« on: November 07, 2012, 01:14:22 pm » |
IDE 1.01 UNO this is a general question not specific to a program yet so just the void is here goal. when i print or write some info to a serial port or network port etc the write and print commands take a variity of formats such as a byte, a number, a string and even an array. so as an example i might have this lcd.setCursor(10,0); lcd.print("ALL in "); lcd.setCursor(5,1); lcd.print("Error"); i would like to get it down to something like this MyLCD(10,0,"ALL in "); MyLCD(5,1,"Error"); void MyLCD(byte col, byte row, ?????? info { \\Here is where i am not sure of the proper datatype for the ?????? so it will take anything just like the print/write does //do additional stuff here
lcd.setCursor(col,row); lcd.print(info); }
Valencia, Spain
« Reply #1 on: November 07, 2012, 01:25:12 pm » |
lcd.setCursor(col,row); lcd.print(info); } Try this: template<class T> void MyLCD(byte col, byte row, T t) { lcd.setCursor(col,row); lcd.print(t); }
« Reply #2 on: November 07, 2012, 01:49:14 pm » |
i added that to the code after my void loop CMSBridge_ino2:6: error: 'T' has not been declared CMSBridge_ino2.cpp: In function 'void loop()': CMSBridge_ino2:246: error: invalid conversion from 'const char*' to 'int' CMSBridge_ino2:246: error: initializing argument 3 of 'void MyLCD(byte, byte, int)'
Valencia, Spain
« Reply #3 on: November 07, 2012, 01:55:33 pm » |
i added that to the code after my void loop CMSBridge_ino2:6: error: 'T' has not been declared CMSBridge_ino2.cpp: In function 'void loop()': CMSBridge_ino2:246: error: invalid conversion from 'const char*' to 'int' CMSBridge_ino2:246: error: initializing argument 3 of 'void MyLCD(byte, byte, int)' Did you try putting it before the place where it's used?
« Reply #4 on: November 07, 2012, 02:16:36 pm » |
i added that to the code after my void loop CMSBridge_ino2:6: error: 'T' has not been declared CMSBridge_ino2.cpp: In function 'void loop()': CMSBridge_ino2:246: error: invalid conversion from 'const char*' to 'int' CMSBridge_ino2:246: error: initializing argument 3 of 'void MyLCD(byte, byte, int)' Did you try putting it before the place where it's used? no matter where in code i put template<class T> i get the first error that T has not been declared
Seattle, WA USA
Online
Seattle, WA USA
« Reply #5 on: November 07, 2012, 04:45:54 pm » |
Template functions must be defined in a .h file that is then included in the sketch.
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
« Reply #6 on: November 07, 2012, 05:21:11 pm » |
Is the template class available in the IDE and in which lib does it live? Fungus (short for Funny Gustavo?)? Thank You, that Print function would solve a lot of GLCD printing that I need to do with the UTFT Library
Bob
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Valencia, Spain
« Reply #7 on: November 07, 2012, 05:40:52 pm » |
The Arduino IDE is weird about function ordering, it rearranges the code in the sketch before it compiles so that forward references work.
There has to be a way to make it work...you just need somebody who knows more then me about the IDE.
North Queensland, Australia
Online
« Reply #8 on: November 07, 2012, 06:37:15 pm » |
No, they can be in the source. If you include a header, its contents is placed in the spot of the '#include', so its no different to putting it at the top of the sketch. The compiler just needs to see it before its used. EDIT: PaulS may be right regarding Arduino specifics, it may only copy the function prototype without the previous 'template' line. Try putting it all on the one line 'template<class T> void MyLCD(byte col, byte row, T t);' though before separating. Had no trouble with template objects, spose functions are a different kettle of tea.
« Last Edit: November 07, 2012, 06:56:36 pm by pYro_65 »
Online
« Reply #9 on: November 07, 2012, 07:07:40 pm » |
You can do 3 different things I tried. template<class T> struct MyLCDHelper{ static void MyLCD(byte col, byte row, T t) { } };
//... MyLCDHelper< bool >::MyLCD( 2, 1, 0 ); struct MyLCDHelper{ template<class T> static void MyLCD(byte col, byte row, T t) { } };
//... MyLCDHelper::MyLCD( 2, 1, 0 ); //Template auto type deduction.
MyLCDHelper::MyLCD< bool >( 2, 1, 0 ); //Specific template.
Or a not so safe way. //This must be the first line of code. #define TVoid template<class T> void
TVoid MyLCD(byte col, byte row, T t) {
« Reply #10 on: November 07, 2012, 09:41:56 pm » |
} i used the not so safe way since it seemed easier, but why is it not so safe??
Online
« Reply #11 on: November 07, 2012, 10:18:50 pm » |
Not so much for the actual code, just now there are two things to modify when the return type change. Macros can be iffy, search google for examples. I didn't think of it before, but just use an anonymous namespace. namespace{ template<class T> void MyLCD(byte col, byte row, T t) {
void setup(){
MyLCD( 0, 1, 1 ); } Seems by far the best as the IDE doesn't generate a prototype for it.
« Last Edit: November 07, 2012, 10:23:54 pm by pYro_65 »
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #12 on: November 07, 2012, 10:23:26 pm » |
Forget the defines. Using IDE 1.0.2 you can make it work. Example: HardwareSerial & lcd = Serial;
// function prototype template<class T> void MyLCD(byte col, byte row, T t);
// function definition template<class T> void MyLCD(byte col, byte row, T t) { // lcd.setCursor(col,row); lcd.print(t); }
void setup () { } void loop () { }
That compiles without errors. I simulated the lcd class with a reference to HardwareSerial, but that's not important right now. The important thing is to prototype the templated function as I did up there. Then the compiler won't generate another prototype in the wrong place.
« Reply #13 on: November 08, 2012, 12:56:27 pm » |
That compiles without errors. I simulated the lcd class with a reference to HardwareSerial, but that's not important right now. The important thing is to prototype the templated function as I did up there. Then the compiler won't generate another prototype in the wrong place. this worked to a point, and i may be trying to do more than is possible(easily). what didnt work is old way lcd.print(z[1],HEX); new way MyLCD(0,1,z[1],HEX); i get CMSBridge_ino2.ino: In function 'void loop()': CMSBridge_ino2:152: error: no matching function for call to 'MyLCD(int, int, byte&, int)'
UK
« Reply #14 on: November 08, 2012, 01:35:05 pm » |
You seem to be passing four parameters to a templated function that expects three.
If you want the function to accept additional arguments such as a format specifier, you need to include those in the declaration and definition.
