Topic: Navie USB port drivers (Arduino Due mode) (Read 15812 times) previous topic - next topic
hiduino
For the Native USB port I have installed the "BOSSA programming port" under Windows XP Pro SP3.  It works okay for uploading a sketch.
However, once the sketch runs the usb port changes to "Arduino Due" mode and the driver does not install.  It appears that Windows XP cannot find the driver?  Is the "Arduino Due" usb driver supported under Windows XP?  Or am I misunderstanding how the Native port works?
hiduino
The Windows Device Manager lists the Arduino Due, Hardware ids:
USB\Vid_2341&Pid_003e&Rev_0100
However the included ArduinoDue.inf in the drivers folder is showing:
[DeviceList]
%DESCRIPTION%=DriverInstall, USB\VID_2341&PID_003E&MI_00
[DeviceList.NTamd64]
Could this be why they are not matching?
Louis Davis
Try removing the &MI_00 from the description in the .inf and try to install again.
The way that Windows tries to find a match is to match the VID and PID first and then will get more specific depending on what is specified in the .inf
If we don't want or need to have different drivers for specific REVs, etc. then just specifying the VID and PID is sufficient for Windows to find a matching device.
hiduino
Yep, that works by removing the &MI_00 from the end of the line.  Windows XP now correctly installs the Arduino Due driver for the Native USB port.  I now can use it for uploading as well as serial communications.
hiduino
I don't know if the "&MI_00" is need for other Windows versions, so instead of removing it you can also try appending additional hardware Ids to the end of the line.  This works great for my Windows XP Pro SP3 installation.
To summarize if you are having trouble installing the "Arduino Due" USB driver for the Native USB Port for Windows, you may need to edit the \arduino-1.5.1r2\drivers\Arduino Due.inf file:
Change these lines from:
Code: [Select]
[DeviceList]
To these lines(appended Hardware Ids):
Code: [Select]
[DeviceList]
%DESCRIPTION%=DriverInstall, USB\VID_2341&PID_003E&MI_00, USB\VID_2341&PID_003E
magi2556
Having trouble installing the "Arduino Due" USB driver for the Native USB Port for Windows XP Pro SP3, I edited the \arduino-1.5.1r2\drivers\Arduino Due.inf file as suggested :
[DeviceList]
But sketch "keyboarSerial" don't work.
I upload sketch (ok), open Serial Monitor, digit a letter (inCHAR) and press "send", no replay (inChar+1).
What is the problem?
Louis Davis
You will need to apply this commit to your Arduino code base to solve your problem ( a release with this fix has not been made, yet ):
https://github.com/arduino/Arduino/commit/70351fc34150b1288079996839082e751b176821
Read this thread for all the details:
http://arduino.cc/forum/index.php/topic,129869.0.html
With the changes above, you should uninstall the driver, change back the .inf to original, then install the driver with the original .inf
magi2556
I have done.
Windows XP correctly installs the Arduino Due driver for the Native USB port.
But sketch "KeyboarSerial" still don't work.
magi2556
#8
Dec 13, 2012, 12:12 pm Last Edit: Dec 13, 2012, 05:03 pm by magi2556 Reason: 1
I have done some test.
With this code
  Keyboard.begin();
delay(2000);
  Keyboard.press(KEY_PAGE_UP);
     Keyboard.releaseAll();
It work ok.
With  "KeyboarSerial" sketch I digit a letter in the Serial Monitor window,press "send", but no replay (inChar+1) I recive.
Is 't correct this test of the sketch ?
Thanks.
After others tests I founded that if connect Arduino Due to programming Port "KeybordSerial" sketch work as aspected.
cmaglie
The problem is in the Serial port numbering on the Due.
Serial => RX0/TX0 and Programming Port
SerialUSB => Native Port
To make the example working with only one cable, you should use SerialUSB instead of Serial, but this will make the example fails on Arduino Leonardo (and derivatives)
C.
