Loading...
Pages: 1 [2]   Go Down
Author Topic: Data syncing  (Read 1118 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
Just a caution for those looking at using the PPS to sync remote data things, not all GPS modules or GPS shields provide PPS output so look at the docs carefully.  I am using Maestro GPS 1035 and 2035 modules about $20 and $18 from Mouser they work great and the price can't be beat.  The 1035 and 2035 are surface mount units and need to either go on a breakout board of a shield to use them with Arduinos, they skillet reflow very nicely but you will need to fab a board first.
wade
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
Quote
It's even possible, however unlikely, that you are the one that made the mistake.
See post #10 in this thread.
Logged
Something different - Kitchen-Sink Arduino-compatible boards
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
The Rx and TX pins on the XBee are 5V tolerant. Powering the XBee from 3.3V, and connecting it to 5V TX is fine.
Connecting 5V to other pins on the XBee is not, because only the RX and TX pins are 5V tolerant.
Logged
Offline Offline
Edison Member
View Profile
WWW
OK, I'll bite. Show me on the documentation where it says 5V tolerant.
http://www.digi.com/products/wireless-wired-embedded-solutions/zigbee-rf-modules/point-multipoint-rfmodules/xbee-series1-module#docs
http://ftp1.digi.com/support/documentation/90000982_H.pdf
Logged
Offline Offline
Edison Member
View Profile
WWW
Quote
Quote
Since you didn't answer the question, I will. The datasheets for series 1 and 2 XBee say nothing about
Din pins being 5V tolerant. These are the modules Faludi talks about in his book. Not only that, but the
very first schematic in Faludi's book, fig 1-10, is wrong. He has Rx and Tx wired backwards.
On some of the "newer" XBee modules, the Din pin is 5V tolerant. So we have a pretty poor situation
here, some are and some are not 5V tolerant. You have to be very careful what you're doing, how you're
hooking them up, and how you're mixing and matching.
Logged
Offline Offline
Newbie
View Profile
Ok, I got it.  I used some code from Principia Labs "MultiJoy" sketch to keep the wireless data organized.  He uses the term "error protection".   Anyway, if anyone cares here is the code I used:
Handheld:
Code:
//  Original code borrowed from "Blink without delay"
//  and "Multijoy" by Principia Labs
const int buttonPin = 2;     // the number of the pushbutton pin
const int LEDPin =  12;      // the number of the LED pin
int LEDButton = 9;           // LED on Pin 9 assigned to button
int LEDSync = 11;            // LED on Pin 11 assigned to button
int buttonState = 0;         // variable for reading the pushbutton status
int pinState = LOW;          // set initial state of pin
int t = 0;                   // switching variable
// Import the Arduino Servo library
#include <Servo.h>
// User input for servo and position
int userInput[3];    // raw input from serial buffer, 3 bytes
int startbyte;       // start byte, begin reading input
int servo;           // which servo to pulse?
int pos;             // servo angle 0-180
int i;               // iterator
void setup(){
  // Initialize outputs
  pinMode(LEDButton, OUTPUT);        //  set pin named "LEDButton" as output
  pinMode(LEDSync, OUTPUT);
  pinMode(LEDPin, OUTPUT);
  pinMode(buttonPin, INPUT);         //  set pin named "buttonPin" as input
buttonState = digitalRead(buttonPin);
    if (buttonState == HIGH) {
      if (t == 0) {
        Serial.print(char(255));        // error protection
        Serial.print(char(99));         // send command for "case 99"
        Serial.print(char(180));        // send state command
        digitalWrite(LEDPin, HIGH);
        t = 1;
    else {
      if (t == 1) {
        Serial.print(char(0));          // send state command
        digitalWrite(LEDPin, LOW);
        t = 0;
  Serial.begin(9600); //set baud rate on Arduino to 9600
void loop(){
  // Wait for serial input (min 3 bytes in buffer)
  if (Serial.available() > 2) {
    // Read the first byte
    startbyte = Serial.read();
    // If it's really the startbyte (255) ...
