Topic: DUE PWM Frequency (Read 70023 times) previous topic - next topic
evmaker
Finally I have my DUE in hand and wow is he fast and wonderful, so is a leaf labs maple. I am building my electric vehicle around a 3 phase hex inverter an an ac induction motor. The mega 2560 ha served me well as a proof of concept, however is incapable of doing the math and operations per second that this job is going to ultimately going to require. The project can be viewed at www.evmaker.tumblr.com. One has to go back several pages to get to the video of the truck actually running with the mega pulling the strings, but it did run for 100 or so miles. The problem is that 1 I am not a great c programer. 2 the mega is a little too slow. To make this work I need to change the PWM frequency of the due to at least 4000 Hz.
I want to play at least 60 samples of sine at a minimum top speed of 60 Hz This means that  will be 3600 samples per second. The mega is no problem to get ~4000 Hz, just is not fast enough to do the math and analog writes for more than 19 Hz. Well it pushed the truck down the road. Until I got greedy and tried a sketch that only played 30 samples then the pulses became too long and the inductive kick of the motor blew one of my igbt transistors. The DUE should from the tests have no problem delivering That which I need in terms of speed, I just need a little help modifying the PWM frequency.
Narrowed it down I think to one bit, 0x40094000, bit #19 needs to go to 0 not 1. Tried bitWrite, bitClear, word x = xx. No effect. Like I say I am not a programer by any count. bitRead seems to work just fine for me and returns the results that I would expect. It appears that the register is not write protected at the software level. Any suggestions appreciated.
James
Donziboy2
Howdy evmaker, very nice project you have going there.
http://arduino.cc/forum/index.php/topic,128734.0.html  <This gentleman is also trying to change that same thing I believe.
Your project looks like a lot of fun, the company I am working for designs drive systems for trains, buses, boats and cars.
I see alot of IGBT's of various sizes, and I have also seen plenty of examples of the magic smoke being released inside our drive enclosures.  Its no fun to have to clean one of those rma's  =(
evmaker
I seem to  be able to use bitRead to read the bits in 0x400940E8 bit 0 and bit 8 are both already set to 0.
This means that WPSWS0 and WPHWS0 are bot set to write protect off. It would seem that I should be able to do a simple bitWrite(0x40094000, 0x13, 0), However it seems that I have to define a long =x and use the x as the IDE thinks that it is a stinking 16 bit joe he is talking to. This becomes;
long x = 0x40094000;
bitWrite(x, 0x13, 0);
and later i do
int y =  bitRead(x, 0x13);
Serial.print(y);
and darn if it still ain't a 1
Tried several other things like above mentioned and the compiler wont complie, guess the due was just a waste of money I will continue the project with a leaf labs maple. Already have working code for that, just wanted to make my new pcb compatible with avr and sam3. The maple pins out a little different but the IDE can call a register by name timer_suchandsuch = timer_suchandsuch & 0xshit=0 | 0xnewvalue and presto pwm is set, Real similar to the old mega2650.
Could be that I just was not supposed to be building my own inverters, but my homemade grid  tie  worked hard all summer long and saved me $200 or so. It only runs at the frequency of the power co. Now in the fall it is only doing 3 kwh on a good  day Jul and Aug it was giving 8 to 9. Think I just need more sun and panels to catch it. Longer days would be nice too. It runs an UNO with a very short sketch.
Guess I'll just modify the pcb for maple and role on that. Just seemed that due would have been a more capable kind of guy.
Thank you all for the advice and interest,
James
io53
Impressive project! Would be sad to see you giving up the due for such a basic thing as changing the pwm frequency. The IDE does set the freq in some library, you could try to look for it and change the freq the same way the arduino guys have done. But I'm sure someone already have tried to change the freq and can show you how, it's just hope that such a person shows up :). I might give it a go tonight if I find some free time.
cmaglie
I'll suggest you to give a look here:
https://github.com/arduino/Arduino/blob/ide-1.5.x/hardware/arduino/sam/cores/arduino/wiring_analog.c#L252
to see an example of how to configure PWM channels, and here:
for TC.
BTW, you should be able to change PWM_CLK register, it's weird you can't. CLK register should be accessible using:
Code: [Select]
PWM->PWM_CLK = 0x.......;
Most peripherals inside the SAM3X needs to be "clocked" through a device called PMC. You must activate PMC before any other operation with:
Code: [Select]
pmc_enable_periph_clk(PWM_INTERFACE_ID);
maybe can be this the cause of your issue?
Another thing you can try is changing the PWM_FREQUENCY constant in variant.h:
https://github.com/arduino/Arduino/blob/ide-1.5.x/hardware/arduino/sam/variants/arduino_due_x/variant.h#L180
but I don't know if this would be sufficient to fit your needs. (needless to say: if you try that check the result with a scope first!)
C
C.
io53
Had a quick look at it and I can confirm that changing PWM_FREQUENCY in
https://github.com/arduino/Arduino/blob/ide-1.5.x/hardware/arduino/sam/variants/arduino_due_x/variant.h#L182 does change the freq. So if you just need the 4k freq it'll work fine. Still, a way to change the freq in the sketch would be preferred.
io53
#6
Nov 09, 2012, 07:58 pm Last Edit: Nov 09, 2012, 08:25 pm by io53 Reason: 1
Okay. So I figured out why it dosen't work if you set the register. It turns out that not all the pwm pins is actually pwm pin, some are timer pins. So for example doing:
'PWM->PWM_CLK = 0b00001010111111110000101011111111;'
Works for pin 6, but not pin 2. (Tho you need to do it after every analogWrite as analogWrite insist on the 1k freq)
Another easier way to change the freq is to do:
'PWMC_ConfigureClocks(whatever_freq_you_want * 255 , 0, VARIANT_MCK);'
From variants.cpp:
Code: [Select]
 // 0 .. 53 - Digital pins
 // 0/1 - UART (Serial)
 { PIOA, PIO_PA8A_URXD,     ID_PIOA, PIO_PERIPH_A, PIO_DEFAULT,  PIN_ATTR_DIGITAL,                 NO_ADC, NO_ADC, NOT_ON_PWM,  NOT_ON_TIMER }, // URXD
 { PIOA, PIO_PA9A_UTXD,     ID_PIOA, PIO_PERIPH_A, PIO_DEFAULT,  PIN_ATTR_DIGITAL,                 NO_ADC, NO_ADC, NOT_ON_PWM,  NOT_ON_TIMER }, // UTXD
 // 2
 { PIOB, PIO_PB25B_TIOA0,   ID_PIOB, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_TIMER), NO_ADC, NO_ADC, NOT_ON_PWM,  TC0_CHA0     }, // TIOA0
 { PIOC, PIO_PC28B_TIOA7,   ID_PIOC, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_TIMER), NO_ADC, NO_ADC, NOT_ON_PWM,  TC2_CHA7     }, // TIOA7
 { PIOC, PIO_PC26B_TIOB6,   ID_PIOC, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_TIMER), NO_ADC, NO_ADC, NOT_ON_PWM,  TC2_CHB6     }, // TIOB6
 // 5
 { PIOC, PIO_PC25B_TIOA6,   ID_PIOC, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_TIMER), NO_ADC, NO_ADC, NOT_ON_PWM,  TC2_CHA6     }, // TIOA6
 { PIOC, PIO_PC24B_PWML7,   ID_PIOC, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM),   NO_ADC, NO_ADC, PWM_CH7,     NOT_ON_TIMER }, // PWML7
 { PIOC, PIO_PC23B_PWML6,   ID_PIOC, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM),   NO_ADC, NO_ADC, PWM_CH6,     NOT_ON_TIMER }, // PWML6
