Topic: Building a CAN API for Arduino DUE (Read 368498 times) previous topic - next topic
jspobuk
Yes, I believe J1939 is a higher level than just the signals, but it does utilize the extended id.  I guess what I am trying to do first is just get the raw data, even though I might not know exactly what it means.  The only CAN thing I have is a dynaGen GSC 400.  There is a J1939 plug, and the manual is not very helpful about... well... anything.  Right now I am just trying to get my arduino to send extended id messages to itself.  So I tweaked the first example.  Here is my code:
Code: [Select]
// Required libraries
#include "variant.h"
#include <due_can.h>
#include <sn65hvd234.h>
#define TEST1_CAN_COMM_MB_IDX    0
#define TEST1_CAN_TRANSFER_ID    0xFEEE00
#define TEST1_CAN0_TX_PRIO       0
#define CAN_MSG_DUMMY_DATA       0x55AAAA55
// CAN frame max data length
#define MAX_CAN_FRAME_DATA_LEN   8
// Message variable to be send
uint32_t CAN_MSG_1 = 0;
  // start serial port at 9600 bps:
  Serial.println("Type CAN message to send");
  while (Serial.available() == 0);
void loop(){
  while (Serial.available() > 0) {
    CAN_MSG_1 = Serial.parseInt();
    if (Serial.read() == '\n') {
      Serial.print("Sent value= ");
      Serial.println(CAN_MSG_1);
  CAN.reset_all_mailbox();
  CAN2.reset_all_mailbox();
  // Initialize CAN0 and CAN1, baudrate is 1Mb/s
  CAN.init(SystemCoreClock, CAN_BPS_1000K);
  CAN2.init(SystemCoreClock, CAN_BPS_1000K);
  // Initialize CAN1 mailbox 0 as receiver, frame ID is 0x07
  CAN2.mailbox_init(0);
  CAN2.mailbox_set_mode(0, CAN_MB_RX_MODE);
  CAN2.mailbox_set_accept_mask(0, 0, true);
  CAN2.mailbox_set_id(0, 0, true);
  // Initialize CAN0 mailbox 0 as transmitter, transmit priority is 15
  CAN.mailbox_init(0);
  CAN.mailbox_set_mode(0, CAN_MB_TX_MODE);
  CAN.mailbox_set_priority(0, TEST1_CAN0_TX_PRIO);
  CAN.mailbox_set_accept_mask(0, 0, true);
  // Prepare transmit ID, data and data length in CAN0 mailbox 0
  CAN.mailbox_set_id(0, TEST1_CAN_TRANSFER_ID, true);
  CAN.mailbox_set_datal(0, CAN_MSG_1);
  //CAN.mailbox_set_datah(0, CAN_MSG_DUMMY_DATA);
  CAN.mailbox_set_datalen(0, MAX_CAN_FRAME_DATA_LEN);
  // Send out the information in the mailbox
  CAN.mailbox_send_transfer_cmd(0);
  // Wait for CAN1 mailbox 0 to receive the data
  while (!(CAN2.mailbox_get_status(0) & CAN_MSR_MRDY)) {
  RX_CAN_FRAME incoming;
  // Read the received data from CAN1 mailbox 0
  CAN2.mailbox_read(0, &incoming);
  Serial.println("CAN message received= ");
  Serial.print("ID:");
  Serial.println(incoming.id);
  Serial.print("FID:");
  Serial.println(incoming.fid);
  Serial.print("RTR:");
  Serial.println(incoming.rtr);
  Serial.print("IDE:");
  Serial.println(incoming.ide);
  Serial.print("DLC:");
  Serial.println(incoming.dlc);
  Serial.print("DATA:");
  Serial.print(incoming.data[0]);
  Serial.print(incoming.data[1]);
  Serial.print(incoming.data[2]);
  Serial.print(incoming.data[3]);
  Serial.print(incoming.data[4]);
  Serial.print(incoming.data[5]);
  Serial.print(incoming.data[6]);
  Serial.println(incoming.data[7]);
  // Disable CAN0 Controller
  CAN.disable();
  // Disable CAN1 Controller
  CAN2.disable();
  Serial.print("End of test");
  while (1) {
and my output on the serial monitor below.  Notice the Data is all zeroes.  This the case no matter what i put in.  Any ideas of why I can't get the data through?
Thanks!
jspobuk
So I figured out my problem.  I needed to put a
CAN.global_send_transfer_cmd(CAN_TCR_MB0);
instead of
Success! Now I can actually try to do something with this.  I'm going to try to send some info to my DynaGen GSC 400.  If anyone has any knowledge of doing such things hit me up, otherwise I'll keep ya'll posted.
Rich_P
Hi All.
First off, Fantastic Effort.
I am having real trouble getting the example 1 to compile,
Getting a lot of errors that i think stem from incorrect Variant file, does anyone have the variant file i need? as i cant find it on Collins Git page
Cheers
Rich
Palliser
Hello Rich,
Please see my reply #181.
http://forum.arduino.cc/index.php?topic=131096.181
Regards,
Wilfredo
jspobuk
Hey Rich,
Check out Replies 229-231 also.  I was getting a bunch of errors too at first.
jspobuk
So just an update on the J1939 endeavor.  I was able to find several parameters and PGN's to test.  However, most of them are just to read information not necessarily change throttle speed or even send stop/start signals.  In the picture you can see the Eng. Temp and Hours as N/A and 0.0 respectively.  I was able to send fake data on the bus and have the Dyna Gen pick it up and display it.  Pretty much made my day.
All in all this due is pretty awesome.  Thanks again to all those who worked on putting together the library! Now if only SAE and manufacturers would give access to all the PGN's and detailed descriptions of what each block of data does.  I could do a lot more.  But I'm just glad it worked.  So that's the scoops, and the next step is actually using the Due in a real application.
Rich_P
Hi Thanks for the VAriant Files,
I replaced the standard arduino Variant Files with these and i still cant compile it,
The first error is that variant.h doesnt exist. i have checked spelling of the file and location (in the variants folder i assuem?) seems ok
See below, i am completely confused, i dont usually have issues like this but i have not used the due much as of yet,
Code: [Select]
Arduino_Due_CAN_Sample_1.ino:7:21: error: variant.h: No such file or directory
In file included from \\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:72,
                from Arduino_Due_CAN_Sample_1.ino:8:
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/sn65hvd234.h:34: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/sn65hvd234.h:37: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/sn65hvd234.h:39: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/sn65hvd234.h:40: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/sn65hvd234.h:41: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/sn65hvd234.h:43: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/sn65hvd234.h:44: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/sn65hvd234.h:46: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/sn65hvd234.h:47: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/sn65hvd234.h:48: error: expected `)' before 'Rs'
In file included from Arduino_Due_CAN_Sample_1.ino:8:
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:76: error: 'uint8_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:77: error: 'uint8_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:129: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:130: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:131: error: 'uint8_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:132: error: 'uint8_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:144: error: 'uint8_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:151: error: ISO C++ forbids declaration of 'Can' with no type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:151: error: expected ';' before '*' token
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:159: error: 'uint16_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:160: error: 'uint16_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:161: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:161: error: 'uint32_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:167: error: expected `)' before '*' token
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:213: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:213: error: 'uint16_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:214: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:215: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:216: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:217: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:218: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:219: error: 'uint32_t' does not name a type
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:220: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:220: error: 'uint32_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:221: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:222: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:222: error: 'uint32_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:223: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:224: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:225: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:226: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:226: error: 'uint32_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:227: error: 'uint8_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:227: error: 'uint32_t' has not been declared
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\libraries\due_can/due_can.h:232: error: 'uint32_t' does not name a type
Arduino_Due_CAN_Sample_1.ino: In function 'void loop()':
Arduino_Due_CAN_Sample_1:39: error: 'class CANRaw' has no member named 'init'
Arduino_Due_CAN_Sample_1:39: error: 'SystemCoreClock' was not declared in this scope
Arduino_Due_CAN_Sample_1:40: error: 'class CANRaw' has no member named 'init'
Arduino_Due_CAN_Sample_1:60: error: 'CAN_TCR_MB0' was not declared in this scope
Arduino_Due_CAN_Sample_1:63: error: 'class CANRaw' has no member named 'mailbox_get_status'
Arduino_Due_CAN_Sample_1:63: error: 'CAN_MSR_MRDY' was not declared in this scope
Arduino_Due_CAN_Sample_1:68: error: 'class CANRaw' has no member named 'mailbox_read'
Arduino_Due_CAN_Sample_1:70: error: 'struct RX_CAN_FRAME' has no member named 'data'
Arduino_Due_CAN_Sample_1:71: error: 'struct RX_CAN_FRAME' has no member named 'data'
Arduino_Due_CAN_Sample_1:72: error: 'struct RX_CAN_FRAME' has no member named 'data'
Arduino_Due_CAN_Sample_1:73: error: 'struct RX_CAN_FRAME' has no member named 'data'
Arduino_Due_CAN_Sample_1:74: error: 'struct RX_CAN_FRAME' has no member named 'data'
Arduino_Due_CAN_Sample_1:75: error: 'struct RX_CAN_FRAME' has no member named 'data'
Arduino_Due_CAN_Sample_1:76: error: 'struct RX_CAN_FRAME' has no member named 'data'
Arduino_Due_CAN_Sample_1:77: error: 'struct RX_CAN_FRAME' has no member named 'data'
Palliser
#262
Jul 30, 2013, 03:15 pm Last Edit: Jul 30, 2013, 03:26 pm by Palliser Reason: 1
Hello Rich,
I would recommend you to move (cut and paste) the CAN library folder 'due_can' from
Quote
to
Quote
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\hardware\arduino\sam\libraries\
Please, let me know.
EDIT:
Remember also that the variant files should be located at:
Quote
\\fs02\users\richardpel\arduino-1.5.2-windows\arduino-1.5.2\hardware\arduino\sam\variants\arduino_due_x
djusthof
I just downloaded arduino 1.5.2, downloaded CAN library from GitHub, also updated the variant file just like the last posts indicated but still getting all kinds of errors when I try to run a sketch. Are there more files that I need to be updating within arduino 1.5.2?
Thanks
Palliser
Hello djusthof,
Could you show us part of the errors you are getting? Thanks.
djusthof
when i try to compile this
Code: [Select]
Here is part of the error,
Code: [Select]
In file included from sketch_jul31a.ino:1:
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:9: error: stray '\302' in program
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:9: error: stray '\267' in program
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:314: error: invalid suffix "b4c26c6e36e6baaed686d0d5c3666b" on integer constant
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:315: error: invalid suffix "b4c26c6e36e6baaed686d0d5c3666b" on integer constant
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:369: error: too many decimal points in number
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:373: error: too many decimal points in number
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:377: error: too many decimal points in number
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:426: error: invalid digit "9" in octal constant
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:430: error: invalid digit "8" in octal constant
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:466: error: invalid digit "9" in octal constant
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:470: error: invalid digit "8" in octal constant
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:498: error: too many decimal points in number
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:502: error: too many decimal points in number
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:522: error: too many decimal points in number
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:526: error: too many decimal points in number
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:530: error: too many decimal points in number
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:534: error: too many decimal points in number
C:\Users\Derek\Desktop\Arduino 1.5.2\arduino-1.5.2\hardware\arduino\sam\libraries\CAN/due_can.h:538: error: too many decimal points in number
Thanks
Palliser
Hello djusthof,
I don't know which due_can.h file you pulled but the one from collin80 here: https://github.com/collin80/due_can only has 241 lines and I see you are getting error in line 538?. Thus, I would recommend you to download again the library and try it again. Regards.
djusthof
zabaat
Is there any way at all to get more than 8 total mailboxes?
Code: [Select]
CAN.global_send_transfer_cmd(CAN_TCR_MB0 | CAN_TCR_MB1 | CAN_TCR_MB2 | CAN_TCR_MB3 | CAN_TCR_MB4 | CAN_TCR_MB5 | CAN_TCR_MB6 | CAN_TCR_MB7 | CAN_TCR_MB8 | CAN_TCR_MB9 | CAN_TCR_MB10 | CAN_TCR_MB11 | CAN_TCR_MB12);
Code: [Select]
dueCAN4.ino: In function 'void loop()':
dueCAN4:475: error: 'CAN_TCR_MB8' was not declared in this scope
dueCAN4:475: error: 'CAN_TCR_MB9' was not declared in this scope
dueCAN4:475: error: 'CAN_TCR_MB10' was not declared in this scope
dueCAN4:475: error: 'CAN_TCR_MB11' was not declared in this scope
dueCAN4:475: error: 'CAN_TCR_MB12' was not declared in this scope
I tried this in the library... but not sure what is going on
due_can.cpp
Code: [Select]
void CANRaw::interruptHandler() {
uint32_t ul_status = m_pCan->CAN_SR; //get status of interrupts
if (ul_status & CAN_SR_MB0) { //mailbox 0 event
mailbox_int_handler(0, ul_status);
if (ul_status & CAN_SR_MB1) { //mailbox 1 event
mailbox_int_handler(1, ul_status);
if (ul_status & CAN_SR_MB2) { //mailbox 2 event
mailbox_int_handler(2, ul_status);
if (ul_status & CAN_SR_MB3) { //mailbox 3 event
mailbox_int_handler(3, ul_status);
if (ul_status & CAN_SR_MB4) { //mailbox 4 event
mailbox_int_handler(4, ul_status);
if (ul_status & CAN_SR_MB5) { //mailbox 5 event
mailbox_int_handler(5, ul_status);
if (ul_status & CAN_SR_MB6) { //mailbox 6 event
mailbox_int_handler(6, ul_status);
if (ul_status & CAN_SR_MB7) { //mailbox 7 event
mailbox_int_handler(7, ul_status);
if (ul_status & CAN_SR_MB8) { //mailbox 7 event
mailbox_int_handler(8, ul_status);
if (ul_status & CAN_SR_MB9) { //mailbox 7 event
mailbox_int_handler(9, ul_status);
if (ul_status & CAN_SR_MB10) { //mailbox 7 event
mailbox_int_handler(10, ul_status);
if (ul_status & CAN_SR_MB11) { //mailbox 7 event
mailbox_int_handler(11, ul_status);
if (ul_status & CAN_SR_MB12) { //mailbox 7 event
mailbox_int_handler(12, ul_status);
keywords.txt
Code: [Select]
CAN_TCR_MB0 LITERAL1
CAN_TCR_MB1 LITERAL1
CAN_TCR_MB2 LITERAL1
CAN_TCR_MB3 LITERAL1
CAN_TCR_MB4 LITERAL1
CAN_TCR_MB5 LITERAL1
CAN_TCR_MB6 LITERAL1
CAN_TCR_MB7 LITERAL1
CAN_TCR_MB8 LITERAL1
CAN_TCR_MB9 LITERAL1
CAN_TCR_MB10 LITERAL1
CAN_TCR_MB11 LITERAL1
CAN_TCR_MB12 LITERAL1
I didn't know I was so limited in this respect and am almost ready for this project and just hit an enormous wall!
Palliser
Hello zabaat.
According to Atmel doc11057 (page 1207) http://www.atmel.com/Images/doc11057.pdf, each of the two CAN controllers inside SAM3X8E has 8 mailboxes implemented. Thus, you have 16 mailboxes available which is more than enough for a general purpose CAN project. It is a hardware limitation of the MCU. Notice also that the component_can.h file from the CMSIS library on the Arduino Due...
Quote
(...\arduino-1.5.2-windows\arduino-1.5.2\hardware\arduino\sam\system\CMSIS\Device\ATMEL\sam3xa\include\component)
... there are only 8 defined mailboxes per CAN controller (MB0->MB7). On the other hand, you could optimize the use of the mailboxes implementing the Producer<->Consumer mode where you need half of the amount of mailboxes as compared to the clasical Transmit<->Receive mode. Can you tell us more about you application?. Why more than 16 mailboxes? Regards!