    if (startbyte == 255) {
      // ... then get the next two bytes
      for (i=0;i<2;i++) {
        userInput[i] = Serial.read();
      // First byte = servo to move?
      servo = userInput[0];
      // Second byte = which position?
      pos = userInput[1];
      // Packet error checking and recovery
      if (pos == 255) { servo = 255; }
      // Assign new position to appropriate servo
      switch (servo) {
        //  Upon receiving signal from the other units
        //  determine the case number and the condition
        //  and set the corresponding pinstate.
        case 98:
          if (pos == 180) {
            if (pinState == LOW)
                pinState = HIGH;
            else pinState = LOW;
          if (pos == 0) {
            pinState = LOW;
          digitalWrite(LEDButton, pinState);
        case 97:
          if (pos == 180) {
                pinState = HIGH;
          if (pos == 0) {
            pinState = LOW;
          digitalWrite(LEDSync, pinState);
      if (t == 0) {                         //  switching variable allows only one loop per state change
        Serial.print(char(255));            //  error control
        digitalWrite(LEDPin, HIGH);         //  turn the LED on
        t = 1;                              //  if buttonState HIGH and t = 0, do the above and change "t" to 1
    else {
      if (t == 1) {
        digitalWrite(LEDPin, LOW);          // turn the LED off
        t = 0;
The handheld transmits a signal to Logger 1 and also receives a signal from Logger 1 as confirmation that you are still in range.
« Last Edit: November 06, 2012, 11:55:15 am by tt_tony » Logged
Offline Offline
Newbie
View Profile
Transceiver Unit:
Code:
int LEDButton = 9;              // Button LED on Pin 9 named LEDButton
const int LEDBlink =  11;       // the number of the sync LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;        // will store last time LED was updated
// the following variables are "long" because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 10000;          // Off time for Sync LED (milliseconds)
long interval2 = 500;           // On time for Sync LED (milliseconds)
#include <Servo.h>
int i;               // iterator
int pinState = LOW;  //Initial pinstate set
   // LED on Pin 11 for digital on/off demo
  pinMode(LEDBlink, OUTPUT);
  // LED on Pin 9 for digital on/off demo
  // Open the serial connection, 9600 baud
      for (i=0;i<2;i++) {
      // First byte = LED to control?
      // Second byte = On or off?
      pos = userInput[1];
      // Assign new position to appropriate servo (LED)
      switch (servo) {
        case 99:
          if (pos == 180) {
                pinState = HIGH;
                Serial.print(char(98));         // send command for "case 98"
            else {
              pinState = LOW;
          if (pos == 0) {
            pinState = LOW;
  unsigned long currentMillis = millis();    // "millis" is an internal timer that
                                             //  starts running on power up
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW){
      ledState = HIGH;
      Serial.print(char(97));         // send command for "case 97"
    else {
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(LEDBlink, ledState);
    else if(currentMillis - previousMillis > interval2) {
    if (ledState == HIGH){
      ledState = LOW;
    previousMillis = currentMillis;  }
This code receives the signal from the handheld and relays it to Transceiver 2.  It also sends a signal to the handheld as confirmation.
Logged
Offline Offline
Newbie
View Profile
Receiving Unit:
Code:
#include <Servo.h>
int i;               // iterator
// LED on Pin 51 assigned to button
int LEDButton = 9;
int LEDSync = 11;
int pinState = LOW;
  // LED on Pin 53 for digital on/off demo
void loop() { // loop program
      for (i=0;i<2;i++) {
      pos = userInput[1];
      switch (servo) {
        case 98:
          if (pos == 180) {
                pinState = HIGH;
          if (pos == 0) {
            pinState = LOW;
        case 97:
          if (pos == 180) {
                pinState = HIGH;
          if (pos == 0) {
            pinState = LOW;
This code allows the second unit to receive the relayed signal from the first unit.
Logged
Offline Offline
Edison Member
View Profile
WWW
How do you have the 3 XBees configured? All in broadcast mode?
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