 { PIOC, PIO_PC22B_PWML5,   ID_PIOC, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM),   NO_ADC, NO_ADC, PWM_CH5,     NOT_ON_TIMER }, // PWML5
 { PIOC, PIO_PC21B_PWML4,   ID_PIOC, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM),   NO_ADC, NO_ADC, PWM_CH4,     NOT_ON_TIMER }, // PWML4
 // 10
 { PIOC, PIO_PC29B_TIOB7,   ID_PIOC, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_TIMER), NO_ADC, NO_ADC, NOT_ON_PWM,  TC2_CHB7     }, // TIOB7
 { PIOD, PIO_PD7B_TIOA8,    ID_PIOD, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_TIMER), NO_ADC, NO_ADC, NOT_ON_PWM,  TC2_CHA8     }, // TIOA8
 { PIOD, PIO_PD8B_TIOB8,    ID_PIOD, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_TIMER), NO_ADC, NO_ADC, NOT_ON_PWM,  TC2_CHB8     }, // TIOB8
 // 13 - AMBER LED
 { PIOB, PIO_PB27B_TIOB0,   ID_PIOB, PIO_PERIPH_B, PIO_DEFAULT, (PIN_ATTR_DIGITAL|PIN_ATTR_TIMER), NO_ADC, NO_ADC, NOT_ON_PWM,  TC0_CHB0     }, // TIOB0
 // 14/15 - USART3 (Serial3)
 { PIOD, PIO_PD4B_TXD3,     ID_PIOD, PIO_PERIPH_B, PIO_DEFAULT, PIN_ATTR_DIGITAL,                  NO_ADC, NO_ADC, NOT_ON_PWM,  NOT_ON_TIMER }, // TXD3
 { PIOD, PIO_PD5B_RXD3,     ID_PIOD, PIO_PERIPH_B, PIO_DEFAULT, PIN_ATTR_DIGITAL,                  NO_ADC, NO_ADC, NOT_ON_PWM,  NOT_ON_TIMER }, // RXD3
As you can see only pin 6, 7, 8 and 9 is a PWM_CH pin.
You can surely change the freq on the timer pins too but I'm too tired to dig into that.
I'd say that the analogWrite need to be changed so that it allows easier change of the freq.
Edit:
If you don't want to set the freq for every analogWrite you could use 'PWMC_SetDutyCycle(PWM_INTERFACE, PWM_CH7, your_analog_write_value);' instead.
So a fading led sketch with 4k pwm freq on pin 6 would be:
Code: [Select]
void setup()  {
 pinMode(6, OUTPUT);
 analogWrite(6, 64);
 PWMC_ConfigureClocks(4000 * PWM_MAX_DUTY_CYCLE , 0, VARIANT_MCK);
void loop()  {
       for (int i = 0; i < 253; i++) {
           PWMC_SetDutyCycle(PWM_INTERFACE, PWM_CH7, i);
           delay(10);
for (int i = 255; i > 1; i--) {
           delay(10);
evmaker
io53, cmaglie,
Thanks so much for all the interest, and it looks like work too. I am so so sorry I simply am not that kind of programer, I am just a simple millwright who has slipped through the cracks mostly unnoticed. Most of my work involves using a 3 or 10 pound hammer or welding machine. I am what they call high functioning  autistic dyslexic. But not the number genius that most are portrayed or the music virtuoso for that mater.
Mostly all that I get is just the ability to be very awkward in public, have difficulty in relationships  and oh yea I am usually pretty good at fixing broken  machines. At least the fixing part allows me to eat. Somehow I managed to find a good wife who is patient and tolerates all of my ticks and raise a daughter who is wonderful (wonder if she shares my dna). They are both normal and take good care of me. It wasn't until much later than normal that I could read and write. Still very slow at both.
Here is an older sketch that actually was used to drive the truck down the road ;
Code: [Select]
Copyright Sanderso-Tesier Moters
This Program is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This software is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
See the GNU Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this software; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
// SANDERSON DYNAMIC DRIVE V1.8
// sucessful attempt at feedback loop
// Wave shaping on the fly under cube factor
// voltage Weighting proportional to pot and freq.
// THIS CODE RUNS ON MEGA 2560 ONLY
int y = 0;
float xa = (0);                                     //A phase starting point//
float xb = (2.0943951023931954923084289221863);     //B phase starting point 2pie/3//
float xc = (4.1887902047863909846168578443727);     //C phase starting point 4pie/3//
float index = (0.10471975511965977461542144610932); // 2pie/60 or 60 samples of 2pie//
//define data table arrays
int ahdat[60]; int aldat[60]; //A phase data
int bhdat[60]; int bldat[60]; //B phase data
int chdat[60]; int cldat[60]; //C phase data
//define use data table array
int ahdatu[60]; int aldatu[60]; //A phase data for use
int bhdatu[60]; int bldatu[60]; //B phase data for use
int chdatu[60]; int cldatu[60]; //C phase data for use
//output pin definition digital output pwm
int ahigh = 2;   //Naming IGBT drive pins for hex inverter
int alow = 3;
int bhigh = 5;
int blow = 6;
int chigh = 7;
int clow = 8;
//output to drive pump motor shield pins
int drivepump1 = 12; //Naming drivepump output pins
int drivepump2 = 11; //             "
int drivelev1 = 10;  //             "
int drivelev2 = 9;   //             "
//define input and assoc variables for pot box
int pot = A15;
int potvali = 0;
int hexdrive = 1000;
float potval = 0;
float hexpass = 1000;
//define input and assoc variables for feed back loop
int feed = A13;
int feedv = 0;
float feedc =0;
int decel =0;
//define variables assoc with voltage calculation
float v = .795;
float vc = .795;
float vcf = 0;
int hexv = 0;
 // Serial is for testing only rem out for use
 Serial.write(17);
 Serial.write(12);
// change carrier value of pwm timers so that they are the same
// HEXINVERTER
TCCR3B=(TCCR3B & 0xF8) | 0x02; //CHANGE OUTPUT PWM TO ~4000 HZ TIMER 3 PINS 2, 3, 5 MEGA ONLY LINE
TCCR4B=(TCCR4B & 0xF8) | 0x02; //CHANGE OUTPUT PWM TO ~4000 HZ TIMER 3 PINS 6, 7, 8 MEGA ONLY LINE
//change carrier value of pwm for drive pump
TCCR2B=(TCCR2B & 0xF8) | 0x02; //CHANGE OUTPUT PVM PINS 9, 10 4000 HZ TIMER MEGA LINE ONLY
TCCR1B=(TCCR1B & 0xF8) | 0x03; //CHANGE PWM TO ~500 HZ PINS 11, 12, FOR DRIVE PUMP MEGA ONLY LINE
//pin asssignment hexinvewrter
pinMode(ahigh, OUTPUT);  // assigns output pins for hex inverter as output
pinMode(alow, OUTPUT);   //                     "
pinMode(bhigh, OUTPUT);  //                     "
pinMode(blow, OUTPUT);   //                     "
pinMode(chigh, OUTPUT);  //                     "
pinMode(clow, OUTPUT);   //                     "
//pin assignment drivepump
pinMode(drivepump1, OUTPUT);  // assigns pins as output for drive pump
pinMode(drivepump2, OUTPUT);
pinMode(drivelev1, OUTPUT);
pinMode(drivelev2, OUTPUT);
//initialize drive pump
analogWrite(drivepump1, 127);  // Starts drive pump running
analogWrite(drivepump2, 127);
digitalWrite(drivelev1, HIGH);
digitalWrite(drivelev2, HIGH);
//populate array tables
for (int x = 1; x < 61; x = (x + 1)) {
 //A PHASE HIGH DATA
 ahdat[x] = ((sin (xa)) * (255));
 aldat[x] = (ahdat[x]);
 if ((ahdat[x]) <= (30)) { ahdat[x] = (0); }
 if (ahdat[x] > 250) { ahdat[x] = 255 ; }
 //A PHASE LOW DATA
 if ((aldat[x]) >= (-30)) {
    aldat[x] = (0);
 else {
   aldat[x] = ((aldat[x]) - ((aldat[x]) + (aldat[x])));
 if (aldat[x] > 250) { aldat[x] = 255 ; }
 //B PHASE HIGH DATA
 bhdat[x] = ((sin (xb)) * (255));
 bldat[x] = (bhdat[x]);
 if ((bhdat[x]) <= (30)) { bhdat[x] = (0); }
 if (bhdat[x] > 250) { bhdat[x] = 255 ; }
 //B PHASE LOW DATA
 if ((bldat[x]) >= (-30)) {
   bldat[x] = (0);
 else {
   bldat[x] = ((bldat[x]) - ((bldat[x]) + (bldat[x])));
 if (bldat[x] > 250) { bldat[x] = 255 ; }
 //C PHASE HIGH DATA
 chdat[x] = ((sin (xc)) * (255));
 cldat[x] = (chdat[x]);
 if ((chdat[x]) <= (30)) { chdat[x] = (0); }
 if (chdat[x] > 250) { chdat[x] = 255 ; }
 //C PHASE LOW DATA
 if ((cldat[x]) >= (-30)) {
   cldat[x] = (0);
 else {
   cldat[x] = ((cldat[x]) - ((cldat[x]) + (cldat[x])));
 if (cldat[x] > 250) { cldat[x] = 255 ; }
evmaker
Code: [Select]
Serial.print (ahdat[x]);
Serial.print ("  ");
Serial.print (aldat[x]);
Serial.print ("  ");
Serial.print ("/");
Serial.print ("  ");
Serial.print (bhdat[x]);
Serial.print ("  ");
Serial.print (bldat[x]);
Serial.print ("  ");
Serial.print ("/");
Serial.print ("  ");
Serial.print (chdat[x]);
Serial.print ("  ");
Serial.print (cldat[x]);
Serial.print ("  ");
Serial.print ("/");
Serial.print ("  ");
Serial.println (); */
//delay (1500);
xa = xa + index;
xb = xb + index;
xc = xc + index;
     y = ((y) + 1);//index y value for reading sine table
   //Feedback loop reading based on motor amps
   feedv = (analogRead(feed));
   feedc = feedc + feedv;
   feedv = feedc / 15;
   feedc = feedc - feedv;
   feedv = (feedv * sqrt(v));
   if (decel == 0) {
   if ((feedv) > (200)) { hexpass = (hexpass + ((sqrt(hexpass)) / (7))); }
   decel = 0;
   //POT READING throttle position
   potval = (sq((analogRead(pot) * .0250829) + 6.32455));
   // PROCESS POT DATA
   potvali = potval;
   if ((potvali) > (hexdrive)) { hexpass = (hexpass + (sqrt(hexpass) / 400)); decel = 1;}  //LINEAR DECELERATION
   if (feedv < 195) {
   if ((potvali) < (hexdrive - 5)) { hexpass = (hexpass - (sqrt(hexpass) / 65)); } //LINEAR ACCELERATION
   hexdrive = hexpass;
   //DRIVE VOLTAGE ADJUSTMENT V1.7 Production
   //AJUST APPLIED VIRTUAL VOLTAGE TO COMPENSATE FOR FREQUENCY
   // .78 SINE TO 1.7 SINE
   if ((hexdrive) > (1007)) {
    v = (.76);
    hexdrive = 1024;
  else {
   hexv = (1014 - ((potvali + hexpass) / 2));
   // vc = (((hexv) * (.0139475)) * ((hexv) * (.0139475)) * ((hexv) * (.0139475)));
   vc = (sq (sq((hexv) * (.006912))));
   vc = (vc / 1000);
   vc = vc + .74;
   if (vc > v) { v = vc ; }
   else { if (decel = 1) { v = vc; }
  // vcf = v - vc;
   //if (vcf > .45) { v = (v - .005); }
     ahdatu[y] = (ahdat[y] * v);
     if ((ahdatu[y]) >= (250)) { ahdatu[y] = 255 ; }
     aldatu[y] = (aldat[y] * v);
     if ((aldatu[y]) >= (250)) { aldatu[y] = 255 ; }
     bhdatu[y] = (bhdat[y] * v);
     if ((bhdatu[y]) >= (250)) { bhdatu[y] = 255 ; }
     bldatu[y] = (bldat[y] * v);
     if ((bldatu[y]) >= (250)) { bldatu[y] = 255 ; }
     chdatu[y] = (chdat[y] * v);
     if ((chdatu[y]) >= (250)) { chdatu[y] = 255 ; }
     cldatu[y] = (cldat[y] * v);
     if ((cldatu[y]) >= (250)) { cldatu[y] = 255 ; }
   hexinverter();
  void hexinverter() {
  analogWrite(ahigh, (ahdatu[y]));
  analogWrite(alow, (aldatu[y]));
  analogWrite(bhigh, (bhdatu[y]));
  analogWrite(blow, (bldatu[y]));
  analogWrite(chigh, (chdatu[y]));
  analogWrite(clow, (cldatu[y]));
  delayMicroseconds(hexdrive);
  if (y >= 60) { y = (0); }
As you can see I am not a real slick programer. It seemed to me that those example codes had to do with software serial and playing music. I just want to make all the PWM the same except a pair of them to drive the inverter that runs the drive pump. Leaf Labs Maple will do this line for line just have to rename the timers and swap a pin or two. So it looks like there will no open source arduino electric car it will be a Leaf Labs car. Provably I am trying to do something that should not be done, and am not the one who should be doing it anyway. My Grandfather said that anything worth doing will involve sweat. So far all due has yeald is a head ache. I did however win the bet with my friend  and made a truck move with electricity, it will be a maple that takes it out on the town.
Thank you all,
James
pjrc
Several people have also been asking for this feature on Teensy 3.0.
I'm considering adding an API to set the PWM frequency, and a bit of extra code in analogWrite to automatically scale the resolution to the available range.  That will add a bit of extra overhead in analogWrite, but perhaps that's ok?  Normally analogWrite doesn't take effect until the next PWM cycle anyway.
Christian, Massimo... if you guys are reading this, would you be interested in adding an API for this too?  If so, I'd really like to chat about what the function name and params would be, so we both do something that's compatible.
cmaglie
Paul, sure, would you like to make a proposal on the dev list?
C.
pjrc
Using that mail list drains my enthusiasm for Arduino contributions.
evmaker
That Would be really really cool to have that added, I would call it pwmWrite as the leaf labs bunch dose. In fact the leaf labs pwmWrite already has this functionality.
This week I have been modifying my pcb and sketches to run with a maple. Would have preferred to use DUE, as I it is my belief that it will eventually become the standard but right now  it is shall we say green and not ready. Once the DUE grows up and matures it will provably overwhelm the little maple and press it out of existence.
pjrc
Maple's pwmWrite appears to be only a 16 bit version of analogWrite
http://leaflabs.com/docs/lang/api/pwmwrite.html
How does it let you also control the frequency?
cmaglie
It seems that you must use HardwareTimer methods:
http://leaflabs.com/docs/lang/api/hardwaretimer.html#lang-hardwaretimer-setperiod
this API is not final, since they put a disclaimer that says:
"Warning:
The timer interface is still taking shape, and is expected to change significantly between releases. Because of that, the functionality described in this page shouldn't be considered stable."
C.
