Loading...
Pages: [1] 2 3   Go Down
Author Topic: IDE 1.5.1  (Read 3478 times)
Germany
Offline Offline
Full Member
View Profile
there is something wrong in the IDE
There are no Menueline and no Buttons and I get this error.
Quote
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: processing.app.Base.getBoardPreferences()Lprocessing/app/helpers/PreferencesMap;
   at processing.app.EditorLineStatus.paintComponent(EditorLineStatus.java:98)
   at javax.swing.JComponent.paint(JComponent.java:1029)
   at javax.swing.JComponent.paintChildren(JComponent.java:864)
   at javax.swing.JComponent.paint(JComponent.java:1038)
   at javax.swing.JSplitPane.paintChildren(JSplitPane.java:1030)
   at javax.swing.JLayeredPane.paint(JLayeredPane.java:567)
   at javax.swing.JComponent.paintToOffscreen(JComponent.java:5131)
   at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1475)
   at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1406)
   at javax.swing.RepaintManager.paint(RepaintManager.java:1220)
   at javax.swing.JComponent.paint(JComponent.java:1015)
   at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:21)
   at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:60)
   at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:97)
   at java.awt.Container.paint(Container.java:1780)
   at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
   at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:714)
   at javax.swing.RepaintManager.seqPaintDirtyRegions(RepaintManager.java:694)
   at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(SystemEventQueueUtilities.java:128)
   at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Did someone has an idea, IDE 1.5 works normal.
Logged
Offline Offline
Newbie
View Profile
I get the same error.
Logged
Forum Administrator
Milano, Italy
Offline Offline
Full Member
View Profile
WWW
Which IDE are you using (linux32/64, win or mac)?
Logged
C.
Germany
Offline Offline
Full Member
View Profile
Windows on an Win7 64bit
Logged
Offline Offline
Newbie
View Profile
Windows 8 64-bit.
Logged
Wahiawa, Hawaii
Online Online
Sr. Member
View Profile
I have a similar type errors with Windows XP Pro SP3 and another Windows XP Home SP3.
Code:
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5124)
at javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManager.java:278)
at javax.swing.JComponent._paintImmediately(JComponent.java:5072)
at javax.swing.JComponent.paintImmediately(JComponent.java:4882)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:826)
Logged
Forum Administrator
Milano, Italy
Offline Offline
Full Member
View Profile
WWW
Ok ok! i found the problem!
It was my last windows build that contains an error, probably a not perfectly clean build environment (i should always clean before doing the actual build, my distraction sorry smiley-sad)
I must setup a build-bot as soon as possible to avoid such errors in the future.
Uploading a fixed version right now, it will be available in a couple of minutes.
Logged
C.
Forum Administrator
Milano, Italy
Offline Offline
Full Member
View Profile
WWW
here we go:
https://github.com/downloads/arduino/Arduino/arduino-1.5.1r2-windows.zip
please confirm if this solves your issues.
Logged
C.
Wahiawa, Hawaii
Online Online
Sr. Member
View Profile
Yep, that fixed it for Windows XP Home SP3.
Logged
Germany
Offline Offline
Full Member
View Profile
Yes solve my problem on Win7 64bit
Logged
0
Offline Offline
Newbie
Arduino DUE rocks
View Profile
Still not fixed the load examples problem from certain libraries I reported before if on preferences the default path to sketchbook is changed !!!
This is really anoying as I could load directly all my sketchs from the sketchbook menu insted of having to do "Open", browsing to whatever directory to load them.
Logged
Check all my projects based on Atmel/Arduino -> www.aqualed-light.com
Offline Offline
Newbie
View Profile
Solved the problem on Win8 64 bit.
Logged
Offline Offline
Newbie
View Profile
Not fun. (Newest from git, linux64)
Logged
Offline Offline
Newbie
View Profile
here we go:
Sweet, fixed mine as well.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Cannot launch Due IDE 1.5.1 on OS/X (10.7.5):
Just downloaded a few minutes ago.
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
