Pages: [1] 2   Go Down
Author Topic: problem with visualbasic 2010 coding  (Read 2233 times)
hi everyone,
need ur help to solve the problem that i face.im working on developing the flood monitoring system, using serial data received, then manipulte the data by arduino atMega328 deumilanove. im trying to do the visual basic command but i got an error stated that there are command that is not initialized.my coding are as follows.
visual basic 2010 coding.
Imports System.Text
Imports System.IO.Ports
Imports System.Threading
Imports System.TimeZone
Imports System.Math
Public Class Form1
    Dim voltage As Integer
    Delegate Sub ProcessDataDelegate(ByVal Longitude As String, ByVal Latitude As String)
    Private Sub SerialPort1_DataReceived(ByVal sender As Object, _
                                         ByVal e As SerialDataReceivedEventArgs) Handles SerialPort1.DataReceived
        Try
            Dim Longitude As Integer = SerialPort1.ReadLine()
            Dim Latitude As Integer = SerialPort1.ReadLine()
            Me.Invoke(New ProcessDataDelegate(AddressOf ProcessData), Longitude, Latitude)
        Catch ex As Exception
            MessageBox.Show(ex.ToString, " Unable to get the location")
            SerialPort1.Close()
        End Try
    End Sub
    Sub ProcessData(ByVal Longitude As String, ByVal Latitude As String)
        TextBox1.Text = Longitude
        TextBox2.Text = Latitude
    End Sub
    Private Sub Button1_Click(ByVal sender As Object, ByVal _e As EventArgs) Handles Button1.Click
        If Button1.Text = "Close" Then
            SerialPort1.Close()
            Button1.Text = "Open"
        Else
            If Not SerialPort1.IsOpen Then SerialPort1.Open()
            Button1.Text = " Close"
        End If
    End Sub
    Private Sub Form1_FormClosing(ByVal sender As Object, ByVal _e As FormClosingEventArgs
                                  ) Handles Me.FormClosing
        SerialPort1.Close()
    End Sub
    Private Sub WebBrowser2_DocumentCompleted(ByVal sender As System.Object, ByVal e As System.Windows.Forms.WebBrowserDocumentCompletedEventArgs) Handles WebBrowser2.DocumentCompleted
        WebBrowser2.Navigate("maps.google.com/maps?q=")
    End Sub
    Private Sub CheckedListBox1_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
        If (voltage <= 0.5) Then
            MsgBox("Checked")
        Else
            MsgBox("Unchecked")
        End If
    End Sub
    Private Sub CheckedListBox1_SelectedIndexChanged_1(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CheckedListBox1.SelectedIndexChanged
        If CheckedListBox1.GetItemCheckState(voltage <= 0.5) Then
            CheckedListBox1.Text = True
            CheckedListBox1.CheckOnClick = True
        Else
            If Not CheckedListBox1.CheckOnClick Then
                CheckedListBox1.Text = False
            End If
        End If
    End Sub
    Private Sub TextBox3_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TextBox3.TextChanged
            MsgBox(" safe")
            TextBox3.Show()
        End If
            If (voltage >= 0.5 And voltage <= 0.6) Then
                CheckedListBox2.Text = True
                MsgBox(" WARNING")
                TextBox3.Show()
            End If
        If (voltage <= 0.6 And voltage <= 0.7) Then
            CheckedListBox3.Text = True
            MsgBox("DANGER")
            TextBox3.Show()
        End If
    End Sub
    Private Sub SplitContainer2_Panel2_Paint(ByVal sender As System.Object, ByVal e As System.Windows.Forms.PaintEventArgs) Handles SplitContainer2.Panel2.Paint
    End Sub
    Private Sub SplitContainer1_Panel1_Paint(ByVal sender As System.Object, ByVal e As System.Windows.Forms.PaintEventArgs) Handles SplitContainer1.Panel1.Paint
    End Sub
    Private Sub PictureBox1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs)
    End Sub
    Private Sub CheckedListBox2_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CheckedListBox2.SelectedIndexChanged
        If CheckedListBox2.GetItemCheckState(voltage >= 0.5 And voltage <= 0.6) Then
            CheckedListBox2.CheckOnClick = True
        Else
            If Not CheckedListBox2.CheckOnClick Then
            End If
        End If
    End Sub
    Private Sub CheckedListBox3_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CheckedListBox3.SelectedIndexChanged
        If CheckedListBox3.GetItemCheckState(voltage >= 0.6 And voltage <= 0.7) Then
        Else
            End If
        End If
    End Sub
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Timer1.Enabled = True
        Timer1.Interval = 1
    End Sub
    Private Sub PictureBox1_Click_1(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles PictureBox1.Click
    End Sub
    Private Sub Label6_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label6.TextChanged
        Label6.Text = DateString
    End Sub
    Private Sub Label7_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label7.TextChanged
        Label7.Text = TimeOfDay
    End Sub
End Class
hope anyone can help me solve this problem.thanks.
