Topic: Ebay WIFI module (Read 12371 times) previous topic - next topic
pepemanuer
Nov 06, 2012, 09:12 pm Last Edit: Nov 06, 2012, 09:28 pm by pepemanuer Reason: 1
What's your opinion about this wifi module?
http://www.ebay.es/itm/WiFi-Module-Shield-for-Arduino-Connect-UART-WiFi-module-with-Arduino-easily-/130721771260?pt=LH_DefaultDomain_0&hash=item1e6f9feefc
It´s a TLG10UA03
More information here
http://www.emartee.com/product/42121/Stackable%20Uart%20WiFi%20Module%20Kit
pylon
Did you notice that the offer you linked to does not include the WiFi module but only the adapter shield?
pepemanuer
Frédéric_Plante
This module Rock by the way. Only problem, it as to be alimented from outside. The Arduino offer 50mA on 3,3 volt and the TLG10UA03 need 300mA on 3,3volt. That's why the linking shield has a external plug to hook it  on outside alimentation.
But it's great. If you know how to handle AT command, it's just as flexible as the official shield, except that it communicate with Arduino using USART serial port instead of the SPI port.
TCP IP stacking is built in, and it can be configure from AT command or there is an AUTO mode that can be configure from a web page contained in the module.
As we fight our way northward into the great unknown, only that one thing remains certain...
tack
A different, and less expensive approach:-
Use a standard ethernet shield, or module, together with a TP-Link WR702N Nano in Client mode. This will convert your wired connection to wireless painlessly.
You could then just set up your server using the numerous examples available for ethernet.
Use standard ethernet library (Ethernet.h) for W5100 based and UIP Ethernet librsry (UIPEthernet.h) for ENC28J60 based.
The sketch code is identical for both libraries. You can thus switch device types by simply changing the #include for the library. This also allows you to develop on an Arduino + W5100 based shield and easily swap to an ENC28J60 module for any final discrete build.
Frédéric_Plante
#5
Dec 20, 2013, 10:45 pm Last Edit: Dec 20, 2013, 11:51 pm by Frédéric_Plante Reason: 1
n theory I would agree with you as long your project is supposed ton sit on a table and has a power supply hooked on the wall.
Personally, I prefers this little module, that is about the size of a finger. I don't use it with the shield so it's very very space wise.
Other thing, you can eazely adapt the WiFi or Ethernet library to work it with the module, since in many way the TLG work the same way except for the fact that it communicate with Arduino using the serial port. So basically you adapt it to send the same stuff but Serial way.
The ENC28J60 is totally off subject since there is not TCPIP stacking built in so let's just pass that part, it's gonna require half of you Arduino programming space just for the external stacking.
But what I really like about the TLG unit, is that in fact it does not even need a Ardunio to work. I've tried to hook a GPS, a Bluetooth module, a external US Robotic Modem using a RS232 to ttl module, and many other serial device on the TLG serial port, and they all worked fine sending and receiving there stuff on the net.  It's completely stand alone, the fact that Arduino can use it, is just a plus.
In fact, it even has a GPIO programmable from the network using telnet or locally sending  AT command in the serial port.  It's as simple to use then saying ATA to a modem when the phone ring.
So by the end, a simple web server saying Hello World take about 3k of program space. It require only 2 wires to communicate with Arduino AND considering the GPIO, you can say that you gain back one of the two wires on the TLG device side.
I'm the kind of guy who prefers module over shield, especially because I can choose what i can hook where. And to me this module is way way better the any shield I've tried so far.
Finally this module alone cost about 14$, compare to a minimum of 10$ for the W5100 shield + i don't know how much for the TP-Link WR702N Nano , but it has to be less then 6$ to beat the TLG unit.
http://www.amazon.com/Ethernet-Shield-Micro-sd-Arduino-Duemilanove/dp/B00GIDHZHE/ref=sr_1_5?s=electronics&ie=UTF8&qid=1387578646&sr=1-5&keywords=w5100+ethernet+shield
20 buck on amazon, Nah, not worth it Sorry
http://www.amazon.com/TP-LINK-TL-WR702N-Wireless-Repeater-150Mpbs/dp/B007PTCFFW
For the WR702N plus the W5100 shield, I get 2 TLG unit an extra module of my choice, all that  shipping included.
