Pages: [1] 2 3   Go Down
Author Topic: IDE 1.5.1  (Read 3647 times)
Germany
there is something wrong in the IDE
There are no Menueline and no Buttons and I get this error.
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: processing.app.Base.getBoardPreferences()Lprocessing/app/helpers/PreferencesMap;
   at processing.app.EditorLineStatus.paintComponent(EditorLineStatus.java:98)
   at javax.swing.JComponent.paint(JComponent.java:1029)
   at javax.swing.JComponent.paintChildren(JComponent.java:864)
   at javax.swing.JComponent.paint(JComponent.java:1038)
   at javax.swing.JSplitPane.paintChildren(JSplitPane.java:1030)
   at javax.swing.JLayeredPane.paint(JLayeredPane.java:567)
   at javax.swing.JComponent.paintToOffscreen(JComponent.java:5131)
   at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1475)
   at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1406)
   at javax.swing.RepaintManager.paint(RepaintManager.java:1220)
   at javax.swing.JComponent.paint(JComponent.java:1015)
   at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:21)
   at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:60)
   at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:97)
   at java.awt.Container.paint(Container.java:1780)
   at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
   at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:714)
   at javax.swing.RepaintManager.seqPaintDirtyRegions(RepaintManager.java:694)
   at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(SystemEventQueueUtilities.java:128)
   at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Did someone has an idea, IDE 1.5 works normal.
I get the same error.
Forum Administrator
Milano, Italy
Which IDE are you using (linux32/64, win or mac)?
C.
Germany
Windows on an Win7 64bit
Windows 8 64-bit.
Wahiawa, Hawaii
I have a similar type errors with Windows XP Pro SP3 and another Windows XP Home SP3.
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5124)
at javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManager.java:278)
at javax.swing.JComponent._paintImmediately(JComponent.java:5072)
at javax.swing.JComponent.paintImmediately(JComponent.java:4882)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:826)
Forum Administrator
Milano, Italy
Ok ok! i found the problem!
It was my last windows build that contains an error, probably a not perfectly clean build environment (i should always clean before doing the actual build, my distraction sorry smiley-sad)
I must setup a build-bot as soon as possible to avoid such errors in the future.
Uploading a fixed version right now, it will be available in a couple of minutes.
C.
Forum Administrator
Milano, Italy
here we go:
https://github.com/downloads/arduino/Arduino/arduino-1.5.1r2-windows.zip
please confirm if this solves your issues.
C.
Wahiawa, Hawaii
Yep, that fixed it for Windows XP Home SP3.
Germany
Yes solve my problem on Win7 64bit
Arduino DUE rocks
Still not fixed the load examples problem from certain libraries I reported before if on preferences the default path to sketchbook is changed !!!
This is really anoying as I could load directly all my sketchs from the sketchbook menu insted of having to do "Open", browsing to whatever directory to load them.
Check all my projects based on Atmel/Arduino -> www.aqualed-light.com
Solved the problem on Win8 64 bit.
Not fun. (Newest from git, linux64)
here we go:
Sweet, fixed mine as well.
Melbourne, Australia
Shannon Member
Lua rocks!
Cannot launch Due IDE 1.5.1 on OS/X (10.7.5):
Just downloaded a few minutes ago.
Pages: [1] 2 3   Go Up
