Author Topic: Ohm Meter Issue  (Read 681 times)
Hi im trying to build an Ohm MEter for my project using the analog Pins, I have been following this post from a while ago http://arduino.cc/forum/index.php/topic,21614.0.html but im having some issues.
I am making a sort of object ID system. I have tiles that have a little circuit in them,its placed on a base station. push the button on the tile and the base station read the ID of the tile using the voltage divider rule (each tile has a unique resistance).
What I need in my circuit is this:
This sections is removable        base station
5v------Resistor--------Switch------10k------GND
                                         Analog Read
How should i modify the code from the above forum post to suit my needs?
I hope that makes sense
Switzerland
Where is your problem? What does not work?
Brunsbüttel, SH, F.Rep.GERM
u need a common ground...
i mean: the removable station and the base station must share the same ground potential...
so u need 2 tiles or so...
-Arne
I don't understand, I do have a common ground, don't I? The right hand side of my diagram?
oh - ok... i wasnt sure...
so there is a low resistance connection between arduino's ground and that removable object's ground?
-Arne
thats correct
« Last Edit: November 08, 2012, 01:55:03 am by ricadam » Logged
then u can just use analogRead()..
when it reads 0 no removable station is connected...
when it reads x (x>0) then a removable station with resistance Rremo=(Vref-Vsen)/Isen (where Vsen=(x*Vref)/1024 and Isen=Vsen/(10kR))...
u can configure Vref via this:
http://arduino.cc/en/Reference/AnalogReference?from=Reference.AREF
-Arne
Ok so if I set Vref to 5v and instead of a 10K known resistance I have say a 3.3K would that work?
yup - sure - it's kirchoff's law... no electron ever violates it...  smiley
http://en.wikipedia.org/wiki/Kirchoff%27s_circuit_laws
-Arne
