Loading...
Pages: 1 [2]   Go Down
Author Topic: Read filename from SD card, store to a string  (Read 688 times)
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Where is this from?
Left field. I thought you were trying to read the name FROM a file, not the name OF a file.
Logged
Milton Keynes UK
Offline Offline
Tesla Member
View Profile
Crap ok, found it.
I was using these:
//Add the SdFat Libraries
#include <SdFat.h>
#include <SdFatUtil.h>
not the base SD library.
I see available() now too.
Thanks
If you'd posted your actual code (in its entirety), we'd have known that.
Logged
NZ
Offline Offline
Sr. Member
Turtle in a hard shell
View Profile
I did say in post #1 I am using the SDFAT library, not the SD library. Also posted pieces of the SDFAT functions. I didnt even know there was a SD library 'wrapper' or whatever its called to be honest.
Tried implmenting the SD library instead, but its not compiling. Looks like the 2012 SDFAT library I am using is not quite the same as the 2009 SDFAT library which is part of the SD library included with Arduino 1.01
No luck so far, will keep trying.
« Last Edit: November 06, 2012, 05:26:09 pm by WanaGo » Logged
Milton Keynes UK
Offline Offline
Tesla Member
View Profile
It's easy to find excuses not to, or reasons why we should have guessed or noticed some quirk of your solution, but there's simply no substitute for posting your actual code when you need help with a coding problem.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
