Loading...
Pages: [1]   Go Down
Author Topic: Help reading temperatur with the G_1396 ntc thermistor  (Read 391 times)
0
Offline Offline
Sr. Member
MEGA_Stick_II is here
View Profile
I need to read and display temperature from a G_1396 Thermistor
http://www.specsensors.com/pdfs/ntc_radial_glass.pdf
I'm not sure where to start, the temperature range is non-linear so not sure how to calculate the temp based on the voltage dropped across it.
Any help would be greatly appreciated. THANKS!!!
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
There is a formula for characterizing a thermistor.  You use the voltage across the thermistor to calculate the resistance and the formulas to calculate the temperature from the resistance.
http://www.daycounter.com/Calculators/Steinhart-Hart-Thermistor-Calculator.phtml
Logged
0
Offline Offline
Sr. Member
View Profile
Thanks! that helped.
Your post led me to this,
http://www.arduino.cc/playground/ComponentLib/Thermistor2
http://www.arduino.cc/playground/ComponentLib/Thermistor4
Think I have enough now to at least set something on fire.  smiley-twist
Thanks again!
EDIT
And here is a good tutorial
http://web.cecs.pdx.edu/~gerry/class/EAS199B/howto/thermistorArduino/thermistorArduino.pdf
« Last Edit: November 06, 2012, 07:43:36 am by Jassper » Logged
Pages: [1]   Go Up
Print
Jump to:
