Loading...
Pages: 1 [2]   Go Down
Author Topic: 8 x RGB LED Array  (Read 1200 times)
Offline Offline
Jr. Member
View Profile
Im stuggling a little bit with the maskbit , as i am unsure of the purpose this is serving,
The number i want to send to the array is in decimal, and i want the array to conver it to a binary representation,
is the byte command used for this?
thanks
Rich
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
You are sending decimal, while it will be manipulated as  binary.
The maskBit makes sure that only 1 bit at a time is being tested for the digitalWrite.
Say you send in 64.
64 in binary = 01000000
so 64 & B00000001 = 0
64 & B00000010 = 0
64 & B00000100 = 0
64 & B00001000 = 0
64 & B00010000 = 0
64 & B00100000 = 0
64 & B01000000 = >0 so turn on an LED
64 & B10000000 = 0
You can prove this to yourself using serial.print to print out the results.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Jr. Member
View Profile
I tried running your code,
i had to move a few colons and add a few braces to get it to compile, but i dont seem to get any output,
Just for now i have replaced the CANbyte with a decimal number , i assume this should not be an issue,
code posted below
int x = 0;
int pinsArray[] = {2,3,4,5,6,7,8,9};  // could be whatever group you select
int maskBit = 1;
pinMode(pinsArray[8],OUTPUT);
void loop ()
maskBit = 1;                                       // start with B00000001
for (x=0; x<8; x=x+1){
if ((126 & maskBit) >0){                 // makes all bits but 1 low: 0000000C, next pass 000000C0, etc
digitalWrite (pinsArray
  • ,  HIGH);
else {
  • , LOW);
maskBit = maskBit<1;   // next bit - B00000010, B00000100, B00001000, etc up to B10000000
}  // next x
Logged
Offline Offline
Jr. Member
View Profile
OK, so i have managed to get the code to start running, and modifying the decimal number where the CANbyte value was will give me the desired LED patter,
The isue being, that is only flashes up for a second and it doesnt seem to be running through the loops correctly,
I have had a look over it and i cant spot anything obvious,
I had to add a "<" to the Maskbit line at the bottom as i assume it was supposed to be a Bitshift command? is thios correct?
Appreciating all the help folks
RIch
Code:
int x = 0;
int maskBit = 1;
int i = 0;
  for(i=0; i<8; i++)
pinMode(pinsArray[i],OUTPUT);
pinMode(10,OUTPUT);
maskBit == 1;
void loop ()
digitalWrite(10,HIGH);
if ((255 & maskBit) >0){                 // makes all bits but 1 low: 0000000C, next pass 000000C0, etc
digitalWrite (pinsArray[x],  HIGH);
else {
digitalWrite (pinsArray[x], LOW);
maskBit = maskBit<<1;   // next bit - B00000010, B00000100, B00001000, etc up to B10000000
}// next x
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
I still cannot grasp exactly what your trying to do with the value you get but if your trying to turn on/off the LED's in the binary pattern corresponding to the value receive then you can also do it this way
Code:
const byte target = B11110001;
void setup(){
void loop(){
    for (byte x=0;x<8;x++){
        if (((target>>x) & 1)==1){
            Serial.print("1");
        else {
            Serial.print("0");
        if (((target<<x) & 128)==128){
            Serial.print("1");
        else {
            Serial.print("0");
    while(true){
I have included 2x versions that rotate the bits out to either the left or the right.
Logged
Offline Offline
Jr. Member
View Profile
Sorted, a few tweaks and i am there, i had to replace the == operator at the top of the loop with a single = operator as it was running a comparison and getting stuck,
will follow up with some updates when i have meged the PWM colour code and CAN recieve and transmit code into the main code.
Thanks again
Rich
Logged
Offline Offline
Jr. Member
View Profile
Ah great thanks Riva, i will go try that code out now, the swapping of MSB and LSB looks very usefull
Logged
Offline Offline
Jr. Member
View Profile
Seems to be working great,
Thanks for all of the help Crossroads,
3 questions
1, How can i set the CAN code up to look at only a single base CAN id, at the moment, regardless of CAN id, it simple recieves any message and uses the data in the melevant bits to run the lights,
2, How can i clear the message buffers at the beginning of each time through the loop? at the moment, once the CAN message is removed from the bus, the led's remain in the last message state,
3, Any way of getting the code to run faster, as i believe i can display multiple colours at a time in software as the CAN u[pdate rate is fast enough for visual deception,
Code:
#include "mcp_can.h"
#include <SPI.h>
#include <stdio.h>
#define INT8U unsigned char
INT8U Flag_Recv = 0;
INT8U len = 0;
INT8U buf[8];
char str[20];
////////////////////////////////////////// CAN Setup Above
int x = 0;
int pinsArray[] = {4,7,8,9,14,15,16,17};  // could be whatever group you select
int maskBit = 1;
int i = 0;
///////////////////////////////////////////////////// LED Setup Above
  for(i=0; i<8; i++)
pinMode(3,OUTPUT);   // Red PWM
pinMode(5,OUTPUT);   // Green PWM
pinMode(6,OUTPUT);   // Blue PWM
//////////////////////////////////////////////////////////////// LED Outputs Above
 CAN.begin(CAN_500KBPS);                   // init can bus : baudrate = 500k
  attachInterrupt(0, MCP2515_ISR, FALLING); // start interrupt
////////////////////////////////////////////////////////CAN Begin Above
void MCP2515_ISR()
     Flag_Recv = 1;
/////////////////////////////////////////////CAN Calling code
void loop ()
 if(Flag_Recv)                   // check if get data
      Flag_Recv = 0;                // clear flag
      CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
      Serial.println("CAN_BUS GET DATA!");
      Serial.print("data len = ");Serial.println(len);
      for(int i = 0; i<len; i++)    // print the data
        Serial.print(buf[i]);Serial.print("\t");
////////////////////////////////////////////////////////////////////////////////Recieve CAN Message
analogWrite(3,buf[1]);
analogWrite(5,buf[2]);
analogWrite(6,buf[3]);
////////////////////////////////////////////////////////Set RGB Colour With CAN Message
if ((buf[0] & maskBit) >0){                 // makes all bits but 1 low: 0000000C, next pass 000000C0, etc
else {
maskBit = maskBit << 1;   // next bit - B00000010, B00000100, B00001000, etc up to B10000000
////////////////////////////////////////////////////////////////////////////////////////////////Write LED Pattern
}// next x
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
1. I don't anything about the message you are receiving.  Do you  have some definition of the message?
2.  buf[1] = 0;
buf[2] = 0;
buf3 = 0;
3.  Comment out the serial print's.
Logged
Offline Offline
Jr. Member
View Profile
1, the CAN.ReadMsgBuf command in the code above will read the CAN messages that are being recieved into the message buffer.
Currently, i am using the contents of the CAN message frame   eg, buf[1] being the first part, for the sequence of the LED's,
So weather the Message being sent had a base ID of 0x500 or ox600 , or any other base ID, the LED's would still do whatever the frame of data held.
i want to be able to "take notice" of only a single given CAN id to get my data from,
2, i tried doing this at the beginning of each loop, it seems to just cause the LED's to flash very quickly and at hardly any brightness, maybe i need to place it elsewehere in the loop?
3, thanks, i should have noticed that
Thanks
Rich
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Wrap this part with ID checking code:
Code:
if (buf[0]== intended_ID){
else {
}// next x
} // end ID check
else{
// add code to loop thru the pins with digitalWrite(pin, LOW)
Logged
Offline Offline
Jr. Member
View Profile
Thanks, im just waitinf for the correct command from the cuy that wrote the library to try it out, but looks great,
Any idea why when the CAN message is removed, or i disconnect the board from the CAN bus, it seems to display the last recieved sequence on the lights,
In principal, it should be able to show more than one colour at a time as the CAN speed is high enough, and writing some simple code of digital write high's and low's allows me to do it,
I think i may have something in there that is taking to long, or it isnt clearing the messge buffer fast enough,
What do you think?
Cheers
Rich
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