So i might conclude by saying for those who prefer shield that the adapter shield is 15$, the TLG module is usually around 14$ So for the same price you have the TLG set(shield + module). But to me because the TLG unit is so stand alone, you get more for your money with the TLG option. You will learn more, and Have more fun.
But, if your the Mac kinda persone, and you just want to hook and look at it work, with out work, go for the W5100, it's ease to use all is ready and there is no challenge, but also nothing to learn.
I'm the PC kinda guy, I like to build program and learn stuff. Every one is different.
Frédéric_Plante
#6
Dec 21, 2013, 12:09 am Last Edit: Dec 21, 2013, 05:26 am by Frédéric_Plante Reason: 1
By the way, I've learn a interesting fact.
This example is the generic example that come with the module in automatic mode( the server is preconfigure on on the config web page of the TLG unit has a TCP host on some port you choose)
Code: [Select]
boolean currentLineIsBlank = true;
while(1){
if (Serial.available()) {
char c = Serial.read();
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == 'n' && currentLineIsBlank) {
// send the webpage
Serial.println("HTTP/1.1 200 OKrnContent-Type: text/htmlrnrn<center><h1>Hello World!! I am WiFi WebServer!!!</h1></center>");
if (c == 'n') {
// you're starting a new line
else if (c != 'r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
If you use a Méga256, and if you have not update the boot loader, this line will cause fault when you upload you sketch
Code: [Select]
Just remove 1 of the "!" in the string cause there seem to be a bug in the original boot loader, it does not accept "!!!" in a string.
tack
Have you got a link to that module @ $14? I may have to go get one to have a play. ;-)
Frédéric_Plante
#8
Dec 21, 2013, 03:13 am Last Edit: Dec 21, 2013, 03:15 am by Frédéric_Plante Reason: 1
lol ;)
Check on ali that were i got mine.
I payd like 12 buck but the lady ran out, I know there are some at 14 that have see today
Tcheck for UART WIFI. they will come up
Frédéric_Plante
#9
Dec 21, 2013, 03:16 am Last Edit: Dec 21, 2013, 03:19 am by Frédéric_Plante Reason: 1
tack
Thanks for that Frederic. I have just ordered 2 to play with. :-)
Frédéric_Plante
#11
Dec 21, 2013, 05:03 am Last Edit: Dec 21, 2013, 05:15 am by Frédéric_Plante Reason: 1
Go to the second link that  pepemanuer left, well there basicaly:
Cause the documentation is full a cool details, and you got lot of reading a head of you. There are about 30 AT command to read about, very very configuable using the AT command.
You got lot of fun coming up, i'm happy for you.
May I suggest you get your self a terminal software to test some AT command "script" you could wish to try, By experience, it's messy to upload to the Arduino to see if a series of command does what you want to do.
Personally I like to use this guy:
http://realterm.sourceforge.net/
For this and many other serial need. It's full a neat stuff integrated to the terminal.
Frédéric_Plante
Hey Tack! Got your modules yet?
clubman
Hi Frederic, I would like to be able to control my Arduino over wifi, ie digital pins ie.
Is the module from aliexpress all I need? I would prefer not to mess with spacious shields etc. Is there a way to connect it or do I need a shield? Do you have any schematics?
Thank you
Nick
Frédéric_Plante
#14
Jan 28, 2014, 07:39 pm Last Edit: Jan 28, 2014, 08:49 pm by Frédéric_Plante Reason: 1
Well if you only need to control some ports, like turning on and off a few relay, for example, yes this module will do the job with eaze. Once you have configure the device to connect it on your wifi hub or configure it to host an adhoc connection, it become just like a serial over tcpip bridge, well that is what it is any way.
So what i'm saying is any serial example you can find in the IDE will work. Except that you will need to use a telnet client, instead of a serial terminal, to access it. Unless you setup a second tlg device to hook on your computer serial port. Then it would be completely transparent and then you could use a serial terminal. So basicaly with one tlg device you use telnet, with two you use serial terminal.
But in bolth case, you need to have some understanding of AT command. But honestly it's pretty much like setting up a bluetooth connection. The only thing is that there is lot more AT commands. Some will say that it give more flexibility, other will say it is more complicated. In any case, once the connection is setup, it become just like any serial connection on the point of vue of Arduino.
