Loading...
Pages: [1]   Go Down
Author Topic: [Risolto] [Wifi Shield] WL_IDLE_STATUS was not declared in this scope  (Read 340 times)
Offline Offline
Newbie
View Profile
Mi è appena arrivata la Wifi Shield e per fare un primo test (dopo averla inserita nella mia Arduino Uno rev3) ho provato ad eseguire il seguente sketch copiato/incollato da qui: http://arduino.cc/en/Guide/ArduinoWiFiShield#toc1
ma ottengo il seguente errore: "WL_IDLE_STATUS was not declared in this scope".
Ecco il codice in questione (...stampa le reti wifi rilevate):
Code:
#include <SPI.h>
#include <WiFi.h>
   // initialize serial and wait for the port to open:
   while(!Serial) ;
   // attempt to connect using WEP encryption:
   Serial.println("Initializing Wifi...");
   printMacAddress();
   // scan for existing networks:
   Serial.println("Scanning available networks...");
   listNetworks();
   delay(10000);
   listNetworks();
void printMacAddress() {
   // the MAC address of your Wifi shield
   byte mac[6];
   // print your MAC address:
   WiFi.macAddress(mac);
   Serial.print("MAC: ");
   Serial.print(mac[5],HEX);
   Serial.print(":");
   Serial.print(mac[4],HEX);
   Serial.print(":");
   Serial.print(mac[3],HEX);
   Serial.print(":");
   Serial.print(mac[2],HEX);
   Serial.print(":");
   Serial.print(mac[1],HEX);
   Serial.print(":");
   Serial.println(mac[0],HEX);
void listNetworks() {
   // scan for nearby networks:
   Serial.println("** Scan Networks **");
   byte numSsid = WiFi.scanNetworks();
   // print the list of networks seen:
   Serial.print("number of available networks:");
   Serial.println(numSsid);
   // print the network number and name for each network found:
   for (int thisNet = 0; thisNet<numSsid; thisNet++) {
     Serial.print(thisNet);
     Serial.print(") ");
     Serial.print(WiFi.SSID(thisNet));
     Serial.print("\tSignal: ");
     Serial.print(WiFi.RSSI(thisNet));
     Serial.print(" dBm");
     Serial.print("\tEncryption: ");
     Serial.println(WiFi.encryptionType(thisNet));
Ho già scaricato la Wifi Shield Library da questo link:
http://arduino.cc/en/uploads/Main/WiFiShield_library.zip
e posizionato la cartella WiFi in .../Arduino/library/
e non riesco a capire come mai ottengo quell'errore, chi sarebbe così gentile da aiutarmi?
« Last Edit: November 08, 2012, 09:40:51 am by abstract » Logged
IDE 1.0.2 - Arduino Uno R3 - Wifi Shield
Cagliari
Offline Offline
Faraday Member
View Profile
Su IDE 1.0.2 con Win7 compila perfettamente.
Se è la shield ufficiale non c'è bisogno di aggiungere nessuna libreria.
Scarica il nuovo IDE --> http://arduino.cc/en/Main/Software
Logged
0
Offline Offline
Edison Member
Have you mooed today?
View Profile
Ciao,
anche su ide 1.0.1 compila senza problemi, as is
Logged
Offline Offline
Newbie
View Profile
Ho scaricato la versione 1.0.2 dell'IDE e ora compila!  smiley-eek
Grazie mille ragazzi per le risposte, veloci ed efficaci!  smiley
« Last Edit: November 08, 2012, 09:41:05 am by abstract » Logged
Cagliari
Offline Offline
Faraday Member
View Profile
Bene, buon WiFi con Arduino.  smiley-mr-green
Logged
Pages: [1]   Go Up
Print
Jump to:
