Topic: Power Up tons of Servos Simultaneously (Read 803 times) previous topic - next topic
artoriuscastus
Nov 08, 2012, 04:13 pm Last Edit: Nov 25, 2012, 03:04 pm by artoriuscastus Reason: 1
Hey all,
I want to ask whether i have a proper connection between, 4 servos, the arduino and its power. Because, i have tried it, but it can't move properly regarding to my command. I use XBEE wireless connection with Labview. if i use it for 2-3 servos, it runs properly , but if >4 servos, it seems that the command cannot go through all servo, it rotating but, sometimes it stuck or disobey the command i gave. is it the power problem or the circuit scheme i made?, thank you, i'm just a noob to this kind of things..
i already attached the image for circuit scheme and labview code.
any suggestion is highly appreciated. Thank you,  :)
MarkT
You are sharing power between Arduino and servos, so that its reseting when the servos draw lots of current.  This is the single most common problem posted here about servos and motors.
artoriuscastus
Oh ok, do you have any solution regarding to this issue?
DuaneB
Check the two links in my signature then buy more batteries and have separate power for the Arduino and the servos - but dont forget the shared ground connection - its all presented in detail in the two links below.
Duane B
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
artoriuscastus
Hai DuaneB thanks for your response,
btw now i have successfully powering the servo up to 7 servos (DF05SR 360degree), with the same circuit scheme i posted above, but actually i need to control 10 servos at a time, the other 3 servos are DF15MG (http://www.dfrobot.com/index.php?route=product/product&product_id=120#.ULNv_odJNX0). These 3 servos when i start to run the whole application is jittering, the other 7 servos is running pretty well. i'm using 4AA 4.8V 2700mAh for powering the arduino and USB connection for powering the arduino. Since this is a wireless application, what is good for powering the arduino instead of a usb connection? And what actually the main problem of the jittering servos?
And is it okay if i power up the arduino with 4AA battery the same as the servo being powered with?
Thank you, i'm sorry if i'm too clueless with this :(
zoomkat
Quote
That doesn't make much scense. you really should power the servos with ~6v instead of ~4.8v for best performance (4.8v is the minimum voltage for most servos). Below is a typical servo wiring setup.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
artoriuscastus
thanks for the reply and your suggestion,
i will give it a shot today,
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