Seattle, WA USA
Online Online
Seattle, WA USA
I doubt that the syntax of the message was as mangled as that. Post the EXACT error message.
Good thing you found this problem early before you wrote a ton of code.
i cannot paste the print screen of the error..
after compiling the coding...another window appeared stated that " an invalid operation excerption was unhandled"
The error is: Failed to initialize because CategoryName is missing
tq.
Seattle, WA USA
Online Online
Seattle, WA USA
Where is SerialPort1 defined/initialized? How is it defined and initialized?
should it be initialized?how? because previously i have complied the code, but no error happens. how ever , the error appeared as i put the timer function to the code.
paul...how to intialized the serial port1?
Seattle, WA USA
Online Online
Seattle, WA USA
Initialization is the second step. You have not explained the first step - declaration.
You do some programming to solve a problem, and some to solve it in a particular language. (CC2)
        If Button1.Text = "Close" Then    ' will fail it button's text is " Close" (notice the extra space)
            SerialPort1.Close()
        Else
            If Not SerialPort1.IsOpen Then SerialPort1.Open()    ' where is endif ?
            Button1.Text = " Close"    ' one extra space!
        End If
    End Sub
Where do you set the port options (baud rate, etc. ?).
PaulS, here is the declaration for the serialport1.
Public Class Form1
    Dim WithEvents longitude As SerialPort = New  _
        System.IO.Ports.SerialPort("COM23", 9600, Parity.None, 8, StopBits.One)
however, i still get the same error " system.InvalidOperationException ".
tuxduino...
actually i got the coding from other pages.
            SerialPort1.Close()
        Else
            Button1.Text = " Close"    ' one extra space!( meaning of the code)?
        End If// here is the end if .
    End Sub
hope u can help me in understanding me the button.text= "close" code..i can get ur comment on that code.
(Please use code tags (# button in the editor toolbar above) when posting code.)
Please have a look at this (corrected) version of the code:
        SerialPort1.Close()
    Else
            SerialPort1.Open()
        End If
    End if
End Sub
Let's try to explain it in pseudocode:
if button1 label is "Close" then    (A)
    close the serial port
    change button1 label to "Open"
    if serial port is not already open
        open it
        change button1 label to "Close"   (B)
    endif
endif
(B) If the string assigned here is not _exactly_ equal to that tested in (A) the code won't work.
In the code fragment posted earlier, in (B) you have " Close", with an extra space before the first letter. That's not going to be equal to "Close" in (A), so the IF will always fail.
I hope it's clearer now.
tuxdino,i have try compile will your code.however..the compiling error still exist.the error stated that "A first chance exception of type 'System.InvalidOperationException' occurred in System.dll"
My advice was about the errors in the piece of code you posted. Presumably that exception comes from another part of the code. Without seeing the full code, it's hard to tell.
Also, does it happen just by clicking that Button1 or when some serial data comes in ?
tuxdino..PaulS..here is the full code
Imports System.Text
Imports System.Math
Public Class Form1
        Try
            SerialPort1.Close()
        End Try
    End Sub
    End Sub
            SerialPort1.Close()
        Else
                SerialPort1.Open()
            End If
        End If
    End Sub
        SerialPort1.Close()
    End Sub
    End Sub
            MsgBox("Checked")
        Else
            MsgBox("Unchecked")
        End If
    End Sub
        Else
            End If
        End If
    End Sub
            MsgBox(" safe")
            TextBox3.Show()
        End If
                MsgBox(" WARNING")
                TextBox3.Show()
            End If
            MsgBox("DANGER")
            TextBox3.Show()
        End If
    End Sub
    End Sub
    End Sub
    End Sub
        Else
            End If
        End If
    End Sub
        Else
            End If
        End If
    End Sub
        Timer1.Interval = 1
    End Sub
        PictureBox1.GetContainerControl()
        If (voltage = 0.5) Then
        End If
    End Sub
    End Sub
    End Sub
End Class
Does that "Unable to get the location" error message box show up ?
Pages: [1] 2   Go Up
