Loading...
Pages: [1]   Go Down
Author Topic: vernier conductivity probe  (Read 414 times)
Offline Offline
Newbie
View Profile
good day! how can I interface the vernier conductivity probe (manual here: http://www2.vernier.com/booklets/con-bta.pdf) to an arduino?
i mean, how can i interpret the voltage generated by the conductivity probe and convert it to conductivity?
specifically, how can I convert the VOLTAGE to CONDUCTIVITY with respect to the manual? I'm using the 0 - 200 uS range.
program draft:
int inputPin = 0;
float conductivity = 0;
  analogReference(DEFAULT);
  int samples = 20;
  int aRead = 0;
  for (int i = 0; i < samples ; i++)
    aRead += analogRead(inputPin);
  float voltage = 5.0 * aRead/ (1023.0 * samples);
// how to convert VOLTAGE to CONDUCTIVITY with respect to the manual? I'm using the 0 - 200 uS range.
  delay(2000);
please help. THANK YOU!
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
The document you linked to does not contain the information about how the conductivity is expressed in the voltage. I would assume that it's range to range (0-5V = 0-200uS) but why don't you just try?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
That document says nothing about the (proprietry) interface - some better documentation or reverse engineering is required.  Do you
have any of the devices it is normally connected to?
Logged
Central MN, USA
Online Online
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Very bad interface to find parts in Americas. Maybe on in Europe especially in UK. There is a DIN-5 to BTA-A adapter you want to buy so you can use DIN-5 hardware, so much easier to get. Also get the BTA-A breadboard kit if you want.
Logged
Pages: [1]   Go Up
Print
Jump to:
