Topic: [Risolto] [Wifi Shield] WL_IDLE_STATUS was not declared in this scope (Read 2013 times) previous topic - next topic
abstract
Mi è appena arrivata la Wifi Shield e per fare un primo test (dopo averla inserita nella mia Arduino Uno rev3) ho provato ad eseguire il seguente sketch copiato/incollato da qui: http://arduino.cc/en/Guide/ArduinoWiFiShield#toc1
ma ottengo il seguente errore: "WL_IDLE_STATUS was not declared in this scope".
Ecco il codice in questione (...stampa le reti wifi rilevate):
#include <SPI.h>
#include <WiFi.h>
  // initialize serial and wait for the port to open:
  while(!Serial) ;
  // attempt to connect using WEP encryption:
  Serial.println("Initializing Wifi...");
  printMacAddress();
  // scan for existing networks:
  Serial.println("Scanning available networks...");
  listNetworks();
  delay(10000);
  listNetworks();
void printMacAddress() {
  // the MAC address of your Wifi shield
  byte mac[6];
  // print your MAC address:
  WiFi.macAddress(mac);
  Serial.print("MAC: ");
  Serial.print(mac[5],HEX);
  Serial.print(":");
  Serial.print(mac[4],HEX);
  Serial.print(":");
  Serial.print(mac[3],HEX);
  Serial.print(":");
  Serial.print(mac[2],HEX);
  Serial.print(":");
  Serial.print(mac[1],HEX);
  Serial.print(":");
  Serial.println(mac[0],HEX);
void listNetworks() {
  // scan for nearby networks:
  Serial.println("** Scan Networks **");
  byte numSsid = WiFi.scanNetworks();
  // print the list of networks seen:
  Serial.print("number of available networks:");
  Serial.println(numSsid);
  // print the network number and name for each network found:
  for (int thisNet = 0; thisNet<numSsid; thisNet++) {
    Serial.print(thisNet);
    Serial.print(") ");
    Serial.print(WiFi.SSID(thisNet));
    Serial.print("\tSignal: ");
    Serial.print(WiFi.RSSI(thisNet));
    Serial.print(" dBm");
    Serial.print("\tEncryption: ");
    Serial.println(WiFi.encryptionType(thisNet));
Ho già scaricato la Wifi Shield Library da questo link:
http://arduino.cc/en/uploads/Main/WiFiShield_library.zip
e posizionato la cartella WiFi in .../Arduino/library/
e non riesco a capire come mai ottengo quell'errore, chi sarebbe così gentile da aiutarmi?
IDE 1.0.5 - Arduino Uno R3 - Arduino Wifi Shield - Arduino GSM Shield -  IMU Digital Combo Board 6 DOF ITG3200/ADXL345
PaoloP
Su IDE 1.0.2 con Win7 compila perfettamente.
Se è la shield ufficiale non c'è bisogno di aggiungere nessuna libreria.
Scarica il nuovo IDE --> http://arduino.cc/en/Main/Software
pictux
Ciao,
anche su ide 1.0.1 compila senza problemi, as is
abstract
#3
Nov 08, 2012, 03:37 pm Last Edit: Nov 08, 2012, 03:41 pm by abstract Reason: 1
Ho scaricato la versione 1.0.2 dell'IDE e ora compila!  :smiley-eek:
Grazie mille ragazzi per le risposte, veloci ed efficaci!  :)
PaoloP
