Topic: 3 switches, code for each switch, trouble figuring out how to read each switch.. (Read 3454 times) previous topic - next topic
medic29
This is for the same project...it is the code to make the leds go from the inside out, but for some reason I have the earlier problem again where the ledEPin and ledFPin apparently are still firing when I want them to turn off, thus they only dim until it cycles again.  I have looked through the code and studied it, changed things and played with it, re-written it, etc.  If someone can take a look and see what I'm missing I would appreciate it.
Code: [Select]
// test code utilizing blink without delay.
// written 11/13/12.
const int ledAPin = 7;      // the number of the LED pin
const int ledBPin = 8;      // the number of the 2nd LED pin
const int ledCPin = 9;      // the number of the 3rd LED pin
const int ledDPin = 10;     // the number of the 4th LED pin
const int ledEPin = 11;     // the number of the 5th LED pin
const int ledFPin = 12;     // the number of the 6th LED pin
// Variables will change:
long previousMillis = 0;        // will store last time LED was updated
long ledAOn = 2500;           // total time ledA is on
long ledBOn = 300;              // the time ledB will come on
long ledCOn = 600;
long ledDOn = 900;
long ledEOn = 1200;
long ledFOn = 1500;
long ledGOn = 1800;
long totalTime = 3000;
long totalTimeCenter = 2800;
  // set the digital pin as output:
  pinMode(ledAPin, OUTPUT);
  pinMode(ledBPin, OUTPUT);
  pinMode(ledCPin, OUTPUT);
  pinMode(ledDPin, OUTPUT);
  pinMode(ledEPin, OUTPUT);
  pinMode(ledFPin, OUTPUT);
    if(currentMillis - previousMillis > totalTimeCenter) {
    if(currentMillis - previousMillis < ledEOn){
      if(currentMillis - previousMillis < ledGOn)
      digitalWrite(ledCPin, HIGH);
      digitalWrite(ledDPin, HIGH);
    if(currentMillis - previousMillis > ledBOn){
        digitalWrite(ledBPin, HIGH);
        digitalWrite(ledEPin, HIGH);
    if(currentMillis - previousMillis > ledCOn){
        digitalWrite(ledAPin, HIGH);
        digitalWrite(ledFPin, HIGH);
    if(currentMillis - previousMillis > ledGOn){
     digitalWrite(ledAPin, LOW);
     digitalWrite(ledBPin, LOW);
     digitalWrite(ledCPin, LOW);
     digitalWrite(ledDPin, LOW);
     digitalWrite(ledEPin, LOW);
     digitalWrite(ledFPin, LOW);
thanks in advance.
Arrch
A couple of things...
Remove the commented out code, no need for it to waste space.
Create a variable that stores the result of currentMillis - previousMillis, and use that in your comparisons; no need to do the arithmetic that many times.
Use arrays for the pins and intervals; probably an array of a simple struct simple struct:
Code: [Select]
struct ledData {
 int pin;
 unsigned long on;
 unsigned long off;
I would also use a variable as a flag that gets set when you turn all the LEDs off, and cleared otherwise. Have a single if statement that checks the flag before even bothering to check if it's been long enough. Psuedocode:
Code: [Select]
if the flag cleared
 get the time difference
 check each led to see if it should be on
  turn all leds off
  set the flag
  clear the flag
I need to try to figure out what you are talking about as far as setting flags, etc.  As far as setting a variable to replace doing the arrythmatic, that would be easy enough, but either way doesn't affect the code and/or the functioning of the code. Not a bad idea to make the code look cleaner.
"setting and clearing a flag" isn't complicated; the concept is implemented using a simple variable and assigning it a some value that you check it against later on.
The functionality won't change, but when you're dealing with devices with limited resources, it's always a good idea to not make it do unnecessarily repetitive calculations.
Arrch
Code: [Select]
Did you forget brackets around the nested if statements? As you have it written, A and B are turned HIGH when both of their conditions are met, while F and E are turned only if the first condition is met, and regardless of the nested condition.
medic29
Code: [Select]
Yep, that is probably it.  I didn't realize I needed them, but it makes sense.  Thanks!!
