Loading...
Pages: [1]   Go Down
Author Topic: Turning a rotary dial on an old phone  (Read 462 times)
Offline Offline
Newbie
View Profile
Hey, I'm looking to turn a rotary dial using a stepper motor. I'm hoping to take out some of the stress by using a couple of cogs so that we don't have the stepper turning the dial directly. My question is, what kind of kit will I need for this? I've got this shield picked out, http://proto-pic.co.uk/adafruit-motor-stepper-servo-shield-for-arduino-kit-v1-0/ and we have a generic stepper to play with but will I need quite a beefy stepper? I'm also curious as to how hard it is to use a stepper with a shield; is it as simple as a servo?
Thanks
-Struan
Logged
USA
Offline Offline
God Member
View Profile
As far as the output of the stepper motor, I don't think a lot of torque will be necessary to move the dial for a couple of reasons.  First, these dials were intended to be turned with a finger and usually one that could be attached to a pre-teen child or elderly person, not just an adult in their prime.  Second, you are planning to use some sort of mechanical drive using cogs/gears and with the proper gear ratio it can provide increased torque in exchange for slower rotation, which shouldn't be a problem since a human operated dial wouldn't be fast to begin with.  Therefore the stepper motor you have is likely to be up to the task.
As far as interfacing controlling the stepper motor... With a well made shield with libraries and online tutorials available, like the one from Adafruit you are planning on using, it shouldn't be any more difficult than controlling a servo.  Although the wiring and commands necessary for the two devices are will be different.
Logged
Offline Offline
Newbie
View Profile
Thanks very much Far-seeker! As it turns out we had a little trouble powering the shield but I left a post on Adafruit with the hopes of a fix.
Logged
Pages: [1]   Go Up
Print
Jump to:
