Pages: [1]   Go Down
Author Topic: Ohm Meter Issue  (Read 1225 times)
Offline Offline
Newbie
View Profile
Hi im trying to build an Ohm MEter for my project using the analog Pins, I have been following this post from a while ago http://arduino.cc/forum/index.php/topic,21614.0.html but im having some issues.
I am making a sort of object ID system. I have tiles that have a little circuit in them,its placed on a base station. push the button on the tile and the base station read the ID of the tile using the voltage divider rule (each tile has a unique resistance).
What I need in my circuit is this:
This sections is removable        base station
5v------Resistor--------Switch------10k------GND
                                         Analog Read
How should i modify the code from the above forum post to suit my needs?
I hope that makes sense
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
Where is your problem? What does not work?
Logged
Brunsbüttel, SH, F.Rep.GERM
Offline Offline
God Member
View Profile
WWW
u need a common ground...
i mean: the removable station and the base station must share the same ground potential...
so u need 2 tiles or so...
Logged
-Arne
Offline Offline
Newbie
View Profile
I don't understand, I do have a common ground, don't I? The right hand side of my diagram?
Logged
Offline Offline
God Member
View Profile
WWW
oh - ok... i wasnt sure...
so there is a low resistance connection between arduino's ground and that removable object's ground?
Logged
-Arne
Offline Offline
Newbie
View Profile
thats correct
« Last Edit: November 08, 2012, 01:55:03 am by ricadam » Logged
Offline Offline
God Member
View Profile
WWW
then u can just use analogRead()..
when it reads 0 no removable station is connected...
when it reads x (x>0) then a removable station with resistance Rremo=(Vref-Vsen)/Isen (where Vsen=(x*Vref)/1024 and Isen=Vsen/(10kR))...
u can configure Vref via this:
http://arduino.cc/en/Reference/AnalogReference?from=Reference.AREF
Logged
-Arne
Offline Offline
Newbie
View Profile
Ok so if I set Vref to 5v and instead of a 10K known resistance I have say a 3.3K would that work?
Logged
Offline Offline
God Member
View Profile
WWW
Quote
yup - sure - it's kirchoff's law... no electron ever violates it...  smiley
http://en.wikipedia.org/wiki/Kirchoff%27s_circuit_laws
Logged
-Arne
Pages: [1]   Go Up
Jump to:
