?
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
No you make a wiring change on one of the boards then you modify the code that drives that board.
Logged
Offline Offline
Newbie
View Profile
What do you mean "wiring change on one of the boards"?
Logged
Offline Offline
Newbie
View Profile
Well, I read a bit.
So maybe all of this will be work together. Only needs to manipulate things on the devices. Am I right? Somebody agree or disagree it please.
Logged
Online Online
Brattain Member
View Profile
WWW
I mean that the shields connect certain signals to certain pins. You will have to change one or more of these.
Take the boards you want, look at the signals they use and see what arduino pins they use. Draw this out and see if any boards need the same pins, they will.
Then look and see if you can change some. That is do they need any special functions that are only mapped to those specific pins. Try to resolve any clashes. Any pins you move you will have to make sure you move both the physical wires and any referance to them in the code or libary.
Logged
Offline Offline
Newbie
View Profile
So if I understand you, I need only to change the wires and rewrite something in the code. Right? So I can order them. Right?
Yes or no? smiley
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
