Loading...
Pages: [1]   Go Down
Author Topic: How to use PORTD,PORTB in Arduino ADK Mega  (Read 594 times)
Offline Offline
Newbie
View Profile
 Hello everybody
Code:
// Example 43.1
// tronixstuff.wordpress.com/tutorials > chapter 43
// John Boxall - October 2011
// Digital 0~7 set to outputs, then on/off using port manipulation
//http://tronixstuff.wordpress.com/2011/10/22/tutorial-arduino-port-manipulation/
  DDRD = B11111111; // set PORTD (digital 7~0) to outputs
  PORTD = B11110000; // digital 4~7 HIGH, digital 3~0 LOW
  PORTD = B00001111; // digital 4~7 LOW, digital 3~0 HIGH
This code run good with Arduino ATMega32 ,but can not run with Arduino ADK Mega
I don't know why ?
Can you help me ?
Thanks.
« Last Edit: November 06, 2012, 06:36:18 pm by taipscode » Logged
Offline Offline
Newbie
View Profile
Hello John,
Have you found a solution? I have a similar situation: For an Arduino UNO project I'm using the PIND variable. In the UNO PORTD maps to Arduino digital pins 0 to 7. PIND is a variable for the Port D Input Pins Register - read only. I need the same information for the Mega ADK board - what is the equivalent variable for the digital input pin register 0 - 7?
thanks,
andrew
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Hello John,
thanks,
andrew
https://spreadsheets.google.com/pub?key=rtHw_R6eVL140KS9_G8GPkA&gid=0
Logged
Offline Offline
Newbie
View Profile
Hello,
I have an Arduino ADK board. I'm trying to use a built-in variable to monitor the digital input pins. For example, on my Arduino UNO
PIND - The Port D Input Pins Register - read only
With the UNO I can use the PIND variable successfully to monitor activity on the pins 0-7. However, this is not working with the ADK board. Although the "PIND" variable is defined I don't know what it maps to and I cannot find the info. For the UNO, there is this web page:
http://www.arduino.cc/en/Reference/PortManipulation
However, the page doesn't include the ADK's ATmega2560. How can I find the correct variable to use (if there even is one)?
Thanks,
andrew
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
In any case, this is not an installation and troubleshooting issue.
Threads merged.
- Moderator
Logged
Pages: [1]   Go Up
Print
Jump to:
